{ FS } Renesis Race Engine Package in Virginia
Old 08-06-2017, 07:13 AM
jwilless's Avatar
Category: Engine - Complete Motors
Price: $4900
Location (US State/Canada/Int): VA
$4000 – Almost everything you could want or need in a Renesis Race Package! Will not separate.
6 port motor freshly rebuilt by RP performance (0 hours) with all new Mazda OEM seals and gaskets. No engine oil or oil injection pump on this motor. It is set up as a dry sump motor with pre-mix fuel. I’ve swapped to a Peripheral Port motor on my Diasio 962R!
Moroso Dry sump 3 stage oil pump – 10 hours since rebuild – Stock filter pedestal & filter housing included if you prefer. Comes with 2 cog belts. Flat plate oil pan currently installed. High pressure oil bypass included depending on your use. Good for 10 GPM and 120 psi.
MicroTech ECU – includes ignition module and performance LS style coils, already tuned with a map to get about 260 HP at the flywheel. Complete wire harness included with relays and sensors. Programming Dongle and cable included.
AEM Wideband O2 – includes 3 - O2 sensors
Racing Beat Race Header – Coated with the White Lightning Swaintech exhaust Coating, Aluminum heat shield included. 3” V-clamp outlet
Intake – 2 with large throttle body, tuned injectors, custom airbox and air filter
Lots of extras with this package. All the hardware is there and it’s labeled. All the wires are labeled. There are lots of new extra gaskets, seals, injectors, water pump, stock coils, pick-ups, alternator with belts etc. You aren’t gonna find more Renesis engine stuff in one place. This would be great for a kit car or aircraft project
Pictures below
https://drive.google.com/open?id=0B4...y1rdnlTMFNIOTA
Contact Justin Willess at jwilless@itd-nc.com 540-230-9047 Located in Aldie, VA
Attached Thumbnails Renesis Race Engine Package in Virginia-20170528_153904.jpg   Renesis Race Engine Package in Virginia-20170528_153843.jpg
jwilless is offline
Old 09-04-2017, 06:17 AM
jwilless's Avatar
Price drop to $6k
Originally Posted by jwilless
$7k including shipping to Continental US– Almost everything you could want or need in a Renesis Race Package! Will not separate.
6 port motor freshly rebuilt by RP performance (0 hours) with all new Steel seals and gaskets. No engine oil or oil injection pump on this motor. It is set up as a dry sump motor with pre-mix fuel. I’ve swapped to a Peripheral Port motor on my Diasio 962R!
Pictures below
Price drop to $6k
jwilless is offline
Old 09-23-2017, 05:52 AM
jwilless's Avatar
Bump for fall
jwilless is offline
Old 09-26-2017, 02:43 PM
sa22rally's Avatar
what kind og port job is done to get 260 HP ?
sa22rally is offline
Old 09-26-2017, 06:07 PM
No respecter of malarkey
Received 2,012 Likes on 1,640 Posts
No porting is required to achieve up to around 270 hp @ flywheel. That's a function of it being built and tuned properly.
TeamRX8 is offline
Old 10-09-2017, 07:11 PM
jwilless's Avatar
$5999
$5999
jwilless is offline
Old 12-18-2017, 06:58 AM
jwilless's Avatar
Price drop to $4999
Price Drop to $4999
$5999
jwilless is offline
Old 12-18-2017, 03:38 PM
sa22rally's Avatar
Could you get a quote on shipping to Denmark? Maybe email me a complete price? Rmautosport@live.dk
Old 04-16-2018, 06:45 AM
jwilless's Avatar
Price Drop $4900!
jwilless is offline
Old 05-28-2018, 07:43 PM
jwilless's Avatar
Price drop $4600
jwilless is offline
Old 06-02-2018, 01:09 PM
jwilless's Avatar
$4k + shipping
jwilless is offline
Old 06-09-2018, 09:52 PM
lusuana katooloo's Avatar
Motor
i live in Virginia, will pick up for 4K cash
call me at 8048554341, left you a voicemail and sent an email.
lusuana katooloo is offline
jwilless
MW For Sale/Wanted
10-12-2019 01:13 PM
jwilless
NE For Sale/Wanted
07-30-2017 05:25 AM
jwilless
SE For Sale/Wanted
07-30-2017 05:23 AM
jwilless
NE For Sale/Wanted
07-28-2017 05:50 PM
20b-3rotor
03-17-2015 08:22 AM
Quick Reply: { FS } Renesis Race Engine Package in Virginia
