DIY: Spark Plug change.......
Old May 19, 2010 | 03:23 PM
  #276
rotarygrl04's Avatar
Originally Posted by Vlaze
I envy your hubby.
Hehehe
Old May 20, 2010 | 08:32 PM
  #277
Galaxy Gray's Avatar
Replaced the plugs and coils yesterday. Definitely had not been done before, and the car is at 60k miles. Plugs were disgusting and 3/4 of the coils had white marks on them. Car starts, idles, and runs much smoother now.
Old Jun 26, 2010 | 11:01 AM
  #278
dmp's Avatar
dmp
RX8 and a Truk....
Just a note to say thanks to the OP and the others who contributed - made the swap very easy - no surprises.
Old Jun 26, 2010 | 11:19 AM
  #279
laythor's Avatar
I zoom therefore I am.
awesome to hear.
There are few things as rewarding as working on your own car.
Old Jun 26, 2010 | 01:41 PM
  #280
dmp's Avatar
dmp
RX8 and a Truk....
Originally Posted by laythor
awesome to hear.
Oh - I hate working on my car!! Hate paying $90/hr for a guy who doesn't CARE about my car worse, however.
:D
:beers:
Old Jun 26, 2010 | 02:08 PM
  #281
Mazurfer's Avatar
Surf Hard, Drive Hard
awesome to hear.
Who are you.....................and what did you do with Laythor?
J/K
Old Jun 26, 2010 | 04:36 PM
  #282
laythor's Avatar
pfft.. i've done a lot of wrenching on my car. but i'm at the point in my life where my cost per hour is much higher then what i have to pay someone to do it for me.
the one thing i avoid like the plauge is running wires, i'm getting to old to do the "whole body twist" to reach some areas and besides, my audio installer has a very nice movie room to relax in while i wait
Old Jul 7, 2010 | 03:38 AM
  #283
jasonrxeight's Avatar
gosh, 15k ready for new plugs? rotaries not only eat oil but also eat plugs.
Old Jul 10, 2010 | 02:50 PM
  #284
77mjd's Avatar
How much anti seize should you be putting on the plug threads? Do you just lightly coat them or lather them up pretty good?
Old Jul 10, 2010 | 02:52 PM
  #285
invasion08's Avatar
you just need a little bit.
  #286
laythor's Avatar
a light coating. you dont need much at all
Old Jul 10, 2010 | 08:56 PM
  #287
cliffkemp's Avatar
All cars eat plugs when you rev them to 9k. just only so few do. my talon eats plugs as well. Most complain of eating plugs due to being 20 bucks a piece. NGKs in my talon are just 3 or so.
They dont eat oil either. They do use some depending on load and rpms. Of all the fussing I have heard about, most people dont realize that piston engines eat oil as well. They just do it more as the rings wear. They do eat oil between changes but they dont eat quite as much as the rotary due to design. Remember, the first rings on a piston are called oil control rings for a reason. they control oil residue to keep the cylinder walls lined with a slight coating to keep the rings from diggin in to the walls.
Changing out the plugs is fairly easy once you do it a few times. Just taking off the driver's side tire is the hard part really. I have changed out 5 sets of plugs on my car and do it in about 30 mins or so now. Piston engine owners are so lazy LOL
by the way, I change out my talon plugs every 10k miles or so. turbo has its advantages and disadvantages.
Old Jul 20, 2010 | 07:53 PM
  #288
ronx8's Avatar
zoom zoom!
what is the torque spec for tightening new ones on?
Old Jul 20, 2010 | 08:37 PM
  #289
VashGS's Avatar
Zoom Zoom Addict
114-156 in- lbf or roughly 10 f-lbf. Overtight can strip the housings I just use little motor oil on threads, wipe off excess and tighten little over finger. Never actually measured it
Old Jul 21, 2010 | 01:55 AM
  #290
ronx8's Avatar
zoom zoom!
so hand tight is fine?
i thought it would be a large amount of ft/lb due to the fact they can be difficult to remove.. i guess its cuz theyre more stuck on then tight on
Old Jul 21, 2010 | 02:01 AM
  #291
Jon316G's Avatar
Grasshopper
A little more than hand tight.
Once you get it hand tight, use the spark plug socket and give the plug another 1/4 - 1/2 turn.
Also remember to use anti-seize on the plug threads so its not so difficult to get out next time.
Old Jul 25, 2010 | 12:38 AM
  #292
ronx8's Avatar
zoom zoom!
gotcha. thanks.
got my BHR kit and it looks great.
Old Jul 25, 2010 | 11:15 PM
  #293
irishshindig's Avatar
what spark plugs are good?
DENSO ULTIMATE CLASS IRIDIUM RACING SPARK PLUG, are these good plugs for the rx-8? i found them on autopartswarehouse.com/ they are $51 each, so i was curious if they were worth the money?
Old Jul 26, 2010 | 06:20 AM
  #294
Huey52's Avatar
Registered Zoom Zoomer
Just stick with the NGK. Black Halo Racing here has a good deal at ~$80 for the set of four.
Old Sep 8, 2010 | 10:11 AM
  #295
the1jesster's Avatar
Trained true Killers
Well boys and girls I made it 75,000mi on the original plugs before they went on me two days ago, been premixing since she was born as well what ever that helps.
Thanks for thread helped out a bunch on my install today she runs great now
No 30,000 for me
Old Sep 9, 2010 | 06:30 PM
  #296
mark joy's Avatar
Exclamation rx7 plugs
Originally Posted by dcfc3s
Not in particular. Best is to find some way of disabling spark and fuel - probably pulling the ECU fuse or the like, then cranking the engine over for a second or so to blow all the fuel vapor out.
You have to be REALLY careful with this, as atomized fuel is VERY flammable. You have to be certain the spark is disabled, as the disconnected spark plugs could ground to something and ignite the fuel in the air.
Dale
I HAD A BOSS DO THAT & BURN HIS WIFE'S SUBARU TO THE GROUND. make sure u pull the wires away or off. I thought I lost an engine at 12,000+ revs the electrode melted off the leading plug & fouled the trailng plug. I switched to a four electrode set. MJ
Old Sep 10, 2010 | 04:51 AM
  #297
cas2themoe's Avatar
PoloRican Rotary
This may be a stupid/ignorant question, but are the plugs I purchased from Sparkplugs.com already gapped or do I have to do it still????
Old Sep 10, 2010 | 05:54 AM
  #298
Huey52's Avatar
^ they're already gapped, but it's always a good practice to double check.
Old Sep 10, 2010 | 12:29 PM
  #299
Well today I now have a missfire p0301 my coils are just as old 75,000mi I think this might be it but yesterday it ran fine now at 7grand it starts missfire could I have over tight my plugs? It took about three or four turns to hit the right spec on my wrench?
Old Sep 11, 2010 | 09:10 AM
  #300
skrubol's Avatar
Overtightening shouldn't cause misfires (though it may make it nearly impossible to get them out without stripping the threads.) I'd check all your connections.
