broken bearing
Old Sep 3, 2006 | 03:36 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
broken bearing
does anyone know what would happen if you drive with a broken wheel bearing?
does it affect anything else or does it just make sounds?
Old Sep 3, 2006 | 05:31 AM
rxeightr's Avatar
M0D Squad -charter member
Damage to the spindle, or worse yet, the wheel would fall off!
Do you have loud squealing or grinding noises?
Jack the suspect wheel up & rotate. You can also confirm a bad bearing by moving the wheel up/down/ side-to-side. Any play confirms the bearing needs replaced.
Bearing typically last well over 100,000 miles, so it is unlikely you have a bad wheel bearing.
Old Sep 3, 2006 | 08:33 AM
The RX-8 has a unit bearing.....it is non-adjustable...and you replace the mount and the bearing as one piece. It will make a lot of noise before it fails...and it shouldn;t hurt anything but itself...as the spindle is not part of the bearing unit itself.
Old Sep 3, 2006 | 10:21 AM
Moostafa29's Avatar
Storm Trooper
You're breaking suspension parts left and right (=0(
Old Sep 4, 2006 | 05:48 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
yes i have loud metal grinding to metal noise. this happened right after my friend used a hammer to bang the wheel lug out. anyways... how much do you think it will cost to repair it? thanks
Old Sep 4, 2006 | 06:28 AM
rxeightr's Avatar
DIY -- < $60
Shop -- a couple hundred
Old Sep 4, 2006 | 10:21 AM
Front unit bearing = about $150.00.....
Rear bearing about $60
Labour about 1hr.....
Luke.s
Sep 30, 2015 05:57 PM
Ian_D
Rotary Swaps
Sep 23, 2015 11:22 AM
yankeepicker
Sep 11, 2015 05:42 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
