5W30 Oil Don't Cut it, Engine Bearing Pics 58K S1 RX-8 from England.
Old Nov 3, 2009 | 02:31 AM
  #476
ASH8's Avatar
Super Moderator
Originally Posted by 9krpmrx8
It's a local member here that is rebuilding his engine.
Ran 10W-40, 70k on the motor. Front Apex seal was ****, says the rear was perfect.
Sure the front apex was ****?, it is just the second to last Pic is of the rear Rotor Housing and e-shaft.
  #477
madcows's Avatar
Damn rats nest in the engine!
But really, that's an apex seal that took a **** like that?!
Old Nov 3, 2009 | 07:24 AM
  #478
it seems that foreign substance like rocks went into the engine and **** everything up. Look at those marks on the rotor !
Old Nov 3, 2009 | 07:46 AM
  #479
Mazmart's Avatar
Originally Posted by bse50
Uhm... that doesn't look like an oil viscosity problem
More infos on the engine?
Boosted with a tuning issue perhaps?
Paul.
Old Nov 3, 2009 | 07:49 AM
  #480
PhillipM's Avatar
It does look like det. marks.
Old Nov 3, 2009 | 07:52 AM
  #481
Mazmart's Avatar
And the wonderful results of traveling apex seal fragments.
Paul.
Old Nov 3, 2009 | 08:07 AM
  #482
PhillipM's Avatar
WEll, you've got to let them out to see the world occasionally.
Old Nov 3, 2009 | 08:29 AM
  #483
Mazmart's Avatar
Yes, but the guards at the Renesis prison are not very easily persuaded to allow outside travel resulting in the troublesome inmates causing much uprising and unrest.
Paul.
Old Nov 3, 2009 | 09:19 AM
  #484
PhillipM's Avatar
You can usually bribe them with a big shot of nitrous.
Old Nov 3, 2009 | 10:24 AM
  #485
TX
No, I'm not sure, that's just what he said. The engine was not boosted. Although he did sell a nitrous kit, I don't think he ever had it installed.
Old Nov 3, 2009 | 10:54 AM
  #486
olddragger's Avatar
disoriented apex seal fragments under the influence of laughing gas and having a one fragment party inside a rapidly spinning party room.
Sort of like that thing that bounced out of control in the movie "Men in Black".
OD
Old Nov 3, 2009 | 05:51 PM
  #487
What do you guys think of this oil temp gauge? 1" x 2"
Old Nov 3, 2009 | 08:52 PM
  #488
madcows's Avatar
Looks corny.... Leave Knight Rider back in the 80s
Old Nov 3, 2009 | 09:07 PM
  #489
Under normal conditions only the amber numbers will be showing. I just don't like the look of bunch of different round gauges.
Old Nov 3, 2009 | 09:10 PM
  #490
Look at the PLX Devices OLED guages...You can have 4 sensors on each display..
I have 3...and can run up to 12 different sensors So far I can only figure I need the 9 I have
Old Nov 3, 2009 | 09:14 PM
  #491
I checked those out and they are very sweet. But really I just want oil pressure and oil temp, everything else I get through the Scangauge II. But maybe I will have price out everything i would need to get the PLX, it would be nice to only have one gauge.
Old Nov 3, 2009 | 09:24 PM
  #492
@!!narotordo's Avatar
FLAME ON!
180 to 200 is the usual oil temperatures for the RX-8 right?
Old Nov 3, 2009 | 09:30 PM
  #493
I would say average under normal conditions.
Old Nov 3, 2009 | 10:37 PM
  #494
ASH8's Avatar
Super Moderator
I like it mate....I think it looks KOOL... do you have a website link?..
It does have more than one function? OP , OT, no more?
Personally (no offense guys) I hate all the add on guages over the dash, although the function is there it looks way too RICE..
I like this if it is an all in-one, I may even consider for my 8 and be one of the first to get S2 the OP and OT numbers..
I would like to see Mazda move into a small multi-screen LCD readout similar to the GTR...perhaps the new RX-??
Old Nov 3, 2009 | 10:40 PM
  #495
ASH8's Avatar
Super Moderator
Found it on ebay...
Automobile Multimeter for EGT, Boost and More..
This digital automobile gauge can be used to measure temperature, pressure and other important parameters such as battery voltage, current and air/fuel ratio. Its bright LED display is easy to read from a distance as compared with many dim LCD type digital gauges. The programmable alarm will turn on a blue LED in the front panel to get driver's attention if the temperature/pressure is above the setting point. It will also close a relay output port that can be used to turn on a buzzard, shut off the fuel, or turn on a cooling fan. The meter stores the peak temperature/pressure with time that can be checked later. It can also operate in the peak holding mode so that only the maximum value is displayed. The brightness of LED display can be synchronized with headlight. When the headlight is turned on in the night, the display will be dimmed by the illumination signal. It can also be dimmed directly from the key pad. Developed based on industrial grade instruments, this four digits gauge offers up to 10 times the resolution and accuracy than the most of 3 digits gauges on the market. Its compact size (24 x 48 mm or 1x2") takes less space than a 52 mm round gauge.
For EGT measurement, the meter will work with all EGT sensors on the market, grounded or ungrounded. There is no input impendence matching requirement. It can display the temperature in either Celsius or Fahrenheit. It is probably one of the most accurate exhaust gas temperature (EGT) monitor on the market.
For boost pressure measurement, the meter will work with all MAP sensors as long as its pressure/output voltage relationship is known. It can display the pressure in either Bar, PSI, or user defined units with high resolution. However, it will not display the pressure with two different type of units in one scale such as PSI for pressure range but inHg for vacuum range.
For water/oil temperature measurement, the meter can display from -199 C to 250 C (or -199F to 500F) with 1 degree accuracy when used with our RTD sensor. It will also work with our liquid tight thermocouple based sensor, In addition, it can work with VDO 150C (300F) sensor with a limited display range (50-150C /120-300F).
For water/oil pressure measurement, the meter can work with either old style resistive pressure sensor or the modern style pressure transducer with linear voltage output. The meter offers a regulated 5V DC output for the power supply of the pressure transducer.
For air/fuel ratio measurement, it can be used to display either air/fuel ratio or lambda when interfaced with Innovate Motorsports' LC-1 wideband oxygen sensor controller. Please note, the meter cannot work as a stand along AFR with the oxygen sensor unless you are using a controller.
Specification
Input type
Temperature Sensor, K, E, S, R, J, T, B, WRe3-WRe25 Pt100, Cu50,
Pressure transducer, 0-375ohm, 0-5V, 0-75mV,
Other transducer: 0-30 mV, 1-5V, 0-10V, 0-10mA, 0-20mA, 4-20mA.
Display
One lines, Four digits. °F or °C, Bar, PSI, or user defined
Display resolution
1°C, 1°F, or 0.1°C, 0. 1°F, with Pt100
Display brightness control
12 V illumination control signal, or key pad
Accuracy
±0.2% or ±1 unit of full input range
Control mode
On-Off
Control output
Relay contact: 3A at 240VAC
Alarm
Relay (3 A rating) high/low alarm,
Recording function Maximum, Max time, Minimum, Min time.
Recording time 100 hrs with 1 minute resolution.
Power consumption
<2 Watt
Power supply voltage rating
12 (8.5-16.5)VDC
Panel cutout dimension 22x45 mm
Dimension
24 x 48 x 75mm (1/32 DIN)
Old Nov 4, 2009 | 10:52 AM
  #496
madcows's Avatar
I'll let you all in on a little secret... I'm starting work on a device that interfaces with several of the most common types of sensors, and can be viewed on any screen with a composite or VGA input (in dash DVD players, dash/visor mount LCDs) all at the same time. Although I don't suggest you hold your breath as it is still about 6 to 8 months away from a low-volume production run.
Old Nov 4, 2009 | 10:59 AM
  #497
that is normal.
but it also depends on your engine load.
if you're cruising on a highway, your oil temp will be much lower.
if you carry a lot of weight, it will go higher.
depends. ya know
my oil temp range from 70-110 Celsius.
Last night I was cruising on 495 and my oil temp was around 75-85 Celsius. About 50 Degrees outside.
Old Nov 4, 2009 | 03:03 PM
  #498
Mazurfer's Avatar
Surf Hard, Drive Hard
Three? Where the hell did you mount all the modules?
I have one DM200 OBDII hooked up right now(so I monitor 4) to my vent pod.
Because I am lazy and waiting for Winter, I haven't daisy chained the sensor module for oil temp/pressure yet.
Old Nov 4, 2009 | 03:23 PM
  #499
xun4gvn4everx's Avatar
True love is blue x2
Hey now! My car is named after that show....
Old Nov 4, 2009 | 04:16 PM
  #500
I have the vent pod as well and a oil temp gauge but I agree with ASH in terms of the look and the fact that it draws attention. This gauge is small and I have some ideas for installation due to it's small footprint. You can also order the sending units if different lengths/types, etc.
Here is the place that makes them.
http://www.auberins.com/
