Turbo Kit Emanage Map Password.
Old Sep 14, 2006 | 07:53 AM
kiet1's Avatar
Does Anyone know the password for the emanage blue so i can unlock it and copy the map onto my emanage ultimate.
Old Sep 14, 2006 | 08:25 AM
mysql101's Avatar
Two things wrong with your statement:
1) You cannot transfer the map. They are not the same.
2) GReddy does not give out the password. It's the only way they are able to tell if someone's messed with the unit or not. e.g; You can't upload a bogus map, screw up everything then come back and say "it came that way"
Old Sep 14, 2006 | 08:28 AM
kiet1's Avatar
My Mechanic just want's to take a look at the map on the standard one and re write a similar Map onto my Ultimate.
Does anyone have any good Turbo Maps i can see or is there anywhere i can go to view any good settings?
Old Sep 14, 2006 | 08:31 AM
kiet1's Avatar
i dont get yoru statement waht do you mean they are not the same?
Isn't the Tuning process on the Emanage Blue and the Ultimate the Same.
So if i could unlock the blue and view the figures i could program the ultimate the same way.
a 0 at 500 rpms on the blue and a 0 at 500rpms on the ultimate are the same aren't they?
if you change the 0 on either map on either unit they would work the same way i would assume.
Old Sep 14, 2006 | 08:33 AM
kiet1's Avatar
if the word maps is not good for you then how about if i reword my question.
my mechanic would like to view the data on the emanage and hopefully setup the ultimate to similar settings as the preprogrammed blue unit.
if no one has managed to hack or obtained the password then does anyone have the settings that it's set up with?
Old Sep 14, 2006 | 08:52 AM
mysql101's Avatar
They are not the same. You cannot lift values from one into the other. Forget about the blue unit.
this is the REAL emanage ultimate map that will be used in the latest ultimate units:
https://www.rx8club.com/showpost.php?p=1435662&postcount=1
BUT THERE ARE TWO WARNINGS:
1) Do not use this map if your Ultimate isn't from the turbo upgrade kit. The wiring is different and this map will not function properly without the upgrade kit harness.
2) This map may require the v2 firmware to function properly. I cannot give you v2 firmware at this point since it's not publically available.
But you can use this map as a base for your ultimate tuning.
Old Sep 14, 2006 | 09:04 AM
kiet1's Avatar
hmz.
I dont have the Ultimate Upgrade Kit cause apparently they only work in the US.
Well that's what Japan said. Upgrade Kit is only for Left Hand Drive.
So i have the Normal Wiring Harness for the EMU
Thanks for the Help.
looks like it's going to be a long day of tuning.
Love the Flutter Sound.
Does anyone know if i lose it once i put a blow off on?
i dont want it to go away!!!
Old Sep 14, 2006 | 09:57 AM
mysql101's Avatar
The flutter sound will go away and be replaced by a PSSSST sound.
You do not want the flutter, it's going to damage your turbo over time.
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
jDt!
Oct 2, 2015 04:04 PM
Fickert
Sep 9, 2015 01:21 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
