My ongoing LED conversion...
Old 03-30-2007, 04:15 PM
  #76
One ball, corner pocket
kwescott's Avatar
looks like a battleship board. G-7.....Hit.
Old 03-30-2007, 04:23 PM
  #77
BoosTED's Avatar
Interesting approach; that should look great when lit.
Is the plan to have the center light up when the brakes are pressed?
You could do every other along the circles to light up when the brakes are pressed.
Old 03-30-2007, 04:35 PM
  #78
NgoRX8's Avatar
awesome!
Old 03-30-2007, 04:52 PM
  #79
503wtq Boosted Bimmer
Rotary Rasp's Avatar
Attached Thumbnails My ongoing LED conversion...-dscn2721.jpg   My ongoing LED conversion...-dscn2723.jpg   My ongoing LED conversion...-dscn2722.jpg   My ongoing LED conversion...-dscn2724.jpg
Old 03-30-2007, 05:11 PM
  #80
wow, thats sick!
Old 03-30-2007, 09:10 PM
  #81
Second try:
The first one wasn't perfectly round.
Attached Thumbnails My ongoing LED conversion...-dscn2728.jpg   My ongoing LED conversion...-dscn2729.jpg
Old 03-30-2007, 09:19 PM
  #82
Easy_E1's Avatar
Looks like a "Lite-Brite" set. J/K I would love to make a Rotary shaped one for the rear accent. Wow,, I just had a brain storm,,Gotta go.
Looks good! RR
Old 03-31-2007, 02:19 AM
  #83
Brake ^
Running light^
Running light ^
Brake ^
This is the back of the second circuit board.
Attached Thumbnails My ongoing LED conversion...-dscn2735.jpg   My ongoing LED conversion...-dscn2737.jpg   My ongoing LED conversion...-dscn2741.jpg   My ongoing LED conversion...-dscn2743.jpg   My ongoing LED conversion...-dscn2744.jpg
Old 03-31-2007, 02:24 AM
  #84
NgoRX8's Avatar
wow.... FREAKIN AWESOME Rodger! the small LEDs make it look very clean.
Old 03-31-2007, 11:32 AM
  #85
BoosTED's Avatar
Almost looks like it is in afterburn when lit up full. :eyecrazy:
Looks great!
Do you have a pic of it off?
Old 03-31-2007, 04:25 PM
  #86
X e p i A
Aipex8's Avatar
Looks really good, RR, can we have a pic of what the LEDs look like in the housing when off?
Old 03-31-2007, 04:49 PM
  #87
^yea, i'll take one once I get the plastic that i'm going to use to cove the pcb holes.
I can't believe how close it looks to your photoshop.
Old 03-31-2007, 10:57 PM
  #88
BoosTED's Avatar
I can't believe how bright it is when fully on!
It looks like it is on fire!
Old 04-01-2007, 02:27 AM
  #89
I wasn't able get the plastic today so I did dome light in the meantime.
Just so eveyone knows, my camera doesn't do these leds justice. The contrast between the leds and the background is so high that it makes the leds just look like a big blob of light. They look 1000 times better in person.
Attached Thumbnails My ongoing LED conversion...-dscn2747.jpg   My ongoing LED conversion...-dscn2746.jpg   My ongoing LED conversion...-dscn2745.jpg
Old 04-01-2007, 03:31 AM
  #90
Received 2,648 Likes on 1,896 Posts
Damn Rodger, this is looking really good!
Old 04-01-2007, 08:04 AM
  #91
resU deretsigeR
jstkilntim's Avatar
I need more time!!
Old 04-01-2007, 08:12 PM
  #92
Major thanks to g3tr3ddy for the donation of the dome light.
Old 04-02-2007, 06:47 PM
  #93
I used some gloss black formica as a bezel for the led array. I'll take some shots of it inside the housing when I get home tonight.
Attached Thumbnails My ongoing LED conversion...-dscn2752.jpg   My ongoing LED conversion...-dscn2753.jpg   My ongoing LED conversion...-dscn2750.jpg
Old 04-02-2007, 06:59 PM
  #94
I'm sooooo jealous.
Old 04-03-2007, 12:24 AM
  #95
Here are two pictures with the leds off.
Leds on:
Attached Thumbnails My ongoing LED conversion...-dscn2756.jpg   My ongoing LED conversion...-dscn2757.jpg   My ongoing LED conversion...-dscn2755.jpg   My ongoing LED conversion...-dscn2758.jpg   My ongoing LED conversion...-dscn2760.jpg
Old 04-03-2007, 12:26 AM
  #96
NgoRX8's Avatar
DAMNNN! that looks insane! got any further away pics with the lights off?
i gotta see this in person.
Old 04-03-2007, 12:31 AM
  #97
Two more with leds off:
Flash:
No Flash:
Attached Thumbnails My ongoing LED conversion...-dscn2764.jpg   My ongoing LED conversion...-dscn2766.jpg
Old 04-03-2007, 10:56 AM
  #98
Electronic Check Valve?
Does such a thing exist?
I'm having a problem, maybe someone here can help me.
The white arrow is the ground.
The red arrow is the out led ring. (12 leds)
The green arrow is the inner ring. (8 leds)
I want to power the outer ring through the resistor (100 ohms) to act as running lights. When the brake is pressed, I want both rings to light up without the resistor. The issue I'm having is the wire used for the brake is connecting to both rings. This is causing power from the outer ring to back flow and light the inner ring when the running lights are on.
How can I stop the power from back feeding into inner led array?
thanks for you help
Old 04-03-2007, 11:40 AM
  #99
kwescott's Avatar
wow rodger, looks cool with that plastic piece added.....would be perfect to "color" match in doing some more lights in the future. Imagine, a white plastic peice for white 8's, WB plastic....wow, would look really nice.
I see business opportunity here if your up for it.
Old 04-03-2007, 06:24 PM
  #100
elf
What pointy ears?
elf's Avatar
It's called a diode. It allows current to flow in only one direction. The 1n400X (where X is 1 through 9) series of diodes should work for your application, if the forward current is no more than 1A. Radio Shack carries them.
Quick Reply: My ongoing LED conversion...
