DIY intake mod
Old 03-31-2005, 08:16 PM
  #31
takahashi's Avatar
Originally Posted by scotty
Perhaps Mazda should offer a model much along the lines of Porsche GT3/Carrera Cup car
Then it won't be a ~$60K car.
This is what all modification is about... do it as you see fits. Many people do up their cars are nothing like what the manufacturer is done. The company made car for people. And people modified their car to suit them.
Welcome to the Options world (as the Japanese like to say )
Old 04-16-2005, 07:38 PM
  #32
takahashi's Avatar
Wildcard I have done it.
It works as good as you said. Thanks!
https://www.rx8club.com/australia-new-zealand-forum-37/taka%92s-review-odula-ram-intake-duct-58857/
Old 04-16-2005, 08:16 PM
  #33
Lock & Load's Avatar
nice mod Taka whats the damage$$$$.
cheers
michael
Old 04-16-2005, 09:11 PM
  #34
takahashi's Avatar
21000 Yen. So it is about AUD$250 in Japan. Just add shipment and installation cost.
Old 04-16-2005, 10:03 PM
  #35
NT Rotorhead
Wildcard's Avatar
Glad you like it!
Old 04-17-2005, 12:19 AM
  #36
Taka
Wondering why you choose Odula over the racing beat system .??
cheers
michael
Old 04-17-2005, 02:14 AM
  #37
takahashi's Avatar
Racing beat does not have a dick like yours (which does not get up :p).
From the pictures of racing beat, it does have a bigger opening but it does not have an extension. And at least I have not seen a picture of one.
The similar design is RE Amemiya, and I am not prepare to pay 1000 bucks for one. It extension goes forward and have a large mouth. This may collect water in rainy days.
Old 04-17-2005, 03:22 AM
  #38
Shifty Bastard.
Gomez's Avatar
I won't collect water unless you drive through a river, Taka. Michael, the RB intake will have a CAI duct like this one available for it later in the year....according to Racing Beat.
Old 04-17-2005, 03:27 AM
  #39
Shifty Bastard.
Gomez's Avatar
Originally Posted by Wildcard
First, the long intake tube is specifically designed to be that length & width because the stock airbox uses Helmholtz resonant tuning. The length and width control the velocity of the air. Do a search if you are curious. I'll leave it at that....
The long VFAD tube is that length and made of fabric to reduce intake noise....not for tuning purposes. Racing Beat (who have a close relationship with Mazda) recently confirmed that on their website.
Old 11-24-2009, 06:51 PM
  #40
treitz's Avatar
So I am going to remove my VFAD this weekend and was going to gut my stock intake a throw a cone filter as recommended in this thread:https://www.rx8club.com/showthread.p...Ram+Air+Intake
If I do that, will adding this pipes help significantly? The pipes and cone filter cost me $66. If removing the VFAD alone will sound and perform the same with my stock filter I will return the cone and the pipes. But if they will sound better and offer more power I will keep them.
What should I do?
Old 11-25-2009, 12:16 AM
  #41
takahashi's Avatar
What kind of piping you are talking about?
I stand on my believe that the VFAD is for sound reduction only. There is no benefit of having it in terms of how the engine performs. I have recorded a lower intake temperature with a non VFAD direct tubing from the outside.
I never have problem with water to the filter.
Sounds are similar though but there is more but not significant noise from the front. You can prob can just hear it from the outside.
HKS has proven the use of cone filter benefit as long as you enclose it properly. In fact they recorded a higher power output with a system that have a box open ajar inside (if you know what I mean ... close but not air tight).
Linky: https://www.rx8club.com/showthread.p...ght=intake+HKS
Old 11-25-2009, 09:58 AM
  #42
treitz's Avatar
Basically my plan is to combine 3 different threads I have found on here.
First, remove the VFAD to increase the airflow
Second, gut my intake box and drop in a cone filter as shown in this thread...
Third, add intake piping to direct air straight into the filter. Basically a cheap air duct system as shown in this thread, the thread we are on right now...
My question is, if I remove the VFAD and drop in the cone filter is it really necessary to add in the duct piping? I would assume the answer is yes because otherwise, without the VFAD you aren't getting any direct airflow into the intake. Just wanted some other input.
Old 11-25-2009, 10:22 AM
  #43
Registered Zoom Zoomer
Huey52's Avatar
Wow, some folks were doing some "interesting" mod's back in the dark ages.
I went another route; removed my VFAD and mated a Racing Beat Ram air duct (instead of blue poly clothes dryer pipes to my stock air box with a K&N drop in filter. Also removed the two plastic baffles from the box.
It's not absolutely necessary to add duct piping, as air will certainly find its way to your cone filter, but to make it closer to a true Cold Air Intake (CAI) the duct does serve to more directly channel outside air when moving.
Old 11-25-2009, 10:45 AM
  #44
treitz's Avatar
Right on. Thanks for the input huey. I plan on replacing the pipes with the RB Duct when I can. But I figured since I am going to have the bumper off already I might as well try something!
I Considered the home made CAI option that puts the cone filter in the bumper... but I really don't see how the extra cost involved in that would provide much better results than just installing a cone filter in the stock box?
Old 11-25-2009, 10:48 AM
  #45
Grasshopper
Jon316G's Avatar
Instead of removing the VFAD/intake duct, why not just remove vacuum from the VFAD actuator so the valve stays open all the time?
And you don't need to remove the front bumper to do this.
But hey... to each their own.
Quick Reply: DIY intake mod
