anyone have one of these? do they work?
Old Sep 24, 2006 | 10:56 AM
davidwanj's Avatar
http://cgi.ebay.com/ebaymotors/SAVE-...32514569QQrdZ1
I have one just wondering if it work, but never bother putting it on, wondering if any of you guys have tried it, 31% seems like a huge different..........
Old Sep 24, 2006 | 11:00 AM
Mugatu's Avatar
Even My Dog Searches
you dont have one of these? we ALL have these on our cars.
Old Sep 24, 2006 | 11:01 AM
davidwanj's Avatar
well....anyone else beside mugatu then?
Old Sep 24, 2006 | 11:04 AM
TQ025's Avatar
My rotors are dizzy
I believe this was sarcasm... It's been covered before on here that this and the tornado don't do what they say especially with our cars... (can't remember why) but it made it worse off.
Old Sep 24, 2006 | 11:06 AM
otherside's Avatar
I dont care...
"Don't be fooled by imitations", just be fooled by ours!
Looks like a crushed beer can....
Old Sep 24, 2006 | 12:52 PM
kartweb's Avatar
It will do nothing positive for performance. Might even screw up idle.
Old Sep 24, 2006 | 12:57 PM
MAF will be really happy having that thing near it. It already freaks out over the smallest amount of turbulence Good Luck!
Old Sep 24, 2006 | 04:20 PM
ken-x8's Avatar
I am astounded that people can advertise and sell junk like that. Where are the state Attorney Generals when we need them?
At best, it will reduce the weight of your wallet, and that might translate into better performance.
Ken
Old Sep 24, 2006 | 04:24 PM
toxin440's Avatar
if you buy two and stack them on top of each other you get 62% increase...
Old Sep 24, 2006 | 05:01 PM
turbonator is much better... mo power..
Old Sep 24, 2006 | 05:12 PM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
KIT had one of these so did the Dukes of Hazard.
That's why they where so L88T.
(I'm sorry but, no these do NOT work. There will either be no change or you will lower you mpg. Also, you are risking that a piece of cheap poorly made metal will brake off a ruin your engine. Such damage would NOT be covered by your warranty. Even if something else should brake off in your air intake and damage your engine they could blame it on this a void your warranty. Avoid at all costs.)
(Nothing cheap will give you MPG or HP / Torque. If they could car companies would just stick em in their cars, up their numbers, and sell more cars. To end an overly long post.... snake oil my friend, snake oil)
Old Sep 24, 2006 | 09:47 PM
beachdog's Avatar
Truth. A while back, Popular Mechanics bought a bunch of these devices and one of them was made from stamped recycled metal like an old band-aid box. They called off the test for fear of the thing breaking and getting ingested by the engine.
Old Sep 24, 2006 | 11:03 PM
rx8dude907's Avatar
but if it dosent work then why does the seller have very good feedback
Old Sep 24, 2006 | 11:46 PM
ken-x8's Avatar
I'd guess that he ships stuff promptly and does the billing correctly.
He's also got other products.
Old Sep 25, 2006 | 12:58 AM
rx8dude907's Avatar
http://feedback.ebay.com/ebaymotors/...&iid=-1&de=off
Old Sep 25, 2006 | 12:59 AM
zenmoused's Avatar
the stig is my hero
I have 2 of these on my car, and it increases my milage to 30 mpg and gives me 30 extra hp! Seriously, buy at least two of these and put them in your car ASAP!
Old Sep 25, 2006 | 01:26 AM
flomulgator's Avatar
put one in your exhaust too!
Old Sep 25, 2006 | 05:13 PM
beachdog's Avatar
ebay buyers fear being flamed by bogus sellers and either give neutral feedback or no feedback at all. Just look how nasty the seller gets when someone files a negative feedback.
Old Sep 25, 2006 | 07:57 PM
rx8dude907's Avatar
the funny thing is that in the feedback some say it helped and they felt the improvement.
Old Sep 25, 2006 | 09:28 PM
but if it doesn't work then why does the seller have very good feedback
It's actually pretty easy to get lots of good reviews. The only cost is the ebay listing.
Never trust good responses on ebay. They should be there BUT what you really want to look for is the BAD responses.
Also, check out what it's he bought by looking at what feed back he left.
There is a LOT of ebay fraud out there.
Old Sep 26, 2006 | 05:04 AM
BoosTED's Avatar
Nope they don't improve anything.
Quite a few have increased mpg numbers with the Revi intake though. Have other intakes had that effect?
Old Sep 26, 2006 | 06:27 AM
turbine's Avatar
4th Year runnin
Funny thing about this item. I had the Typhoone Type one intake. I mounted a turbonator in the very front of the aluminum neck. It did help that system. I took it out and it ran worse. That led me to change out the intake totally. The MAF did better with it on the Typhoon type one. I first started decreasing the pitch on the blades gradually, until I just removed it. The less pitch the better, but all the way out the MAF went crazy. My hypothesis was the incoming air was in wrong form due to the filter design. I changed the wide body filter with a inverted cone filter. A closer design to the Type 2. Instead of the air rushing in from the sides converging into the neck was a bad design. The air needs be more controlled, focused more from the center, than the sides. This made a huge difference. The turbonator was actually helping the Typhoone one design. It was drafting down the turbulances before the MAF, even though it was causing some drag.
In some cases the turbonator will help. In some cases it will not. If the intake system is a good design then it will not work. If it is a bad design then it will.
I put one on my 1999 Land Rover. The gas mileage jumped 3 to 4 up. It has a bad intake design.
The RX-8 has a straight shot, with no bends. The cars with turns and bends in the intake will probably see some benifit. That Land Rover sure did.
Old Sep 26, 2006 | 06:48 AM
The Ace's Avatar
Greek Power
Originally Posted by turbine
Funny thing about this item. I had the Typhoone Type one intake. I mounted a turbonator in the very front of the aluminum neck......The RX-8 has a straight shot, with no bends. The cars with turns and bends in the intake will probably see some benifit. That Land Rover sure did.
If the aftermarket filter/intake is badly designed, then *maybe* this stupid thing can help only because it will alleviate the turbulence created by the intake (i.e. it will try to correct something wrong), which is NOT what it claims. So, no gains here.
If the filter/intake are correctly designed, then this thing will f@ck up your intake, throw your MAF waaaaayyy into a fit, and generally make your car run like ****. Not to mention that it might actually be dangerous for your engine.
A couple of decent -at the least- mechanics, which were not biased, bought a few of these ebay "power mods", tested them, and found them to be -at best- of little or no help at all. Some of them -like this one here- were dangerous. I have had a personal experience with one of these products, and I can assure you they ARE indeed dangerous
That's all the info/proof I need.
Old Sep 26, 2006 | 09:13 AM
h-khunterkiller's Avatar
for hire
i have a 1st k&n filter and i bought the craponator i put that thing in front and back of the MAF it did nothing positive a gave me a CEL, idle, pourly and had all kinds of jumps on the acceleration curve. in other words it suck @$$. so i left a neutral feedback cause the guy did not invent the product but delivery was fast, he wrote back to me a neutral and complaint about my thougths on it.
Old Sep 26, 2006 | 09:26 AM
silverwolf's Avatar
only thing you may see that looks bad but isnt... is the grounding kits. they actually help sound quality and some even say that it really does help your computer work better. no proof on that one. but the audio is a definate. i have 2 amps and i never heard a clearer hit on my subs or a clearer more constant treble than after this. cheap 2 like 30 bucks.
