Need some help with this offset.
Old Aug 31, 2006 | 11:46 AM
Dagious's Avatar
Motor City Madman
Question Need some help with this offset.
I can get a good deal on a set of wheels but my question is:
Will this offset work on all four corners?
18x9 with a 5.95" backspace (+24mm offset).
And if they do fit, any suggestions on tire size? Maybe 255x35 or 275x35???
thanks
Old Aug 31, 2006 | 11:53 AM
I would think that they will rub bad...they will stick out almost an inch further than my 9.5's on the back...and that will be a no go. They also will probably rub on the front as well. All in all...I would look for something different that will fit better
Old Aug 31, 2006 | 11:55 AM
NgoRX8's Avatar
agree with dannobre. the offset is too low for front and rear. you will rub insanely bad.
Old Aug 31, 2006 | 07:22 PM
I8U's Avatar
I8U
I think you should look into going with a 40-45 offset and I would go with 275/35...it looks hella good that way.
Old Aug 31, 2006 | 08:47 PM
Dagious's Avatar
Motor City Madman
it's hard to gage the min/max offset. I wish we had a real gage of what is the realistic min/max is for offset.
thanks guys, I appreciate it.
the search continues on.......
Old Sep 1, 2006 | 01:11 AM
c41250n's Avatar
if you roll the fender and have about 1.75-2 negative camber and stretch you tires, i think it should be ok!
Old Sep 1, 2006 | 01:19 AM
NgoRX8's Avatar
lol... and dont forget... do not lower and do not have back seat passengers.
Rosko350z
Mar 7, 2008 06:03 PM
kors-jan
Nov 16, 2007 03:42 PM
Galaxy 8
Dec 15, 2006 12:20 AM
Jabberwock
Oct 18, 2005 01:52 PM
jaehyun127
Jul 3, 2005 01:43 AM
