Touring vs Grand Touring
Old Nov 16, 2009 | 02:11 PM
  #26
dozer's Avatar
on his 3rd rx8
1. thats not recommended, do you know if you have the updated starter?
2. NGK's are stock, and yes they should be the same, and i say go with napa, thats a good deal on the plugs, the stealerships like ripping people off, and YES DO IT YOURSELF, its way easy and its way cheaper
3. yes
Old Nov 16, 2009 | 02:12 PM
  #27
dozer's Avatar
on his 3rd rx8
bullet here you go
Old Nov 16, 2009 | 02:18 PM
  #28
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Ahhh I see hmmmm.... For some weird reason that doesn't look very stock?!?! I could be wrong but hey what do I know about turbos..... Lol
Old Nov 16, 2009 | 02:21 PM
  #29
Vikingdiesel's Avatar
3. yes
1. I dont know if I have the updated starter, would that make a difference for the plugs? is that a recall?
2. Thank you
3. How do I know which one is which, I read that its stamped right next to the plug, i looked, couldnt see though?
Old Nov 16, 2009 | 02:24 PM
  #30
dozer's Avatar
on his 3rd rx8
the plugs are stamped with either a T or an L...
i think the updated starter was a tsb
Old Nov 16, 2009 | 02:27 PM
  #31
dozer's Avatar
on his 3rd rx8
you know nothing about turbos, and you know even less about the 8
Old Nov 16, 2009 | 02:46 PM
  #32
the plugs are, but what if the plugs were wrong to begin with, how do I know where T or L goes into, which slot for which plugs?
Old Nov 16, 2009 | 02:49 PM
  #33
dozer's Avatar
on his 3rd rx8
when you go to install the plugs theres a T and an L stamped right the engine block right next to the plug holes
Old Nov 16, 2009 | 04:01 PM
  #34
Gr8Bullet's Avatar
Lol I know enough to make my 8 happy.
Old Nov 17, 2009 | 05:55 AM
  #35
Huey52's Avatar
Registered Zoom Zoomer
Dozer heads up the comic relief department, not technical issues, so I'll chime in.
1. There was a TSB that freely upgraded the starter and battery on all '04's and early '05's, but since the B-to-B warranty is up for that group it's no longer available.
The germane TSB was 01-004/05 dtd 12/1/2005 "Engine Cranks No Start" (note that later editions of this TSB did not discuss the new starter and battery, for the aforementioned reason). I don't have a softcopy, but from my hardcopy: ~"if the VIN is at or below JM1FE173*****150745 then visually inspect the starter placard. If the placard indicates N3H1 replace the starter. If the placard indicates N3H1 A or later you have the upgraded starter."
Early cars came with a Panasonic battery that was upgraded to an Interstate, so that's another way to know (unless the original owner just happened to get an Interstate). The starter placard is on the driver's side of the unit. You may have to jack up the vehicle to read it (use a jack stand).
2. You're welcome, but in the future try and search first.
3. The 'plugs have 'T' and 'L' labeled on their boxes and the engine block is stamped with a 'T' and 'L' adjacent their sockets. See the sparkplug change DIY.
2. Thank you
Old Nov 18, 2009 | 08:15 PM
  #36
db_8's Avatar
turbo.... mmm, toasty. they said mine was GT. dammit, i should go back, complain and ask for a replacement. a real GT this time
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
CMRine04
Sep 17, 2015 10:04 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
