MS Sport muffler and RX8Store HFC fitment
Old Aug 14, 2006 | 09:33 PM
woodysjh's Avatar
I already searched!!!!!!!
Question on the fitment between my Mazdaspeed Dual Sport exhaust and the RX8Store High flow Cat.
I have my high flow cat on for a few of days now and am getting acquainted with it. I am hearing a slight leak some where so I thought to look it over good. All the welds seem good but I am noticing the fitment between the muffler tail piping and the high flow cat do not line up quite right.
I looked closely to the stock cat piping and notice that it bends very slightly down where it connects to the muffler piping. I see that the high flow cat doesn’t have that slight extra bend in it so it doesn’t match up well with the muffler. So there is a gap at the top where the flanges connect together.
I cannot get a good seal because of this and it is making a pfffffffsssst sound in the upper rev ranges.
Has anyone else noticed this on this same setup or any other exhausts and high flow cat setups?
What would be a solution to this?
Old Aug 15, 2006 | 07:51 AM
Jason's Avatar
RX7store.net
Add another gasket on the side thats leaking.
Old Aug 15, 2006 | 09:03 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
If this is the connection where the HFCat connects to the catback then there should be a doughnut gasket at that connection. Did you try to reuse the stock doughnut gasket? Also, did you reuse the stock bolts and springs for that connection?
Old Aug 15, 2006 | 06:52 PM
woodysjh's Avatar
I did not use the stock bolts because I could not get them off, however I went and bought new bolts and used the stock springs and the doughnut gasket.
So if you look at the drawing I did on this picture.
The pipe shown is the stock cat pipe.
Think of 1 is the mazdaspeed sport muffler.
2 is the high flow cat, see how in diagram 3 it creates a gap at the top because it doesn't have that bend like the stock cat has. so they do not match up flush with each other.
So I take it that most aftermarket exhausts are straight and do not have that bend in them. If that is the case then they would match to the HFC perfectly.
Attached Thumbnails MS Sport muffler and RX8Store HFC fitment-exhaustexample.jpg
Old Aug 17, 2006 | 10:40 PM
woodysjh's Avatar
I cranked down on the bolts with the springs that hold these two parts together and it seems to have closed the leak.
Old Aug 17, 2006 | 10:56 PM
NgoRX8's Avatar
lol. you solved your own problem. gj
Old Aug 18, 2006 | 05:23 PM
woodysjh's Avatar
I might just get some 1" stainless steel bolts and take the springs out.
Hopefully this is usefull for others.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
snowrydr01
Nov 23, 2015 09:40 AM
Oct 3, 2015 09:51 AM
duworm
Oct 1, 2015 04:57 PM
