Any transmision problems??
Old Aug 27, 2006 | 08:51 PM
Dads8's Avatar
Hey, I hope someone can maybe help me. I have only had my 8 for about a month and i have about 3500KM on it so far. I have started to notice a shudder in the car when I put it in to first from neutral while at a complete stop. Now it doesn't seem to do this all the time however, I have been driving cars with manual transmisions all of my life and I have never felt a car shudder like this when shifting in to first gear.
Has anyone experienced this? or does anyone have any ideas about what this could be? I just want to be educated before I go to the dealer.
Any help would be great....
Old Aug 27, 2006 | 09:02 PM
you are in km land somewhere. where? what flash are you on...
likely it has nothing due to the trans.. it is a shudder as the ecu comes back to idle.... it used to do it as the ac cycled.
Old Aug 27, 2006 | 09:08 PM
Dads8's Avatar
Yes I am in KM land...
Im in Brampton ON
Im not sure what flash I have, is there a way to find out?
The shudder happens while the AC is off. I very rarely use the AC.
Any other thoughts???
Old Aug 27, 2006 | 09:10 PM
Im in Brampton ON
not without a canscan... or a dealer... what year car and how many miles?
and does it only happen as you are coasting to a stop and the rpm drops to idle?
Old Aug 27, 2006 | 09:15 PM
Dads8's Avatar
It is an 06 with 3500km on it, im sorry I dont know what that is in miles.
It only happens when I have come to a complete stop, sitting in neutral and the go to shift in to 1st.
Old Aug 27, 2006 | 09:52 PM
back to the dealer. neutral switch.. has been a problem before.
Old Aug 28, 2006 | 01:04 AM
TKE's Avatar
TKE
What do you mean by shutter? Can you be more specific?
Old Aug 28, 2006 | 04:50 PM
Dads8's Avatar
im not sure that shutter is the right description, I guess that you can also describe it as a shake. You can feel the car shak a bit when it happens. I guess another way to describe it is it feels like some one has given you a light bump from behind.
Old Aug 28, 2006 | 05:41 PM
map's Avatar
map
im not sure that shutter is the right description.
Shutter is not the right description. A shudder however might be possible
Old Aug 28, 2006 | 06:14 PM
so you are not feeling it in the idle?
Grizzly8's Avatar
Get your engine mounts checked .if they are not welded correctly they can produce shudder .
michael
Old Aug 28, 2006 | 06:57 PM
Dads8's Avatar
No, I dont feel it in the idle. You can only feel it when you push the stick in to first gear. As you do it you feel a jolt in the car, as I described, it feels almost like someone has hit you lightly from behind because the car actually jolts a bit.
Old Aug 28, 2006 | 07:37 PM
_Logan_'s Avatar
I think I have the same with my 8
When you go put it in first it feels like something doesnt quite match up in the tranny, i seem to get a jolt as the tranny alignes properly. This is with the clutch in, once I am actually in gear the car behaves normally. I havnt really thought about it but this might only be when the car is cold. The tranny and engine seem much smother when fully warmed up.
3,500km is around 2,200 miles, my cars done 22,000km around 13,500miles
Old Aug 28, 2006 | 09:48 PM
TKE's Avatar
TKE
I wouldn't worry about it. It's a rear wheel drive car the tranny is right next to your leg. That click and bump you feel is just the gears engageing.
Old May 6, 2020 | 03:35 AM
Cupen23's Avatar
that happend when u start in the morning
Old May 6, 2020 | 03:40 AM
Cupen23's Avatar
i feel the same but is strong feels like ur tranny gonna brake but after u drive runs fine, thats on my use trans, i have to change because the original got problems
that was 14 years ago, bub
Old May 6, 2020 | 12:16 PM
Cupen23's Avatar
did anybody. Find the problem
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
