Highest Horsepower dynos for SC Turbo and nitrous - post them here
Old Aug 11, 2009 | 03:20 PM
  #26
Kane's Avatar
Yeah I feel you - but even doing every 500 RPM / HP it would give you a good idea of the curve.
Old Aug 11, 2009 | 03:27 PM
  #27
rodjonathan's Avatar
silent assasin
thats some serious power
Old Aug 11, 2009 | 04:56 PM
  #28
ChrisRX8PR's Avatar
13B-RE
Originally Posted by bse50
Yeah, i just thought that a bridge ported renny was no longer a renny
We will get to see how those new ports work then! I just thought that it was ok to point that issue out before falling again in the "but you" spiral that killed the other thread.
I broke 500whp last fall with no bridge, the stock intake manifold and the front mount intercooler that I had in all my other runs...I just don't have a dyno sheet to post...I will see if I can find it...it wasn't the pretiest dyno, there were issues picking up the rpm...I was having a little spark blowout which was killing the top end and the stock intake many was chocking the engine so I didn't want to open a can of worms by posting dyno charts of that, I thought I would go again after that but one thing led to another and winter came and I made my new setup.
Eitherway, My engine is a renesis...ported or not...however, I will make sure and specify the extent of the modifications it has undergone to reach whatever level I reach in the next couple of weeks .
Chris
Old Aug 11, 2009 | 05:02 PM
  #29
Easy_E1's Avatar
I have to get the car back on the dyno. It's a lot more powerful now.
Old Aug 11, 2009 | 05:48 PM
  #30
Charles R. Hill's Avatar
Owner of BHR
Yeah, me too. I have not had much time lately to play with the nitrous stuff and I really should get back to it.
Old Aug 14, 2009 | 03:27 AM
  #31
suay's Avatar
Work hard Drive Hard!
es lo que es, gracias! te vamos a ver el fin de septiembre si vas al puerto para el mazda festival. Que core el gua gua!!!! suay AKA Josue. esta gente no conosen lo que el renesis puede corer! Brettus respect the boricua!!!! people don't know that puerto ricans know best!
Old Aug 14, 2009 | 03:40 AM
  #32
Brettus's Avatar
Boosted Kiwi
added chart to first post
Old Aug 14, 2009 | 07:01 AM
  #33
Kane's Avatar
That chart is bad ***!
Old Aug 14, 2009 | 08:37 AM
  #34
ChrisRX8PR's Avatar
13B-RE
Hey Brettus,
I would almost rather you plot the 366whp run on your comparison chart. In the 414 the E-boost2 controller was dropping the boost to wastegate spring pressure(10-11psi) on the top end because of a parameter that was set up incorrectly. In the 366whp dyno the car held the boost fine(there was no boost controller ) so it is more indicative of the power band with our kit.
Its just a suggestion...as much as its nice to have a 400whp chart up there when no one else has it, I would like people to see what the powerband should actually look like...not to mention that pretty soon I will have a dyno of the entire power band at higher numbers anyways and I will forward that to you asap.
Thanks.
Chris
Old Aug 14, 2009 | 08:45 AM
  #35
Owner of BHR
I tend to think that looking at and discussing the torque curves would be more educatuonal than the horsepower curves, but maybe that is just me.
Old Aug 14, 2009 | 03:14 PM
  #36
Brettus's Avatar
Boosted Kiwi
Originally Posted by ChrisRX8PR
Hey Brettus,
Thanks.
Chris
Good point but I really wanted the thread to be a ***** out -what can we do type of thing - not who has the nicest curves .
Old Aug 14, 2009 | 03:33 PM
  #37
Brettus's Avatar
Boosted Kiwi
I agree but most people wont want to know or understand that because they were educated by 'fast and furious' to look only at hp .
Old Aug 14, 2009 | 03:57 PM
  #38
ssspeedfreak's Avatar
I guess adding price to the mix makes sence.... kind of unfair to rate a $3500 kit vs one that is double the price. Or even a HP or TQ per $ comparo.
  #39
Mawnee's Avatar
I divide by zero
Hey, dont hate just because I live my life a quarter mile at a time!
I REALLY need to finish tuning mine and get it on the dyno. I'd love to jump into the action on THAT chart
Old Aug 14, 2009 | 04:33 PM
  #40
Kane's Avatar
And because torque does no work.
Look at the graph any RPM where HP is higher than another kit - that car would be accelerating FASTER than the one with the lower HP.
Compare the 3071 to the Esmeril and it can be clearly seen that the 3071 would pull down low and then the Esmeril would walk the 3071 past 5500 RPM's - no torque required.
Old Aug 14, 2009 | 04:53 PM
  #41
Brettus's Avatar
Boosted Kiwi
Exactly , and for that reason I don't think a torque chart is necessary . Aside from the fact that it is a whole lot more work to do and keep updated ....
Also : compare the SC dyno to either of the UG greddy or 3071 and you can see the 310ish whp turbos will out accelerate the 330whp SC
Old Aug 14, 2009 | 05:28 PM
  #42
Kane's Avatar
Werd!
Old Aug 14, 2009 | 05:32 PM
  #43
blackenedwings's Avatar
Life begins @ 30 psi
Well, until the chinese turbo gives up and throws shrapnel through your car, but yeah...
Old Aug 14, 2009 | 05:42 PM
  #44
Mawnee's Avatar
I divide by zero
:popcorn:
Old Aug 14, 2009 | 05:52 PM
  #45
chickenwafer's Avatar
Nope
I should have a dyno in a few weeks, hopefully one at 14 and 16psi.
Old Aug 14, 2009 | 06:44 PM
  #46
Kane's Avatar
I've installed one... 'nuff said.
Old Aug 14, 2009 | 07:20 PM
  #47
BLACKOUT's Avatar
To the BATMOBILE!!!!!!
+1 on that. Thank you very much. Luckily mine was caught before it went BOOM completely. As it stands when I am done I will look at posting my charts here. I will have a Esmeril kit running a TO4e 60 trim garrett instead of the chinese Snail Bomb that it had.
Old Aug 14, 2009 | 07:26 PM
  #48
now THAT is something I wanna see!
you doing the tuning yourself?
Old Aug 14, 2009 | 07:39 PM
  #49
Nope
Yeah.
I'm excited, too! I found a dyno in town that will cut me a good rate for self tuning.
I'll have my water/meth spraying at full tilt with Snow Boost juice (half water/half meth) and a splash or so of CP116 in the tank for protection. Since this is "All out" ya know, haha!
Old Aug 14, 2009 | 07:41 PM
  #50
go Big or go Home...
