DIY: Aftermarket flywheel
Old Jan 11, 2008 | 10:40 AM
  #51
Originally Posted by Slick8
You can use a Craftsman 2-1/8" socket from Sears for $27.99 to substitute the 54mm to remove the flywheel locknut and borrow a Timing Gear Puller from Autozone for free to remove the flywheel.
If you impact the flywheel nut off/on you don't need a breaker. CAUTION: LEAVE THE LOCKNUT ON WHEN REMOVING THE FLYWHEEL WITH THE PULLER OR RISK SERIOUS INJURY WHEN THE FLYWHEEL POPS OFF.
Old thread comes to life !
**** I got a 54MM impact socket on the internet, it saids 3/4 inch drive but it came @ 1in .... so it wont fit my impact
Can the Craftsman Socket you mention really work ? its 12 pt tho. I thought the big Flywheel nut is 6 pt ?
Old Jan 11, 2008 | 12:35 PM
  #52
staticlag's Avatar
The Professor
I think you can find the 54mm socket at lowe's also.
Old Jan 11, 2008 | 12:47 PM
  #53
The problem is the closest Lowes to me is like almost an hour drive >_<
If the Sears/Craftsman works I can go get it, its just like 5 minutes drive from my home. but 12 pt .... Is our Flywheel nut 6 or 12 ? or will the 12 fit ?
Old Jan 11, 2008 | 02:56 PM
  #54
staticlag's Avatar
The Professor
12 should fit.
Whats your impact gun rated at?
I remember mine was on so tight I had to give my gun like 110 psi.
Old Jan 11, 2008 | 03:40 PM
  #55
Reverse force is rated at 400 lbs ... dunno if its too low
Forward is about 350 lbs I think
Old Jan 14, 2008 | 01:02 AM
  #56
.....and to think I do these swaps with no air tools.......
Shut up !!!!!!!!!!!!!
I hate you being so skillful, I hate myself being a noob !!!!!!
Well, maybe after my 1st time, I will get a better idea on how to change it so I dont need to use as much air tools.
but come on Charles, air tools makes removing it 10 times faster. tell me thats not true :P
Old Jan 14, 2008 | 01:15 AM
  #57
I just did a complete engine swap with no air tools...I have a compressor and impact tools...but I find them clumsy and mostly a PIA.
They come in handy for a few things...but usually I just use ratchets and wrenches
Old Jan 25, 2009 | 02:22 PM
  #58
tournapart's Avatar
Your Mom is ******
just finished my install, need to bleed the SC a little more and adjust the pedal, but so far so good, prolite flywheel, ACT HDMM clutch kit, SS braided clutch line. took about 8hrs for the total install, on the floor with jackstands. The trans is only like 100lbs, I was able to muscle it up and down with the assistance of a floor jack for the alignment, but I have done this on a lot of different cars, nothing new to me. the 12pt craftsmen 2 1/8 socket works perfectly.
Old Jan 25, 2009 | 02:28 PM
  #59
G3tR3DDY2GR3DDY's Avatar
how did you get the top two bolts from the trans off?
Old Jan 25, 2009 | 02:30 PM
  #60
The only thing i would want an air tool for is the flywheel nut because i would be doing it on the floor and not much leverage with a breaker bar thats 36" long when you are 10" off the ground....
Old Jan 25, 2009 | 05:31 PM
  #61
tournapart's Avatar
Your Mom is ******
lol, had about 4 feet of 1/2inch drive extentions, so I could have clearance past the trans to turn the 1/2" ratchet....I have alot of tools, lol. With that many extensions there was enough play that it almost acted like a swivel but torque transfer was a lot more solid, so taking the bolts off was a breeze.
Old Jan 25, 2009 | 05:34 PM
  #62
tournapart's Avatar
Your Mom is ******
use a impact wrench to break the flywheel nut off, and thread the new one on (on my impact wrench, it has 4 settings, 1 is the hardest and 4 is so light I can hold the socket with my hand and it lightly hammers), other than that, hand tools are the way to go, unless you like breaking bolts
Old Aug 6, 2009 | 09:21 PM
  #63
outinnowhere3193's Avatar
outinnowhere3193
For those who don't have a puller or want to pop that flywheel off in a matter of seconds after you get the nut off the flywheel. If your like me your replacing that flywheel I could care less about it. Go to the outside edge of the flywheel..what a small sledge hammer or just the head. Start off with a small tap and just tap a little harder if you hit 5 times and no pop turn the motor and do it on the otherside. I made a puller and the impact didn't pull it...then I pulled the breaker bar and torqued as hard as I could...and never got anywhere. After thinking about it was afraid to hit it to hard but realized it don't make much on the outside edge and the flywheel falls off.
Old Sep 12, 2009 | 10:04 PM
  #64
Targatheory's Avatar
Question.
About how strong should a guy be to be able to get the flywheel nut off with the Racing Beat tool? Or rather, how much strength is needed? It is 540ft/lb right, so if the car is up on jackstands, hanging/pulling on the breaker bar...would that be enough? Would a mallet banging on the bar be better? I really don't have access to air tools, nor do I want to spend money when I can do the job with the specialty tool.
Also, about how safe is it to attempt the nut removal when the car is up on jacks stands? I'm just worried that the constant pulling yanking banging etc on the breaker bar could make the car slip and kill me.
Old Sep 13, 2009 | 01:22 AM
  #65
Jon316G's Avatar
Grasshopper
^I got the nut off with the Racing Beat tool.
Be prepared to have the car raised HIGH on jack stands (over 24" if possible) because the bar is really long.
We had to bend the bar a little bit to make it a little "shorter" and more room to turn it.
Because of this, I've had the end of the Racing Beat tool (the 54mm hex) cut and welded with a 1/2" attachment for a large breaker bar that can more easily fit under a car on jack stands.
And don't worry about doing this work on jack stands as long as they are good, large, sturdy stands.
Old Sep 13, 2009 | 11:41 PM
  #66
outinnowhere3193
For me I made my own tool that had a handle that was about the same length as the breaker bar. I just stuck a foot on the one bar and pulled on the other. It wasn't that hard.... I just start applying strength little by little... I'd say it took about 75% strength since I was slowly applying the pressure.
Old Sep 15, 2009 | 11:38 AM
  #67
NOTURX8's Avatar
it's always best with a PIT
Old Sep 29, 2009 | 01:55 AM
  #68
I've searched, and have read many threads on the subject. So this post is just out impulsive wannabe really really sure security matters.
Using 4ton jackstands, four of them, where is the THE MOST secure and stable locations for safety's sake. I will be using Kragen Powerbuilt stands.
Old Sep 29, 2009 | 05:59 AM
  #69
outinnowhere3193
As far as that...that's up to you it's not that bad...just find a spot you feel comfortable with....As far as your flywheel....
Loosen that nut and then just hit the outside edge of the flywheel with a hammer any size...and you don't even have to hit it hard.
The shaft is tappered...which means it gets bigger as it goes on...so a hit on the outside and it comes right off.. It will save you so much time and won't damage or hurt anything.
Old Oct 14, 2009 | 12:51 AM
  #70
Damn getting to the point where my car has been up on stands for four days not being able to finish the job because of work/rain. First heavy rain this very night, power was knocked out for a while.
Stuck with he transmission, only attempted once and couldn't get it. I'm having trouble getting the input shaft back into the spline of the clutch. Then I had to undo the pressure plate to check out the disc.
Noticed two things, that I could see tiny marks on the disc teeth where I had just missed the mark with the input shaft. Also, my pilot bearing seal is ripped up on one side, and I think this is what caused the bad alignment disc wise.
Just got a new seal today and will change those out, hope to fix this error.
Old Oct 14, 2009 | 12:57 AM
  #71
Jon316G's Avatar
Grasshopper
Make sure the engine is supported too.
Without the transmission attached, the engine will lean back and make it difficult to align.
I use a jack and wooden block to raise the back end of the engine up so its not leaning.
Also if the spline isn't going in, verify the clutch disc is properly aligned.
The past couple clutches I did I noticed the alignment tool didn't keep the disc centered and the tool tilted downward.
I had to lift the end of the alignment tool slightly while I tightened the pressure plate bolts.
Old Oct 14, 2009 | 01:22 AM
  #72
Ya, noticed that my alignment tool bent downwards also. Will try the jacing the engine tip, when it stops raining.
Old Mar 8, 2010 | 11:56 AM
  #73
batangisip89's Avatar
dumb question, and i have searched but didnt find a clear answer...
im shopping for a new clutch kit and while the clutch is being replaced might as well as relpace the flywheel with a lighter one. My only question is about the counterweight, because all the aftermarket flywheels say that i need a counter weight. can i reuse the OEM one or do i have to buy a new one...? never had to replace a clutch til now so im kinda uneducated in this area.
Old Jan 22, 2014 | 02:15 PM
  #74
csuttman's Avatar
From: Jupiter, Florida (sure beats Wisconsin winters!)
Do I need a new counterweight?
Good question, batangisip89 (even if a very old post)
I am a noob & my Exedy OE Clutch kit (MZK1002) just arrived. I didn't order a flywheel but am thinking that if I'm about to invest 8-16 hours into replacing the clutch... maybe I should do the lighter flywheel too.
I've spent hours reading the forums for DIY & tips for doing the clutch but it seems the most basic of questions isn't answered directly (that I saw)
Can someone please tell me when the flywheel counterweight needs to be replaced. I assume if I just do the clutch & leave the OE flywheel... I don't have to replace the weight... but do need to get the flywheel milled. If I replace the flywheel with a lighter one... can I still use the OE counterweight?
I'm confused because when shopping, some flywheels say you must use THEIR compatible counterweight (ex. Exedy Racing - Lightweight Flywheel - THMotorsports - Discount Performance Car & Truck Parts Sale | Lowest Price | Free Shipping) whereas many flywheels don't mention the counterweight at all.
Old Jan 22, 2014 | 02:26 PM
  #75
CRO8TIA's Avatar
The OEM flywheel has the counterweight integrated on the flywheel, if you use an aftermarket flywheel,you need a counterweight. Or use and automatic counterweight.
