'swtich-blade' key on an 04?
Old May 18, 2022 | 05:49 AM
  #151
sonicsdaman's Avatar
The Blue Blur
I just re-programed a new switchblade last summer, my bet is that you are going to fast during the 3 seconds with the keys in the 'lock' position.
Old May 18, 2022 | 08:54 AM
  #152
StephZoom's Avatar
Thanks for your input. It’s funny, other posts were saying the opposite, it fails if you go too slow switching if being the 3 keys. I guess I’ll keep trying at different speeds in the off chance I get lucky
Old Jun 1, 2022 | 06:52 PM
  #153
StephZoom's Avatar
I concluded that the switchblade I got from eBay has a bad chip. I bought an actual key and it registered on the first try: https://www.ebay.com/itm/232772343368
So, I'm going to open that one up, take the RFID chip from it and move it to the switchblade. We'll see if that little surgery finally gives me a fully functional switchblade.
Old Jun 3, 2022 | 11:45 AM
  #154
StephZoom's Avatar
Well, that didn't work out at all! the chip is fully fused into the plastic handle and basically impossible to extract intact.
Old Jul 11, 2022 | 10:03 AM
  #155
TKJimmy's Avatar
Does the switchblade also include keyless entry/ignition?
Old Jul 12, 2022 | 08:46 AM
  #156
StephZoom's Avatar
Yes, it has everything. I ended up buying this one and both keyless entry and ignition worked great: https://www.ebay.com/itm/16510137337...mis&media=COPY
my mistake with the first attempt was to ignore that the model was not compatible with a 2004. The last one was and it worked fine. I programmed the chip with Forscan.
Old Jul 12, 2022 | 01:03 PM
  #157
TKJimmy's Avatar
Does that mean I need a programmer? Or would it just be easier to pay a stealership? I have a brother in-law who's a locksmith who's so insistent that aftermarket keys won't work for the keyless entry/ignition because of the proximity sensor so I was under the impression a switchblade key would only work for the key section.
Old Jul 13, 2022 | 09:23 AM
  #158
StephZoom's Avatar
No, you can do everything yourself. Read the early parts of this thread for instructions. I had the key cut at the Home Depot. They even did it for free since it brought my own key. Forscan is free software and optional, unless you only have one functional key left. Again, search this forum for instructions to program the chip either manually with 2 keys or with Forscan with only one valid key.
Old May 10, 2026 | 04:40 PM
  #159
Dani_Zetec's Avatar
My 04 came with two keys, the classic one and the switchblade but with just two buttons from the dealer.
I really like to get the switchblade with the button for opening the trunk but it's impossible to me to program it.
I've tried from Aliexpress ones to some used keys... Nothing. I can just reprogram the classic ones
Anyone had the same problems?
curly_ebhc
Jul 12, 2022 08:51 AM
Bail-Dawg
Apr 2, 2011 07:45 PM
thecrackhead
RX-8 Discussion
30
Jul 7, 2009 10:02 PM
ramathorne
Apr 13, 2007 11:34 AM
RX8driver
Dec 25, 2006 03:54 AM
