ksport coilvers ??
Old Sep 19, 2006 | 01:02 AM
Kel Rx8's Avatar
if your not 1st your last
ksport coilvers ??
anyone heard or know of this brand ?
Old Sep 19, 2006 | 01:06 AM
Kel Rx8's Avatar
Ksport Kontrol Pro
Key Features:
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Spring Rates (kg/mm,lbs/in): Front 10/560 - Rear 5/280
Old Sep 19, 2006 | 02:25 AM
NgoRX8's Avatar
ask Razz
Old Sep 19, 2006 | 10:53 AM
Kel Rx8's Avatar
thanks bro
I did a rookie move and didnt search im try some other brand
thanxs
Old Sep 19, 2006 | 05:38 PM
dam, what a rookie..hahahha
Old Sep 19, 2006 | 05:54 PM
mac11's Avatar
Rotary , eh?
see them for my tiburon. A few tib owners I know have them. They like them. Tiburon owners in general dont know what good parts are though so i will not attest to any merits of these. Only that I have heard of them.
Old Sep 23, 2006 | 08:20 PM
PhotoMunkey's Avatar
I have installed these on my RX-8... Spring rates are 10 kg/mm front and 8 kg/mm rear. I was afraid they'd be too stiff but the valving on the shocks is EXCELLENT! I specified the higher rate (wanted 7 kg/mm but they only had the 8 available). I initially went with 2 turns up from full soft in the front, and 2 turns up from full soft in the rear (maximum is 4 turns front or rear). Two turns is, IMHO, just a little too stiff for the street, but when the freeway got smooth, like a track, the control was fantastic!
Nick at K-Sport (Autoline Industries in Phoenix, AZ) was helpful and knowledgeable about his product when I called with questions. I may try the 5 kg/mm spring at a later point if I decide I want more rear grip. They've chosen these rates because they don't make anti-sway bars, so in typical race car fashion all of the body control is done with the spring rate. Whatever. It works...
I'm making no claims at this point about overall durability, but they looked and felt very solid (comparable to Zeal Function in fit and finish) with quality locking rings and nice machining. No loose fitting threads like some extremely cheap kits I've seen. Supplied with 4 adjustment ***** so you can leave them in place if you like. The fronts can be adjusted (barely) with the OEM strut bar in the car, the rears, of course, cannot be.
After I finish settling the suspension (loosening and tightening the control arm bolts I'll reset the ride height (I think I need to go a little lower both front and rear) and shoot some photos. I'm very happy so far though!
BTW-the picture shown above is NOT for the RX-8. Both front and rear are substantially different.
Old Sep 23, 2006 | 09:03 PM
hamsta's Avatar
how low can it be drop?
Old Sep 25, 2006 | 02:36 AM
TerenceC's Avatar
Hi PhotoMunkey,
Does yours comes with rear top mounts? I just received mine and doesn't come with rear top mount. Their website clearly stated that it comes with front and rear top mounts. I know I can use the factory mounts but 1 of the reason I get this coilover rather than tokico and RB springs is I can swap the whole assembly easily. I guess I have to buy an extra sets of rear top mounts from the dealer(I hope they are not ridiculusly expensive).
Also how do you know if you have the 8k springs? I don't see any label or markings on the springs itself.
Please post some pics of the coilover if you have some.
thanks,
Terence
Old Sep 25, 2006 | 12:30 PM
It doesn't come with the rear top mounts. They have to be removed from the stock assemblies, which really doesn't take long to do. You do need spring compressors to do it though.
I have some photos, but they're going into S3 magazine as soon as I can get the story done comparing Eibach springs/stock shocks to the K-Sport package (basic coil-overs). They're paying for the story so they get first dibs on the photos.
Eric
Old Sep 26, 2006 | 07:48 AM
auzoom's Avatar
Hmmmmmm.........
PhotoMunkey,
Are you saying its not possible to adjust the rears at all?
Cheers
Andrew
Old Sep 26, 2006 | 10:59 AM
NgoRX8's Avatar
im pretty sure you should be able to adjust them before putting them in place... if they cant at least be adjusted then that sucks.
Old Sep 26, 2006 | 08:41 PM
auzoom's Avatar
Hmmmmmm.........
Well I looked further and am pretty sure they are adjustable rears, but I think what he is saying is that once they are on its impossible to adjust them becuase you cant get to them. If thats the case then I cant believe they haven't made a tool yet to allow you to adjust them. I know at least one manufacturer that has and I wouldnt be buying adjustable coilovers that dont let me adjust them once installed.
Old Oct 5, 2006 | 03:12 PM
You can't get a tool into the strut cavity when they're installed. The shock would have to be an inverted mount design, or have an attached adjustment cable like the Teins do. That's the only way. I can live with it this way because once they're set, how often do you really need to adjust them?
Old Oct 5, 2006 | 04:01 PM
auzoom's Avatar
Hmmmmmm.........
Every time you go from the street to the track. Why else would you need adjustable struts?
Old Oct 5, 2006 | 04:52 PM
no dice's Avatar
I bomb atomically
They sell an extension that connects to the rears so you dont have to remove all the trunk lining to get to it..
Old Oct 6, 2006 | 05:20 PM
K-Sport does? I thought only Tein did?
Dan@Assaultech
AssaulTech
285
Jul 30, 2013 07:02 PM
Turblown
Jul 26, 2010 07:51 PM
Transporter_GW
13
Apr 9, 2008 12:04 AM
