Finally ordering RPF1s, need tire help
Old Aug 22, 2006 | 08:15 AM
snowrydr01's Avatar
I was thinking about a 255/35 or a 255/40. I wouldnt be against going wider but i am trying to keep the tires under $200. Can anyone suggest what they are riding on or any good feedback. The wheels are the 18x9.5 if you havent guessed.
Old Aug 22, 2006 | 09:04 AM
Red Devil's Avatar
I've got Kumho MX 275/35, they were about $197 per tire. Have logged a few hundred track miles and I have no real complaints about the tires.
Old Aug 22, 2006 | 09:15 AM
snowrydr01's Avatar
i guess i should also mention that these will also be my daily driver tire aswell. I have a beatup subaru for when it rains and snows, so bad weather really isnt a concern.
Old Aug 22, 2006 | 09:35 AM
Moostafa29's Avatar
Storm Trooper
I have those rims and am using Falken Azenis 615, 255/40. The fit is perfect. I highly recommend them.
Old Aug 30, 2006 | 10:46 AM
snowrydr01's Avatar
Moo
Do you have any pictures of you rim/tire package on your car so i can take a look?
Old Aug 30, 2006 | 10:51 AM
PUR NRG's Avatar
Why not the 275's? That's what I have on them. No rubbing.
________
Arizona Dispensaries
Old Aug 30, 2006 | 10:52 AM
snowrydr01's Avatar
are you running the 275s as your daily driver?
Old Aug 30, 2006 | 11:19 AM
PUR NRG's Avatar
It's my wife's daily driver.
________
SexyCrystall
Old Aug 30, 2006 | 11:29 AM
snowrydr01's Avatar
PUR
Do you have any pics?
Old Aug 30, 2006 | 05:38 PM
PUR NRG's Avatar
Look on goodwin's site. He has lots of pics.
________
COACH PURSES
Old Aug 30, 2006 | 05:42 PM
I've been running the Azenis 275's on these rims as my daily driver....as well.
Other than a bit more tramlining than stock they have been great. Good wet traction....and good enough performance at the track to keep me satisfied. I've run 12 days at the track and have put 16K miles on them since new...and they are wearing better than expected.
Old Aug 30, 2006 | 07:36 PM
I8U's Avatar
I8U
I suggest the same as the majority...275/35. Here's a good link of a tire and wheel offset calculator.
click here
Old Aug 30, 2006 | 08:06 PM
Moostafa29's Avatar
Storm Trooper
Because I already had the 255s and am too cheap to buy the 275s. Its a little overkill for my needs anyway, but if you do have a forced induction car, that is the better route to go.
Im_DANomite's Avatar
I love GOOOLD
275 all the way around? wow
Old Aug 30, 2006 | 08:21 PM
snowrydr01's Avatar
i certainly dont have FI, i just want something that will sit nicely on these wheels and allow me to rip apart turns. Again, wet traction is not an issue becuase i have a second beater subaru that i usually use if its anything but dry out.
Old Aug 30, 2006 | 09:24 PM
I8U's Avatar
I8U
It looks quite nice too, not mention the almost 12 inch foot print they lay down. Plus they fill out our fenders perfectly.
Here's what the 275/35's look like:
Old Aug 30, 2006 | 11:37 PM
PUR NRG's Avatar
275 is a little overkill for my needs anyway, but if you do have a forced induction car, that is the better route to go.
Actually I need something like a 315 on the rear tires in order to minimize wheel spin coming out of turns. Autocrossers in STU have found 275s perfect for NA cars.
________
LovelyWendie99
Old Aug 31, 2006 | 12:39 AM
scsi's Avatar
STU is actually limited to 275 maximum tire width
Old Aug 31, 2006 | 06:51 AM
snowrydr01's Avatar
Looks like 275 it is. Thanks for all your help guys.
Old Aug 31, 2006 | 07:12 AM
Spin9k's Avatar
Momentum Keeps Me Going
Yea you'll love the 275s. I do, for both daily driving and tracking.
Attached Thumbnails Finally ordering RPF1s, need tire help-side1.jpg   Finally ordering RPF1s, need tire help-side.jpg
Old Aug 31, 2006 | 12:35 PM
Rhythmic's Avatar
Laid back in the pocket
Have you guys noticed any significant gains in acceleration with these wheels? Is the weight for 18x9 17.2 lbs, or 18.3 lbs. ?
For those of you with the Falkens and the Kumhos, how might these tires compare with the Toyo T1-S in terms of grip, ride quality, tread ware, etc. ?
Old Aug 31, 2006 | 12:36 PM
Rhythmic's Avatar
And...is the weight of the stock wheels 21.5 lbs? I can't remember for sure.
Old Aug 31, 2006 | 01:24 PM
Red Devil's Avatar
Can't say I've noticed a difference in acceleration. There is a dramatic difference in grip, as expected. The RP-F1s weigh about 17lbs or just a bit above, I've seen quotes on the factory wheels being anywhere from 21.5 to 22.5lbs.
I can't comment on the Toyo vs. Kumho as I have no experience with the Toyo. From what I gathered the Toyos have soft sidewalls. I do have the MX and am very happy with them and they are holding up very well after a few hundred track miles. I think from all the reviews the Falken 615 is probably the best street/track tire you could go with targeting that $200-225 per tire price range. I would have purchased those but I had reservations about using them in the rain because of their tread pattern.
Old Aug 31, 2006 | 02:52 PM
Moostafa29's Avatar
Storm Trooper
I can notice a difference. Seems to run faster, and feels lighter.
Old Aug 31, 2006 | 04:19 PM
Magic8's Avatar
Mazda Mole
If you are going with a wider wheel it and the 275/35's then the tires will be heavier than stock 225/45. If I remember correctly, the total weight savings (wheel + tires) between stock and RPF1 is less than 3 pounds per wheel/tire.
