Turbo owners, fill this out please.
Old Nov 1, 2008 | 01:54 AM
  #26
chickenwafer's Avatar
Nope
So I'm finally weighting in!
Make year of car (motor if changed) - 2005 (Mazda factory reman in 2008)
Transmission type - 6 Speed manual
Average high and low temp in area of operation - 45F to 98F (I don't drive in the Winter)
Altitude - 4985ft Above Sea Level (Thin air!!)
Fuel grade - 91 Cat ****
Oil type/grade - Idemitsu 10W30
Plug type/deg - Leading: NGK BURQEP, Trailing NGK RE9B-T, Custom LS2 Ignition System
Miles on motor before turbo - 3,000 on Reman
Miles with turbo - 3500
Blown motors - 1, but without turbo
Reason / what broke - Lost side seal in rear rotor
Turbo kit - Custom/Modified GReddy with MM/Garrett GT3071R upgrade
PCM/ECU - COBB Tuning AccessPORT
Lowest PSI and highest PSI you run - 7.5 psi (w/g) so far 14psi highest, still tuning
Your normal operation PSI - 9-9.5 psi
Shop tuned or self tuned - Self
Dyno'd HP/TQ (if you have) - 330-rwhp and 326 ft-lbs of torque @13.5psi/317-rwhp and 286 ft-lbs of torque @10psi
Fuel upgrades - Denso 730cc third bank injectors
Cooling upgrades -Snow Stage 2 water/meth injection, BHR aluminum rad, GReddy 1.3 bar rad cap, 98% distilled water with Water Wetter, rad fans on earlier with AP tune, Seibon vented hood
Exhaust type or diameter - Custom 3" diameter cat-delete pipe, HKS Hi-Power single outlet catback (2.9" diameter)
Cat or catless - Catless!
Driving style (DD/heavy foot/so on) - I like boost
Average time under boost per day - third of drive time
Total cost (ball park) for turbo/install/tune - $5500 including everything for turbo ONLY parts and ignition
Personal comments about your setup. (likes/dislikes) I love having boost "On Command", passing cars on the highway is too easy, accelerating from a stoplight is a little scary.
As with any major modifications, FI especially, it gets a little annoying to constantly have to watch AFRs and have an eye on your gauges, but the Cobb takes a lot of the worry away.
Old Nov 3, 2008 | 12:38 PM
  #27
maxxdamigz's Avatar
Baro Rex
Make year of car (motor if changed) - 2005 GT trim, purchased as a demo in 4/2006
Average high and low temp in area of operation - 0-105 (NJ) though I don't like going outside when it's 100 (rare) and my other car will see most of the winter
Altitude - +200-300ft
Fuel grade - 93
Oil type/grade - Valvoline 10/40
Plug type/deg - To be determined. Just torched some Rx7 plugs after 9k. Mazsport ignition solution, HKS Twin power.
Miles on motor before turbo - 33k pre-turbo
Miles with turbo - 9300 post turbo
Blown motors - none - still holds 20" vacuum at idle, for now.
Reason / what broke - N/A
Turbo kit - Type 1 (low mount) Mazsport kit
PCM/ECU - Int-X
Lowest PSI and highest PSI you run - Started with 7 psi, run 12.8 psi peak right now regularly.
Your normal operation PSI - 12.8 psi peak
Shop tuned or self tuned - Top end tuned by Maximum AutoSound. Has been self adjusted heavily since to account for newer parts
Dyno'd HP/TQ (if you have) - Did a 320whp on Maximum AutoSound's dynapack, but I don't really want to use their numbers for comparison. Did 284 whp @ 6000 rpms (254 wtq) at KDR Perfomance (dynojet, 1.02 CF) before ending run. Car needed more fuel and spark plugs are toast. Will need to run again.
Fuel upgrades - Mazsport Fuel Pump, Aeromotive Adj FPR, 650 primary, 780 secondary, stock aux injectors
Cooling upgrades -None. Mazmart water pump to be installed when I am no longer lazy.
Exhaust type or diameter - RP Supercat gutted w/ custom resonator. Racing beat dual muffler exhaust. 2.5" seconds removed and replaced with 3" slip fit to get a full 3" exhaust
Cat or catless - Just the shell remains
Driving style (DD/heavy foot/so on) - I boost a lot when I'm driving for fun, but 80% of my driving right now is to and from work. I'm putting miles on the car fairly quickly. I would anticipate a return to thorough use of the boost once I replace the spark plugs
Average time under boost per day - If I drive 60 minutes a day, I'm probably in boost for less than 2 minutes. It doesn't take long to get to "lose your license" speed. If I'm on vacation and drive 60 minutes, I'll be in boost 20-30% of the time depending on the number of stop lights.
Total cost (ball park) for turbo/install/tune - I plead the fifth.
I enjoy the numbers side of things. I like data logging and fuel maps and all the mundane crap. My car runs very quiet (possibly more quiet than stock) and I like that. I run 275 NT-01s and have no traction issues whatsoever with a little bit of throttle control (crappy pavement withstanding). As I've grown more comfortable with all the stuff added to the car, I've had a lot of fun doing setup and tuning work.
Old Nov 20, 2008 | 09:03 PM
  #28
Sovesky's Avatar
Sovesky
Make year of car (motor if changed) -2004
Transmission type -Manual
Average high and low temp in area of operation -high 95 Low -10
Altitude - 1000 ft above sea level
Fuel grade - 93
Oil type/grade - Mobil1 5w/20
Plug type/deg - Mazsport upgraded
Miles on motor before turbo -20000
Miles with turbo -2000
Blown motors -0
Reason / what broke -.....
Turbo kit -Mazsport type 2
PCM/ECU - Int-X
Lowest PSI and highest PSI you run - lowest 5 Highest 18
Your normal operation PSI - 10
Dyno'd HP/TQ (if you have) -Not yet.
Fuel upgrades - Mazsport Upgraded Pump and inj
Cooling upgrades - Koyo radiator.
Exhaust type or diameter - Agency Power
Cat or catless - ~less
Driving style (DD/heavy foot/so on) -Always in boost and sideways
Average time under boost per day - Driven only on weekends and when driven about 5 hrs.
Total cost (ball park) for turbo/install/tune - 13,000
Old Nov 24, 2008 | 01:26 PM
  #29
Brettus's Avatar
Boosted Kiwi
Make year of car (motor if changed) - 2003
Transmission type - MT 6
Average high and low temp in area of operation - -2 to 30 deg C
Altitude - sea level
Fuel grade - 98 (equivalent to US 93)
Oil type/grade - Pennzoil 5w-40 synthetic
Plug type/deg - 9 heatrange all round
Miles on motor before turbo - 101000 km
Miles with turbo -20000km
Blown motors - 2
Reason / what broke 1st time - apex seal - missfires suspect Mazsport coils on stock dwell
2nd time - apex seal (ran lean on high speed corner and low fuel - detonation.
Turbo kit - Greddy with cold side upgrade + custom cold air intake
PCM/ECU - Hymee Pro Tuner
Lowest PSI and highest PSI you run - 8psi - 12psi
Your normal operation PSI - 10psi
Shop tuned or self tuned - Self Tuned
Dyno'd HP/TQ (if you have) - 333hp at 10psi 281 lb/ft torque at 13psi
Fuel upgrades - blue injectors in P2 position yellow in P1
Cooling upgrades - Fitted extra radiator instead of 2nd oil cooler (it works)
Exhaust type or diameter - Trust TI catback - std midpipe with gutted cat 2.5"
Cat or catless - gutted
Driving style (DD/heavy foot/so on) - Not F&F tokyo drift more your give it stick when I see some open road . Do track the car
Average time under boost per day - not a lot normally
Total cost (ball park) for turbo/install/tune - nz$7500 $4000US
Love the extra power & low down torque .
Have set my shift beeper to 7700rpm so it is no longer a 9000rpm screamer which is good in some ways but not so in others .
Finding i get a bigger thrill taking short bursts to 6000-7000 in 2nd than I did taking it to 9000 .
Cant see any need for more power but that may change over time .
Old Apr 1, 2009 | 11:22 AM
  #30
Cattywampus's Avatar
Turbos blow!!
Average high and low temp in area of operation -average is 175-183
Altitude -no idea
Fuel grade -always 93
Oil type/grade -castrol 10w-30
Plug type/deg -NGK
Miles on motor before turbo -23k
Miles with turbo -3k
Blown motors -0
Turbo kit - GReddy
PCM/ECU -
Lowest PSI and highest PSI you run -5-8
Your normal operation PSI -5
Shop tuned or self tuned -MM Cobb AP
Fuel upgrades -
Cooling upgrades -
Exhaust type or diameter - Hymee 2.5
Cat or catless - Turbo XS 2.5 catless
Driving style (DD/heavy foot/so on) - moderate
Average time under boost per day - a few
Total cost (ball park) for turbo/install/tune -4k
Comments: I dont drive hard but I do use boost. I dont beat my car up but there are times I floor it to keep it running good. I hit the twisties once a month. My car is driven at the most 3 times a week. I love the boost and the tune is just like OEM. For a car this lite and the added hp makes it such a fun ride. After the catless midpipe the boost is much quicker and comes on around 2k. The boost default back to 5psi around 7600k rpm but I uually shift at that point so I hardly exp the drop. The boost will go up to about 9-10 just for the experience once I set up my boost controller. Right now it looks stock and no bov sounds makes it a great sleeper.
Old Jun 23, 2009 | 11:47 PM
  #31
angeljoelv's Avatar
angeljoelv
Make year of car (motor if changed) - 2004, 3 rotor swap
Transmission type - tremec t56, 6 speed
Average high and low temp in area of operation - 70-90
Altitude -
Fuel grade -93 / water methanol system
Oil type/grade - 20/50 Royal Purple
Plug type/deg - NGK Iridium
Miles on motor before turbo -50000
Miles with turbo -500
Blown motors -hurt a side seal once
Reason / what broke - detonation at a 25 psi peak
Turbo kit -Custom
PCM/ECU - Halteck E11V2
Lowest PSI and highest PSI you run - 8/ 20 I did a couple of higher psi passes but only testing
Shop tuned or self tuned - Friend tuned
Dyno'd HP/TQ (if you have) - not yet
Fuel upgrades - 2 044 bosch fuel pumps upgraded now to Electromotive A100
Cooling upgrades - custom aluminum radiator and 2 speed fan, Dual upgraded oil coolers comming soon
Exhaust type or diameter - 5" exhaust at turbo, down to 4" gpoing back
Cat or catless - nothing
Driving style (DD/heavy foot/so on) -Very heavy foot
Average time under boost per day - al the time
Total cost (ball park) for turbo/install/tune - A lot
I love it
Old Sep 4, 2009 | 04:20 PM
  #32
blackenedwings's Avatar
Life begins @ 30 psi
Make year of car (motor if changed) - 2005 Shinka
Average high and low temp in area of operation - 20F to 101F (MD weather is kind of random)
Altitude - 350ft Above Sea Level (smogtastic!)
Fuel grade - 93 octane
Oil type/grade - Castrol 5W20 & Idemitsu 2-stroke premix
Plug type/deg - Leading: NGK BURQEP, Trailing NGK RE9B-T, BHR Ignition System
Miles on motor before turbo - 31,000
Miles with turbo - 2,333
Blown motors - 0
Lowest PSI and highest PSI you run - 9 psi-11psi, still tuning
Your normal operation PSI - 9 psi
Shop tuned or self tuned - MazdaManiac tunes
Dyno'd HP/TQ (if you have) - 301-rwhp and 218 ft-lbs of torque @8.5psi (was dealing with a lot of MAF issues, the car drove like crap, it is MUCH better now)
Fuel upgrades - Machined yellow 650cc P2 injectors
Cooling upgrades - AEM water/meth injection, rad fans on earlier with AP tune, Seibon vented hood, Godspeed intercooler, Tsunami front bumper
Exhaust type or diameter - Racing Beat nonresonated catless midpipe, HKS Hi-Power single outlet catback (2.9" diameter)
Driving style (DD/heavy foot/so on) - DD with a heavy foot
Average time under boost per day - It's hard to say, 1/3rd or more
Total cost (ball park) for turbo/install/tune - The turbo kit with gauges and the MM upgrade was $4050, install and tuning was $2600 (had to fly Jeff out and pay for dyno) so $6650 just for these pieces not counting exhaust, meth kit, etc.
Personal comments about your setup. (likes/dislikes) This is basically the perfect car in my opinion now. It's light, beautiful, and very fast. It turns heads everywhere I go, and can hang with more powerful cars with pride. I can think of very few cars I would rather have. Now just time to raise the boost a bit and start on the interior!
Old Sep 23, 2009 | 11:56 AM
  #33
\\Konig\\'s Avatar
turrrbo!
Make year of car (motor if changed) -2005
Transmission type - 6 speed manual
Average high and low temp in area of operation - low 60 to high of 100
Altitude - sea level to...slightly above sea level
Fuel grade - 91
Oil type/grade - 5w-30 and 5w-25
Plug type/deg - stock
Miles on motor before turbo - 40,000
Miles with turbo - 35,000
Blown motors - none
Turbo kit - Used Greddy Turbo with AEM intake and HKS BOV
PCM/ECU - Cobb accessport with Mazdamaniac tune
Lowest PSI and highest PSI you run - 6 psi to 10psi
Your normal operation PSI - 6 psi
Shop tuned or self tuned - mazdamaniac tuned
Dyno'd HP/TQ (if you have) - dynoed: 255 whp, 198 torque
Fuel upgrades - BHR Ignition
Cooling upgrades - none
Exhaust type or diameter - HKS hi-power with racing beat non resonated midpipe
Cat or catless -catless
Driving style (DD/heavy foot/so on) - light throttle with occasional boosting
Average time under boost per day - 20% percent of each drive in boost
Total cost (ball park) for turbo/install/tune - parts: $3623 install: $700 (a friend) tune: bought accessport w/ Mazdamaniac service $695
i am very happy with my setup and i have not had any problems as of now.
Old Sep 28, 2009 | 01:51 AM
  #34
joepatterson's Avatar
2004 VR 6 SPD
Transmission type - 6 Manual / Racing Beat Alum Flywheel / ACT Street-Strip Clutch
Average high and low temp in area of operation - 30, 90
Altitude - 580 ft
Fuel grade - 93
Oil type/grade - 5-30 Royal Purple, Sohn OMP Adaptor w/ 2 cycle
Plug type/deg - NGK Iridium Racing / BHR Ignition Coil Upgrade
Miles on motor before turbo - 24,000
Miles with turbo - 30,000
Blown motors - 1
Reason / what broke - Apex seals - oil inection issue before recall
Turbo kit - GReddy
PCM/ECU - Cobb AP
Lowest PSI and highest PSI you run - 7 / 10
Your normal operation PSI - 7
Dyno'd HP/TQ (if you have) - Don't know yet
Fuel upgrades - 380 P1, 380 P2, 550 Secondary / CoolingMist Methanol Inection
Cooling upgrades - None
Exhaust type or diameter - Borla Catback
Driving style (DD/heavy foot/so on) - 10% lead foot
Average time under boost per day - come into boost very often
Total cost (ball park) for turbo/install/tune - 4,000
GReddy released kit WAY too soon. Had many problems.
Old Dec 5, 2009 | 08:52 PM
  #35
KrumbZ's Avatar
1.3L of Fury
Transmission type -6spd
Average high and low temp in area of operation -H 42f/ L 14f
Altitude -7,200 ft
Fuel grade -91
Oil type/grade -5w30/Idemitsu premix
Plug type/deg -stock NGK
Miles on motor before turbo -60k
Blown motors -none
Turbo kit -GReddy kit/modified
PCM/ECU -Cobb AccesPort
Lowest PSI and highest PSI you run -Low 3/ High 5
Your normal operation PSI -3
Fuel upgrades -stock
Cooling upgrades -stock
Exhaust type or diameter -GReddy SP2
Cat or catless -Catless Agency Power midpipe
Driving style (DD/heavy foot/so on) -DD
Average time under boost per day -??
Total cost (ball park) for turbo/install/tune -around $4,500
Old Jan 15, 2010 | 10:07 PM
  #36
monzue's Avatar
Persistance
Ben's Turbo Rx-8 Huntsville, AL
Make year of car - 2004 Mazda Rx-8 GT, 13B Renesis. Epi’s old car.
Transmission type - 6 Speed MT with Axial Flow Engineering Short Shifter
Average high and low temp in area of operation – 80-90ish summer 20-40ish winter
Altitude – 600 ft
Fuel grade – BP and Chevron 93 Octane.
Oil type/grade – Castrol GTX 20W-50. Mazsport Oil Metering Pump
I’m thinking I should switch to Castrol GTX 10W-40 for winter.
Plug type/deg – leading - NGK-5255 Trailing NGK-5255 + 2 washer shims
Miles on motor before turbo – 50,000 miles on car at engine rebuild.
Miles with turbo – 62,000 + so far...
Blown motors - 1.
Reason / what broke – Mazsport said that the fuel filter was clogged due to premixing
causing the engine to run lean, causing detonation, causing blown apex seals.
broke apex seals, 2 rotors, 3 side housings (taking Mazsport’s word at this..)
over $6000 repair bill.
Turbo kit - GReddy (T618z)
PCM/ECU – Mazsport Interceptor X
Electronics – Greddy Profec B Spec II Boost Controller
HKS Type-0 Turbo Timer
AEM UEGO Wide Band Air/Fuel pod .
Lowest PSI and highest PSI you run - 5 PSI - 8 PSI.
Your normal operation PSI - 7 PSI.
Shop tuned or self tuned - Shop Tuned Mazsport. Needs another tune. Any help?
Dyno'd HP/TQ Before Turbo - ?
Dyno'd HP/TQ With Turbo - ?.
Fuel upgrades - Mazsport fuel system and injector upgrade
Front and Rear Primary – High Impedance Injectors (12 ohm). Model #?
Front and rear Primary2 – High Impedance Injectors(13.2 ohm). Model?
Front and rear Secondary – Low Impedance (2 ohm) Model?
Cooling upgrades – Mazsport Cooling mod
Other - JDM Clear Corners, Yokohama S-drive Tires 245/40R18 all around.
Exhaust type or diameter - HKS Legamax Exhaust
Cat or catless - catless.
Driving style (DD/heavy foot) - Daily Driver, Calm...
Average time under boost per day – 20 min
Total cost for turbo/electronics/install/tune - About $ 10,000.
Old Mar 29, 2010 | 11:18 PM
  #37
BSchwemer's Avatar
Make year of car (motor if changed) - 2004 RX8
Transmission type - Stock 6 speed
Average high and low temp in area of operation - 20* - 90*
Altitude - 750ft above sea level
Oil type/grade - Castrol GTX 10w-40
Plug type/deg - RX-7 Trailings 9 heat range
Miles with turbo - 1,000 or so
Blown motors - 1
Reason / what broke - Failed coils, misfires, ruined seals?
Turbo kit - Custom
PCM/ECU - Stock/Cobb AP
Lowest PSI and highest PSI you run - 8 - 14
Fuel upgrades - 390 Primary, 780 Secondary, 840 P2, Walbro Pump
Cooling upgrades -
Exhaust type or diameter - Custom 3" turbo back
Driving style (DD/heavy foot/so on) - DD, Aggressive
Average time under boost per day - 30-50%
Total cost (ball park) for turbo/install/tune - Too much
Love it more every day. Hate the extra heat, but you learn to live with it and fix things that fail.
Old Mar 30, 2010 | 12:20 AM
  #38
PhantomRX-8's Avatar
Bad Ass
Make year of car (motor if changed) - 2007
Average high and low temp in area of operation - 40*-110*
Altitude - 550ft above sea level
Fuel grade - 93 octane with Torco Accelerant racing fuel additive ~97 octane
Oil type/grade - Royal Purple 5w-30
Plug type/deg - NGK 5255 leading, stock trailing
Miles on motor before turbo - 7000
Miles with turbo - 4,000 or so
Blown motors - 0
Turbo kit - Greddy, BNR turbo
Lowest PSI and highest PSI you run - 5 - 11
Shop tuned or self tuned - Personally tuned by MM
Dyno'd HP/TQ (if you have) - Not yet, waiting on new actuator
Fuel upgrades - 880 P2s
Cooling upgrades -
Exhaust type or diameter - Racing Beat Rev8
Cat or catless - Racing Beat DR catless
Driving style (DD/heavy foot/so on) - Babied with small sprints
Average time under boost per day - 10%, not a daily driver
Total cost (ball park) for turbo/install/tune - $8000+
Wish the car had a little more potential for power. My buddy has a 550whp Cobra that jaded me unfortunately.
Old Nov 12, 2010 | 12:54 PM
  #39
WildmanRacing's Avatar
04 Winning Blue in New Orleans
Make year of car (motor if changed) - Original Motor
Transmission type - 6-speed (original)--------------------------------------------------------------------------------
Average high and low temp in area of operation - 20 F - 100 F
Altitude - -5'
Fuel grade - 93 Octane
Oil type/grade - 20W50 Royal Purple
Plug type/deg - Stock
Blown motors - 0 so far
Reason / what broke - Blown the seals on the first Greddy Turbo.
Turbo kit - Greddy Modded
PCM/ECU - Access Port
Lowest PSI and highest PSI you run - 8psi - 10 psi (not enough fuel for above 10)
Your normal operation PSI - 10 psi
Fuel upgrades - None
Exhaust type or diameter - 3" Greddy
Cat or catless - Rodded out stock cat
Driving style (DD/heavy foot/so on) - Drive it like you stole it.
Average time under boost per day - 15-20 min.
Total cost (ball park) for turbo/install/tune - $6,000
Turbo make the Renesis run like it should have from the factory. Had to upgrade the iginition to LS7 coils to keep from blowing the stock ones. Recirc valve was a must (but not included in the Greddy kit). Water cooled turbo runs 100% better. Summit racing has some great formable, adhesive backed heat sheild that makes the install much cleaner.
Old Dec 1, 2010 | 12:35 PM
  #40
WantedTwo's Avatar
C4 burns real good
Make year of car (motor if changed) - 2004 MT
Transmission type - Stock with BHR Clutch and Flywheel
Average high and low temp in area of operation - 40 - 120
Altitude - 1000 ish?
Fuel grade - 91 (****)
Oil type/grade - Red Line 10W40
Miles on motor before turbo - Time line follows
14k GReddy kit
18k new motor, back to N/A
51k SFR kit
Miles with turbo - 3k
Blown motors - 1
Reason / what broke - Rear apex, Greddy kit with emanage blue in 2005... Nuff said
Turbo kit - Now SFR, then GReddy
PCM/ECU - AP
Lowest PSI and highest PSI you run - 6 - 9 Summer 9 - 12 winter
Shop tuned or self tuned - MM
Dyno'd HP/TQ (if you have) - Soon
Fuel upgrades - BHR Fuel pump upgrade, 800cc P2
Ignition - BHR
Cooling upgrades - BHR radiator, Meth kit, MazMart Thermo, Samco pipes, GReddy oil pan, MazMart water pump, GReddy radiator cap, water wetter
Exhaust type or diameter - 3" Racing Beat all the way back
Cat or catless - Catless non resonated mid-pipe
Driving style (DD/heavy foot/so on) - Drive it like I stole it
Average time under boost per day - 10% of driving time
Total cost (ball park) for turbo/install/tune - As the car sits - $23,417.55
Just for the stuff to give you the power I have - $12,947.95
wtf is wrong with me....
See build thread in sig.
Old Jan 20, 2011 | 11:02 AM
  #41
Eacrataes's Avatar
Average high and low temp in area of operation - High=100's Low=~0
Altitude - St. Louis, Missouri?
Fuel grade - 93
Oil type/grade - 20w-50
Plug type/deg - OEM
Miles on motor before turbo - 50,000
Miles with turbo - 61,000
Blown motors - 0
Turbo kit - greddy
PCM/ECU - CobbAP (sucks, stick with the emu)
Lowest PSI and highest PSI you run - High=5.5psi
Your normal operation PSI - I daily drive it, WOT about once a week if that.
Dyno'd HP/TQ (if you have) - ~200whp
Fuel upgrades - n/a
Cooling upgrades - n/a
Exhaust type or diameter - stock 2.5in
Driving style (DD/heavy foot/so on) - daily driver
Average time under boost per day - i get on the high way twice a day, probably then, but i'm usually eating.
Total cost (ball park) for turbo/install/tune - Turbo(1700) + Tune(600) + Install(Free) = 2300
On a side note, holy **** you guys spent alot of money putting your turbos on. I'm sure glad i didn't read this post before i decided to do mine this summer!
Old Feb 24, 2011 | 12:00 PM
  #42
Stroudism's Avatar
Got Boost?
Make year of car (motor if changed) - 2004 (had motor replaced in 2010, but not sure what year motor was
Average high and low temp in area of operation - high 90s / low 70s
Fuel grade - 93
Oil type/grade - Castrol GTX 20W50
Plug type/deg - NGK colder than stock, but forgot deg.
Miles on motor before turbo - 4k
Miles with turbo - ~500
Blown motors - 0
Turbo kit - Mazsport Type I kit with Precision T62
PCM/ECU - stock with Cobb AP
Lowest PSI and highest PSI you run - low: 6 high: 15
Your normal operation PSI - 14 for now
Shop tuned or self tuned - shop tuned
Dyno'd HP/TQ (if you have) - 295 / 262 (conservative tune)
Fuel upgrades - 780cc P2s, 255lp Wahlbro
Exhaust type or diameter - custom Magnaflow mufflers 3" pipe
Cat or catless - 3" Exoticspeed Midpipe
Driving style (DD/heavy foot/so on) - DD with itchy foot
Average time under boost per day - wkday: 10min wkend:
Total cost (ball park) for turbo/install/tune - $10k
Dislike: waiting for the car and turbo to warm up
Likes: blowing those stupid 350Zs away, and some of those big muscle cars, and anytime boost > 10 psi that feeling makes my nipples hard.
Old May 11, 2011 | 12:27 PM
  #43
RotaryMachineRx's Avatar
SPOOLN8
Transmission type - 6sp MT
Average high and low temp in area of operation - -5C to 35C (23F - 95F)
Altitude -
Fuel grade - 91 octane
Oil type/grade - Royal Purple 5w30
Plug type/deg - NGK BUR9EQP Leading
- NGK RE9BT Trailing
Miles on motor before turbo - 28 000miles
Miles with turbo - 15000miles
Blown motors - ZERO
Reason / what broke - NOTHING
Turbo kit - GReddy, Fix #2, VTA SSQV BOV
PCM/ECU - MM Cobb AP
Lowest PSI and highest PSI you run - 9psi
Your normal operation PSI - 9psi
Shop tuned or self tuned - MMCCS
Fuel upgrades - Deatschwerks DW200 255lph
Cooling upgrades - MM AP early Fan turn on, Vented Hood
Exhaust type or diameter - GReddy SE, BHR Resonated Midpipe
Driving style (DD/heavy foot/so on) - DD (medium heavy foot)
Average time under boost per day - 33.33333%
Total cost (ball park) for turbo/install/tune - $6500 (CAD)
Old May 11, 2011 | 01:52 PM
  #44
jtripp06's Avatar
Average high and low temp in area of operation - 66f
Altitude -
Oil type/grade - Royal Purple 10w30
Plug type/deg - Stock For now
Miles on motor before turbo - 2000miles
Miles with turbo - 2000miles
Blown motors - ZERO
Turbo kit - GReddy
Lowest PSI and highest PSI you run - 6.5psi
Your normal operation PSI - 6.5psi
Fuel upgrades - Walbro 255lph
Exhaust type or diameter - Agency Exhaust
Cat or catless - Agency Mid-Pipe
Total cost (ball park) for turbo/install/tune - 10k
Old Dec 3, 2011 | 08:05 PM
  #45
rx8 man's Avatar
NZ Remote Turbo Rx8
Transmission type - 6 MANUAL
Altitude - SEA
Fuel grade - 95 NZ (91? USA)
Oil type/grade - CASTROL
Plug type/deg - NGK BUR9QP
Miles with turbo -
Blown motors - YIP
Reason / what broke - WASTE GATE LINE/ COILS and off came the corner of a Apex Seal.
Turbo kit - REMOTE/MID MOUNT
PCM/ECU - PRO-TUNER
Your normal operation PSI - 8PSI
Shop tuned or self tuned - HARPER/ SELF
Dyno'd HP/TQ (if you have) - FIRST DYNO RUN -- 280 WHP
Fuel upgrades -NIL
Cooling upgrades -Extra (small radiator). Fan on Oil Cooler, Water meth Injecting based on Air temp and PSI
Cat or catless - CATLESS
Total cost (ball park) for turbo/install/tune -CHEAP
Old Dec 19, 2011 | 04:25 PM
  #46
TX
Make year of car (motor if changed) -2004-Pineapple Racing Ported 13B-MSP
Transmission type - OEM Aisen 6 Speed
Average high and low temp in area of operation - 71.55F High (Yeah right, maybe 3 months out of the year) / 58.03F Low
Altitude -701 ft Above Sea Level
Oil type/grade - Mobile1 0W-40
Plug type/deg/ignition -BUR9EQP - Leading / RE9BT - Trailing - BHR Ignition
Miles on motor before turbo - 0
Blown motors - None yet (3 blown in the preceding 127,000 NA)
Turbo kit - Greddy with fixes and Comp rebuilt with Comp billet wheel, water cooled and oil cooled CHRA, ported housings. Recirculating Synapse Diverter Valve, Grimmspeed BC, etc., etc.
PCM/ECU - Cobb Accessport Tuned by Kane
Lowest PSI and highest PSI you run - 7-8PSI so far
Your normal operation PSI - 6PSI so far
Shop tuned or self tuned - PPO2 performance (Kane) www.ppo2performance.com
Dyno'd HP/TQ (if you have) - TBD, still tuning (will edit later)
Fuel upgrades - BHR Fuel Pump, Blue P2's
Cooling upgrades - Mizu Aluminum Radiator, FAL fans & shroud, Mazmart Pump, Mazmart Thermo, Derale secondary with fan. Custom oil coolers/lines/oil thermostat.
Exhaust type or diameter - BHR 3" catless Midpipe and 3" Turbo XS catback
Driving style (DD/heavy foot/so on) - Heavy Foot
Average time under boost per day - TBD, still tuning (will edit later)
Total cost (ball park) for turbo/install/tune - $4,000.00 give or take minus engine.
Like: Being able to cruise uphill without flooring it, sounds, sweet smell of uncatted rotary, and all the pretty gauges.
Dislikes: Knowing that I will eventually blow my motor prematurely
Old Jan 2, 2012 | 07:01 AM
  #47
saskloppers's Avatar
sas
Make year of car (motor if changed) -2003- 13B-MSP Turbo
Transmission type - Aisen 6 Speed
Average high and low temp in area of operation 32 C High / 9 C Low
Altitude - Sea Level
Fuel grade - 95 Octane
Oil type/grade - Magnatec 5W-40
Miles on motor before turbo - 30000
Miles with turbo - ????
Blown motors - 1
Reason / what broke - Apex seal - too much boost
Turbo kit - Custom home built
PCM/ECU - Powermod
Lowest PSI and highest PSI you run - 5 to 25
Dyno'd HP/TQ See VBgarage
Fuel upgrades - Walbro fuel pump
Cooling upgrades - Koyo Sport Aluminum Radiator/
Exhaust type or diameter - 3" cat hand built
Average time under boost per day - Mostly under full boost
Total cost (ball park) for turbo/install/tune - $4,000.00 approx.
Like: Everything
Dislikes: Oil consumption
Old Jan 2, 2012 | 08:09 AM
  #48
wcs's Avatar
wcs
no agenda
ON
Average high and low temp in area of operation - 32c high / -15c Low
Altitude -1200 ft Above Sea Level
Oil type/grade - Pennzoil 10W-40, Mazmart Oil Pressure mod, Greddy Oil pan
Miles on motor before turbo - Unknown (estimate 20,000 miles)
Miles with turbo -under - 10,000 km's
Blown motors - None yet (Suspect 40,000 km's on nitrous has lowered compression)
Turbo kit - BNR T04e-60, water cooled and oil cooled CHRA, ported housings.
Lowest PSI and highest PSI you run - 4.5 low / 12.5 high
Your normal operation PSI - 4.5 psi in the Winter / 8 psi Summer
Shop tuned or self tuned - Self Tuned (MM Webinar x2, Kane mentored, Brettus support, BumblebeeRX8 support, FrazdaRX8 support)
Fuel upgrades - BHR Fuel Pump, Injectors Yellow/Yellow/Uncapped Yellow (flow tested at 800cc)
Cooling upgrades - BHR Aluminum Radiator, Mazmart Pump, Mazmart Thermo, RB Silicon Hoses, DEI Header Wrap
Exhaust type or diameter - Custom down pipe 3", catless Midpipe and RB exhaust (I hate the entire thing)
Driving style (DD/heavy foot/so on) - Binary the go peddle is either ON or Off
Average time under boost per day - 30%
Total cost (ball park) for turbo/install/tune - $4,000.00 give or take.
Like: The power, even at 4.5 psi the car is alive. It's the way mazda should have done it.
Dislikes: Current Turbo has considerably lag below 3.5k rpm. I honestly wish I could run a catalytic convertor but nothing seems to survive.
Old Jul 2, 2012 | 09:37 AM
  #49
Chris's Avatar
Turbo Member
Make year of car (motor if changed) - 04 (second motor)
Average high and low temp in area of operation - mid 90's
Altitude - 30 FT
Fuel grade - 93
Oil type/grade - Synthetic 10w30 Mobil1
Plug type/deg -
Miles on motor before turbo - 38k
Miles with turbo - 5k
Turbo kit - Greddy
Lowest PSI and highest PSI you run - 5 - 9
Fuel upgrades - Stock
Cooling upgrades - fan sensor kit
Exhaust type or diameter - BHR mid pipe, borla exhaust
Driving style (DD/heavy foot/so on) - weekend
Total cost (ball park) for turbo/install/tune - 4k
Old Aug 18, 2012 | 07:28 PM
  #50
yellowrx8cy's Avatar
Make year of car (motor if changed) -2004 second engine
Transmission type -manual
Average high and low temp in area of operation -40 celsius most of the time
Altitude -255 m above sea
Fuel grade -98 octanes
Oil type/grade -10w40 valvoline dura blend
Plug type/deg -
Miles on motor before turbo -60 k km,blowed after 7k
Miles with turbo -now 400 km with the new engine
Blown motors -1
Reason / what broke -apex seals
Turbo kit -greddy
PCM/ECU -stock
Lowest PSI and highest PSI you run -7-15
Your normal operation PSI -10
Shop tuned or self tuned -shop
Dyno'd HP/TQ (if you have) - 300 and something
Fuel upgrades -1000 cc rc injectors,walbro fue pump
Cooling upgrades -mazmart water pump
Exhaust type or diameter -FUJITSUBO LEGALIS R
Cat or catless -apexi super catalyzer cat
Driving style (DD/heavy foot/so on) -heavy foot
Average time under boost per day -all times
Total cost (ball park) for turbo/install/tune -5k euros
Thanks.[/quote]
