Car has a misfire
Car has a misfire
so pretty much im having a couple issues with my car. the big one after some trouble shooting is a misfire. but i dont have the tools or space to do this by myself so im going to have to take it in somewhere. anyone know a good place to take it around everett/seattle?? i dont mind a drive to take it somewhere reliable. but i obvoously want this problem fixed. so if anyone knows a place let me know
well first my check engine light was popping on and off. but when it happend it was t a high rpm i sounded like it was kind of struggling. and my buddy is good with this stuff so me and him went into it .. but he said it would take us about 4 hours if not more to figure out whats causing it. and the tools and space and time with my navy schedule.. i dont really have it. but we kinda came up with the misfire from the sound and the check engine light and such. let me konw if this helps. ill talk to him and see how he finalyl KNEW that it was a misfire
55k and yeah i shoudl probably change them anyway. ill look into it. i have been in cali a month so i have not been with my car =( had ot have the Gf drive it once a week because i dont like to let it sit
well usually thats the culprit, I would start there, doesnt take very long, I even think dozer wrote up a DIY for it.
then after you replace those reset your ecu by unplugging the battery for an hour+
dondo ill deff get back to you on that. i have a **** ton to do when i get back and i may be driving my car to missouri for my fam and friends to see. thats where im from. and i dont want these problems for the drive so i may just have to frok over the money =( but we will see.
btw maybe mid april or somethign i say indstead of dicks maybe hit hooters sometime?? mostly casue im craving wings ANd i mean roll into hotters with a bunch of 8's pft bring in the ladies!!!!!
My Other car's A Stryker
Buy a set of BHR coils and a new set of plugs. I did the drive from Lewis, to Ft. Sill, to Detroit last summer. It was a blast and I made sure everything was 100% before I left post.
55k definitely a good bet the plugs and coils should be swapped. If you use the OE coils again then check the wires as well. FWIW my car has 50k and the plugs and coils have been replaced twice. I plan to buy the BHR setup this year so the coils, plugs and wires will get swapped again.
Just pull the plugs and post a pic first. We will be able to tell if they are bad, which is what I believe is your culprit.
I had an aftermarket ignition for awhile, but it is really not needed if you stay normally aspirated. I am back on OE coils and she runs fine. But if you have plans for a blower or turbo, then by all means ignition will be very important.
dbarber
Jul 25, 2015 01:34 PM
Str8lineJKing
Jul 22, 2015 04:19 PM
