Im Getting Traction Control Turning On Out Of No Where
Old Sep 19, 2006 | 04:37 PM
kngfmsta's Avatar
Exclamation Im Getting Traction Control Turning On Out Of No Where
For some reasen after i drive my car semi hard, or sometimes when i just take it past 4 it will cut off the power to the rear wheels and my acceleration doesnt work. The car starts to slow down due to the acceleration being cut off. while its doing this the traction control light will turn on(the same one that turns on when your taking a turn to fast and it stops the wheels from spinning out). the only way for me to get around this and kep driving is by turning the dsc off(thats traction control right?). If i dont turn it i can down shift and it will give me power again, but then it will light up me gauges with all kinds of differnt lights. The traction controll light turns on the brake light turns on, and i think the dsc too. My only mod is borla catback exhaust.
if you know what i need to do to fix this plz tell me. Thanks everyone
Old Sep 19, 2006 | 04:44 PM
Georgia8er's Avatar
Checking to see if there are any codes stored would be a good start. It almost sounds like a sensor problem to me, possibly one wheel is reading incorrectly.
Old Sep 19, 2006 | 10:48 PM
Easy_E1's Avatar
To the dealer with ya laddy,,,i assume you have some warranty left ? Right?
Old Sep 19, 2006 | 11:26 PM
kngfmsta's Avatar
yah they have just extended my warinty to 60 thousand miles and i only got 33 thousand. also i forgot to mension that the abs light turns on
Old Sep 20, 2006 | 03:03 PM
Ericok's Avatar
Rotary Wanker
You said: "i forgot to mension that the abs light turns on"
The ABS system provides input to the traction control. The ABS sensors tell the computer what the wheels are doing and the traction control (or ABS) makes adjustments if necessary. Something's wrong with your ABS sensors or the ABS electronics and that's affecting the response from the traction control system.
The extended warranty covers the "drivetrain". Depending on how generous Mazda is with their intrepretation, the ABS/Traction Control might not be covered past 40,000 miles.
JimmyBlack
273
Feb 10, 2020 10:23 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
yankeepicker
Sep 11, 2015 05:42 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
