track problems...?!?
Old Sep 17, 2006 | 09:08 PM
contender's Avatar
hi, i was doing my first solo1 at a local karting track and even though it was a good experience i had a lot of trouble with the TCS or fuel cut...
first off i have an 05 gt 6spd rx8 with Racing beat sway bars, REVi intake, Agency Power exhaust (stock midpipe), Mazdaspeed springs, 265/35/18R 245/40/18F tires on 8.5 and 9.5 wheels...no TPMS
the car behaved really well better than i expected but i had this weird cut off like a fuel cut in every sharp turn and also in the straightaway i tried to run it with the DSC on and also off but it didn't make any difference the car just shut down and the throttle went blank, it was dangerous and also worrying i tried searching and found something about disabling the TSC completely by pressing the DSC button for 7+ seconds and i didn't knew that but none of the problems explained by the members seemed to be the same as mine... the car had a 1/2 tank of fuel so it couldn't be fuel and the oil level was Full...
if there's a thread about the same problems just link and i'm sorry but i couldn't get anything while searching...
thanks in advance...
Old Sep 17, 2006 | 09:15 PM
You were probably running out of fuel. In high G turns you need AT LEAST 1/3 tank to be sure you will have no problems
You might also have a poor fuel pump if it is happening at higher fill levels
ask me how I know
Old Sep 17, 2006 | 09:54 PM
contender's Avatar
i had 1/2 a tank of fuel which actually is more than 1/3
Old Sep 17, 2006 | 10:46 PM
When mine was doing it in High G left turns......It would do it with 3/4 tank. I added a second pump...and replaced the OEM pump. When I use the new OEM pump alone it is OK to almost a 1/4 tank...so it tells me the OEM pump wasn't working...despite the dealer telling me it tested OK
I have a switch for the second pump and run it at the track. Since then I have had no fuel related problems.
On another note...if you have a failing coil you will trip a lot of missfire codes 0300 series....
Old Sep 17, 2006 | 10:58 PM
It's the DSC switch. Happens all the time if you don't hold it long enough.
Old Sep 18, 2006 | 07:38 AM
yiksing's Avatar
the giant tastetickles
Hold that switch for 7+ seconds.
Old Sep 18, 2006 | 09:02 PM
contender's Avatar
ok, i get that if i hold it for 7+ secs i disable the whole system but why does this happen only on the track and not when i drift on the street???
Old Sep 18, 2006 | 10:15 PM
BlueRenesis82's Avatar
Registered Tracker
I had sympathy for you, but now that you mentioned drifting on the street I would reccomend you sell your car and die in a fire
Old Sep 18, 2006 | 11:10 PM
NotAPreppie's Avatar
What am I doing here?
BR82, don't hold back. Tell us how you really feel.
Old Sep 19, 2006 | 12:15 AM
PedalFaster's Avatar
Old Sep 19, 2006 | 12:21 AM
contender's Avatar
it's not street drfting actually i dont like drifting as a "sport" i find it stupid
what i meant to say is that it didn't happen when you took off a turn or any stop and you loose traction(drift), it didn't even happen to me one day that we took the car to the dragstrip...
Old Sep 19, 2006 | 06:46 AM
Imp's Avatar
Imp
What's next?
Drifting is controlled understeer. If you're getting understeer from a stop, you have biiiig problems.
--kC
Old Sep 19, 2006 | 07:25 AM
contender's Avatar
it's actually done purposedly but anyways let's get back to topic... and btw: drifting is controlled OVERSTEER...
Old Sep 19, 2006 | 09:44 AM
Registered Tracker
this thread fails
Old Sep 19, 2006 | 10:04 AM
GoesLikeStink's Avatar
Drive like you stole it!
it has to be fuel starvation. Though it should not be happening when there is more than 1/3 left in the tank.
I was running at the weekend, and the fuel starvation did not kick in until just about the time the fuel light would come on, and yes it was high g left hand turns that did it.
I have a 06 by the way.
Old Sep 19, 2006 | 10:26 AM
Registered Tracker
personally I wouldnt run the car so light on gas that the light comes on, the gas cools and lubes the pump too, so running the pump out of gas can't be good for the actual pump itself
Old Sep 19, 2006 | 11:00 AM
Imp's Avatar
Imp
What's next?
It's a 4 wheel drift, where neither front nor rear tires have traction right (overcoming both slip angles)? That is called understeer. Only the most set-up drift cars have the ability to fully turn the front wheels into the direction the car is going through modified body work and steering racks.. and even then, not all the time. Breaking traction with just the rear wheels isn't drifting, it's powersliding.
A Slightly Different Case - The Four-wheel Drift
This happens when all four wheels have very little grip on the road, and the vehicle slides in whichever direction it wants to. It is often manifested as an extreme case of understeer, where the whole vehicle is slipping, not just the front wheels.
The generally recommended course of action is to turn gently into the direction of the skid, so that the vehicle has a chance of steering itself out of it.
Gee... if that doesn't describe 'the sport drifting', I dunno what does.
You learned something new today. Or will you just ignore it? Probably the latter.
Heck... go rent the 1st season of Initial D. It's covered in there.
--kC
Old Sep 20, 2006 | 09:42 AM
Red Devil's Avatar
BlueRen for president!
Old Sep 20, 2006 | 09:59 AM
Thumbs up
I actually started the day with a full tank, and the second I got the first hint of fuel starvation I pulled in, and topped up (brought a 20l canister), so no harm done there.
Excellent advice though blueren.
Old Sep 20, 2006 | 11:09 AM
Registered Tracker
you sir will be my VP
Old Sep 20, 2006 | 01:08 PM
Red Devil's Avatar
Just be careful on our hunting trip.
Old Sep 22, 2006 | 08:54 AM
olddragger's Avatar
lol--walk in front!
I too had fuel starvation in high G L handed turn--but only at high rpm fuel demand. It was 3nd gear at about 8K, dropped to 4th and 6.7 K or so and the problem went away. Had over a 1/2 tank of gas. New OEM fuel pump? Hmmmmm. Never thought the oem would not be good enough.
Hey Red Devil we miss yall down here!
Olddragger
Old Sep 22, 2006 | 08:57 AM
Red Devil's Avatar
Originally Posted by olddragger
lol--walk in front!
Olddragger
Don't you guys do a NASA event at Road Atlanta in March, or somewhere around there?
I've been scheming how I can transport myself down there so I can get some track time in during the winter.
Old Sep 22, 2006 | 11:46 PM
Registered Tracker
Road Atlanta is an awesome course. so much fun falling off the earth in that last turn!
Registered Tracker
lol--walk in front!
Olddragger
OD is great people.
Charles
