Steam pouring out of my engine! Help!
Old Sep 6, 2006 | 07:39 PM
Huskyfan23's Avatar
Exclamation Steam pouring out of my engine! Help!
I was driving on my way home from work today (45 miles) and when I got off the highway, I noticed steam was pouring out of my engine. I found that very odd, because no "check engine" lights were on in my car, and the temp guage was normal. I put some oil in (it was a little low) and then let it rest for an hour. I drove it again and didn't notice anything.
Any idea what's going on????? I'm a little worried that the rotary engine on the car I just purchased with 30k miles might be in a bit of trouble. Has anyone else experienced this? Thanks in advance for the response.
Old Sep 6, 2006 | 07:47 PM
scottmhr1's Avatar
Uhh, did you check your coolant level? If you drove it for an hour later it might be nothing, did you maybe go through some water that may have splashed up on the hot parts?
Old Sep 6, 2006 | 07:52 PM
Huskyfan23's Avatar
Hmmmm.....I don't think so. It didn't rain in this area today. My coolant level could be the issue, but wouldn't the temp guage increase as well? It stayed at the normal level.
Gomez's Avatar
Shifty Bastard.
Steam from where exactly?? Done anything in the engine bay recently?
Old Sep 6, 2006 | 07:55 PM
Gomez's Avatar
Shifty Bastard.
What did you see when you lifted the hood? Notice anything strange on your dipstick?
Old Sep 6, 2006 | 07:56 PM
Huskyfan23's Avatar
Nope, nothing. The steam was pouring out from what seemed like the base of the engine (it was coming out of the sides...not straight up).
There also seems to be a slight loss of power. I don't know if it's true or not, but it did seem like less.
Old Sep 6, 2006 | 07:57 PM
Huskyfan23's Avatar
a lot of steam. It also sounded as if a small buzzer was going off, but it might have just been the sound of the engine due to the heat.
Engine was shaking a lot, and the steam was pouring out. Nothing was on the dipstick, although the oil level did seem a little low.
Old Sep 6, 2006 | 08:01 PM
Gomez's Avatar
Shifty Bastard.
Steam coming from the sides of your engine indicates a failure of a housing water jacket seal.
Get to the dealer. Rebuild time, I think. Sorry.
Old Sep 6, 2006 | 08:05 PM
Huskyfan23's Avatar
Hey, it's all good. Still under manufacturers warranty. As long as it's something they cover, that's all I care about.
Thanks for the advice, though. I'll definitely have them look at it.
Old Sep 6, 2006 | 08:12 PM
Gomez's Avatar
Shifty Bastard.
You'll be right. Better get a loaner though....the queue for a new engine might be long with the current engine recall underway!!
Old Sep 6, 2006 | 08:18 PM
Huskyfan23's Avatar
Wow. Jeez, how long would you think? Couple of months? I just bought the car 2 weeks ago.
Old Sep 6, 2006 | 08:26 PM
Gomez's Avatar
Shifty Bastard.
No, not two months. Check with the dealer.
Here is a pic of what I think has failed...see the orange "O" ring seals? One of these has let go...I reckon.
Old Sep 6, 2006 | 08:37 PM
Gomez's Avatar
Shifty Bastard.
^^^^That's not a Renesis pic BTW, but you get the idea.
Old Sep 6, 2006 | 09:01 PM
Easy_E1's Avatar
If the inner o-ring failed it would be blowing combustion gas out the radiator(overflow tank)
If you start the car and you get bubbles out of the coolant you lost the interior o-ring(orange)
If you lost the outer one then you are in deep do-do. It would have to be a major overheating to blow the outer o-ring. If that happened you would have lost all coolant and basicly burned the engine up. If overheated (HOT,, DAMN HOT)the inner one will fail first and leak combustion gases into the cooling system. The rotor houseing will have been damaged and warped on the inner sealing surface next to the coolant jacket side of the houseing the edge will be pealed back a bit.
But this is all worst case scenario.
I would go to the dealer and have them look at it ASAP.
Hey Gomez ,,that baby looks like it got hot.
Old Sep 6, 2006 | 09:45 PM
valpac's Avatar
Ahead of its time
If the inner o-ring went bad, and coolant is leaking into the combustion chamber you might get white smoke from the tailpipe. At least thats what happened to my old RX-7 (12A). Also had big loss of power due to compression leakage.
Old Sep 6, 2006 | 09:57 PM
Huskyfan23's Avatar
Thanks for all the info, guys. I'll definitely let it get checked out tomorrow. Hopefully, it's nothing.
If it doesn't do it on the drive in to work tomorrow, and I into the clear?
Old Sep 6, 2006 | 10:06 PM
Gomez's Avatar
Shifty Bastard.
You really need to get the dealer to do a cooling system test on the car.
You said the engine was shaking badly when it happened. That would indicate an inner "O" ring leak. Steam out the side of the engine indicates an outer "O" ring leak.
Take the day off. Get it looked at.
Old Sep 6, 2006 | 10:50 PM
DOMINION's Avatar
I don't buy Kool-Aid
You guys think it could have been the a/c compresser? or a line from it?
Old Sep 6, 2006 | 11:38 PM
Originally Posted by abbid
Thats what happens when you romp on a cold renesis!
nope,
ecu wont let you do it..
it could be a ps fluid hose leak!!!
lots of white smoke..
mr. GrandGame
Sep 9, 2025 10:41 PM
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
mazdaverx7
Jul 21, 2015 07:31 PM
