DIY: Fog Light Rewire
Old Aug 16, 2010 | 03:28 PM
  #426
BG-8's Avatar
sorry, looks like I missed the party...
THE ONLY WIRE THAT GETS CUT IN TWO IS THE BROWN
REMOVE ONLY SOME OF THE WIRE RUBBER INSULATION OF THE THICKER WHITE/RED STRIPE (DO NOT CUT IT IN TWO PIECES) TO MAKE GOOD CONNECTION BETWEEN THE BROWN AND WHITE/RED STRIPE WIRES IN THE WIRETAP.
Old Aug 16, 2010 | 03:32 PM
  #427
The Reverend's Avatar
That's a lie
just cut the brown
Old Aug 16, 2010 | 04:40 PM
  #428
Rotary-RX8's Avatar
Girls who drive stick FTW
Question ... I used to be able to turn on my hids and fogs even if the cars off. Now I'm only able to turn on my hids but not my fogs when the car iis off. is there any way to fix this ? I know this is stupid but I like everything to be "perfect" and I hate being able to turn on only my hids when the car is off.
Old Aug 16, 2010 | 04:59 PM
  #429
BG-8's Avatar
OK... the Fogs are wired to the ACC Relay. Which means you could only have power/electricity to the fog lights when you turn the key to ACC (turn the key once). You could wire the fogs differently so you have power all the time, even if the car is off, but there will be no beeper to warn you so you don't leave them ON (like the one for the headlights).
In my opinion, the best way is through the ACC Relay. Why would you need to turn them ON when the car is OFF? Plus you could still turn them ON if the car is OFF, just turn the key once to ACC and Voila...
Old Aug 16, 2010 | 07:21 PM
  #430
Rotary-RX8's Avatar
Yea but I wanted to be able to turn them on without the key veing turned at all. Oh well !! If you guys have it that way then I guess ill leave it.
Old Aug 16, 2010 | 08:57 PM
  #431
Rotary-RX8's Avatar
Just noticed something else. Before when my hids and fogs were on, and i use my high beams. The fogs would shut off everytime i flash my high beams. Now they stay on LOL. Just an observation.
Old Aug 16, 2010 | 11:30 PM
  #432
RX8Carnage's Avatar
Done earlier and very easy thanks guys.
Old Aug 18, 2010 | 06:59 PM
  #433
RotaryMachineRx's Avatar
SPOOLN8
So I went to do this mod and I don't have a brown wire going to my fogs relay or the Black and red wire going to the tail relay.... only difference I can think of is I'm in canada and DRL's are mandatory. Can anyone comment on this? I want my fogs to come on when I have the park lights on.
Old Aug 18, 2010 | 07:27 PM
  #434
SPOOLN8
Okay took a closer look, found the red/black wire going to the Tail FUSE not relay and I have a black/white wire going where the brown wire is located in MM's pictures but it is jumpered to the Head Low R fuse ... will the white/black wire be the same as the brown one (just cut it betweem the head fuse and fog relay) or do I need to do something different here? Here are some pictures....
Attached Thumbnails DIY: Fog Light Rewire-img_0170.jpg   DIY: Fog Light Rewire-img_0171.jpg   DIY: Fog Light Rewire-img_0173.jpg
Old Aug 18, 2010 | 07:47 PM
  #435
SPOOLN8
Well I'm gonna go ahead and try this out... I also couldnt find my heat shrink wrap so I'm gonna have to use good ole fashioned electrical tape until tomorrow when the stores are open again.
Edit: Found my shrink wrap!
Old Aug 18, 2010 | 09:03 PM
  #436
SPOOLN8
So I did this mod by soldering the black/white wire that was jumpered between the fog relay and Head Low R fuse to the black/red tail fuse wire. After reattaching everything the verdict is.... Nothing Happened. Does anyone have any insight on this? My fogs still turn on only with my headlights.
Old Aug 19, 2010 | 02:00 PM
  #437
Footman's Avatar
Dodging those Corollas
You Canadians are all forgetting an extra step that needs to be done in the DRL module. Doing that step will enable you to turn your fog lights on even when your engine is off. It will only require the key be in the ACC position to turn on fogs.
Old Aug 19, 2010 | 02:02 PM
  #438
Footman's Avatar
RotaryMachineRX, you pm'ed me about this...
https://www.rx8club.com/showthread.p...dian+fog+light
Here it is.. read it.
Old Aug 19, 2010 | 02:04 PM
  #439
Footman's Avatar
Guys... read my posts: https://www.rx8club.com/showthread.p...+light&page=13
Old Aug 19, 2010 | 02:05 PM
  #440
SPOOLN8
Thanks a ton Footman
Old Sep 22, 2010 | 10:40 AM
  #441
yenphi's Avatar
Hi, I don't have fog light for awhile now for some reason, today I replace new fog bulbs, re-connect the wire to original, check the relay fuse, fog fuse they are all good but, there still no light. Anybody has any idea why? with the car on running, I turn all lights and try to touch the bare BROWN wire to other wire and still no luck, thanks for any helpful hint.
Old Dec 3, 2010 | 01:26 PM
  #442
04blkRX8's Avatar
SR-71
Need some help!!
I was doing it Omicron's way.....ran the brown wire from the fogs to the thin red and white wire from ACC. When i crimped together with blue connector nothing happened. I tried just wrapping it, thinking I wasn't getting a good connection. Negative. The headlights appeared to be strobbing though. Any ideas. Thanks in advanced!!!
Old Jan 18, 2011 | 10:13 PM
  #443
Maui's Avatar
OK, I finally did this using the Omicron method (using the thing red and white wire). The only variation was that I used a T-tap on the white/red wire and male and female disconnects on the two ends of the brown wire, so that if I want to go back the way it was, I just have to unplug and plug.
Old Jan 23, 2011 | 04:19 PM
  #444
RogueTadhg's Avatar
Living is best Modified.
Did it Omicron's way. Mostly because it had what I wanted - the ability to have the fog lights on (or off) whenever I wanted.
Old Jan 27, 2011 | 11:56 AM
  #445
Ricky SE3P's Avatar
Project Seca
Thumbs up
just did this via omicrons method, works perfect! thanks!
Old Jun 8, 2011 | 08:44 PM
  #446
Rotary-RX8's Avatar
Sorry quick question. Im going to help my buddy do his foglight rewire. His 8 is Canadian. I was wondering if its the same wires you need to split ?? Or are they different colours. ??
thanks
Old Jun 8, 2011 | 09:04 PM
  #447
syntrix's Avatar
I like cheese!
thanks
Woah, stop right there! Get a fluke or a test light first!!!!!!!!!!
Check the voltages and go from there. A DIY is good for a lot of info, but maybe a canook can chime in. You never stated a year/options, etc, could be some unknown variations in the mix, never know.
Better safe than sorry!
Old Jun 8, 2011 | 09:25 PM
  #448
Rotary-RX8's Avatar
I didnt check my voltages when i did mine and ive done it like a year and a half ago. Everything is perfectly fine.
I just want to know if the wires that need to be tapped are the same colour or not. The car is a 04 but i dont think that makes a difference.
Old Jun 9, 2011 | 07:51 AM
  #449
SPOOLN8
Canadians Read Here: https://www.rx8club.com/canada-forum-35/canadian-foglight-rewire-90749/
Our Wire colors are not the same.... I believe ours is black/white rather than brown or something like that
Go Canucks
Old Jun 9, 2011 | 08:38 AM
  #450
Rotary-RX8's Avatar
So basically you connect the black/white wire (brown on US cars) to the red/black wire.
The black/white is the wire that gets cut correct?
