Will funky wiring with Bazooka fry head unit?
Old Sep 27, 2006 | 02:22 AM
punanicheng's Avatar
With the great installation pictures posted by members I was able to install a Bazooka subwoofer into my car, however... I got confused at the stage of wiring the signal given that I have an 06 with Bose stereo and went trailblazing instead.
I didn't use a LOC even though every thread I read seemed to suggests this (plus I still don't understand what it does and why it needs to be installed). Instead I took a 2 lead RCA cable and cut in half. I used the open wire end to tap into the pre-amp signal of the rear right speaker. What ended up happening is that with only one RCA plugged into the Bazooka the whole sub system seemed to respond fine. What I don't understand is that it only works if I plug in the RCA HALF WAY. In other words, if I have the whole RCA plugged in the sub doesn't recieve signal.
Is this setup kosher or am I totally screwing with my head unit?
Well atleast the system sounds good!
Thanks for the input!!!
Old Sep 27, 2006 | 10:29 AM
jstkilntim's Avatar
resU deretsigeR
It sounds like you have one of your + & - switched.
Old Sep 28, 2006 | 04:53 AM
Do I have to adjust this or can I leave it as such?
Old Sep 28, 2006 | 06:40 AM
jstkilntim's Avatar
resU deretsigeR
Something is definitely wrong & you need to fix it. Verify you have both positives & negatives correct. It sounds like one of them is backwards.
RXFEVER
Aug 29, 2018 10:14 AM
RenzoRx-8
Sep 9, 2015 02:38 PM
mattymack
Sep 6, 2015 10:33 PM
iwannarun
Sep 6, 2015 01:37 PM
