gearbox or clutch issues.
Old Aug 14, 2006 | 12:31 PM
aa@uow's Avatar
hello everyone..
As I realised the gearbox of my car was getting harder n stiffer day after day (especially when changing gear after hearing the 'beep' ) I decided to let my dealer to have a look what was wrong with my car
I'd been told by my dealer after they had inspected my car that they 'BELIEVE' the problem was due to the clutch was slipping... they said they had to call Mazda Aust. to look at my car and they had the feeling that MA would have to take off the whole transmission system to find out the problem.. In this case if the problem was due to the clutch slipping... I'd have to pay for the labor cost of inspecting the transmission system which'd cost at least $800........
any idea for me guys n ladies?
Old Aug 14, 2006 | 06:40 PM
RXP33D's Avatar
Which dealer may I ask?
Old Aug 14, 2006 | 06:47 PM
aa@uow's Avatar
Mazda Sutherland..
Old Aug 14, 2006 | 06:58 PM
Grizzly8's Avatar
Before you spend $$$ try changing the oil to redline or royal purple definetely helps with gearbox .
Michael
Old Aug 14, 2006 | 06:59 PM
RXP33D's Avatar
Wouldn't you notice hesitation in acceleration through the rev range that is extremely obvious if clutch is slipping?
Old Aug 14, 2006 | 07:10 PM
aa@uow's Avatar
thats what I was thinking too!!!! I have no problem in acceleration... doesn't feel anything weird when driving it hard... the only problem is the gearbox.. I was able to use ONLY one finger to shift up or down.....but now....
Old Aug 14, 2006 | 07:37 PM
auzoom's Avatar
Hmmmmmm.........
Is it in all gears? I am having problems more and more with changing ito 3rd and 4th.
was speaking to rexii yesterday and he has had all sorts of probs with getting his dealer to look at his gearbox but finally one through after a change of service manager.
Cheers
Andrew
Old Aug 14, 2006 | 07:46 PM
Revolver's Avatar
Shootin' from the hip
Hmm, I haven't noticed any problems with my gearbox.
The short shifter makes the action a little firmer but it always goes straight into gear okay.
Keep us posted.
Old Aug 14, 2006 | 09:06 PM
kunz's Avatar
•▫▪› is way, way way way way way way way way wayyy better than you ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ∙ ▪ ;)
Do you still have any warranty left for the 8? If so, wouldnt the inspection + all other costs be covered under warranty?
Old Aug 14, 2006 | 09:25 PM
takahashi's Avatar
All that stupid excuse that they make up. I am sure there is a TSB for dealer to say those words for customers
Dealer will charge you to look at it, since if it is not the source of the problem, they cannot charge MA for the labour. They are not good hearted enough to give you a free man to look at your thing.
$800. They take 7 hours to look at a gear box??? Does that include a 2 hour lunch? Last time I went in for a quick fix in Canberra - the guy took a f^&*ing lunch half way through his job.
Old Aug 14, 2006 | 09:31 PM
kunz's Avatar
Taka, is that even with warranty?
Old Aug 14, 2006 | 09:35 PM
takahashi's Avatar
They can claim the labour only when a warranty part is supplied.
So most people with synchro problem WILL not get the gear box pulled apart. They will just put the whole new set of gear box in, and return the old box to Mazda. Labour is charged as long as they like. And the work is little as it is just a swab over.
There are so many tricks that they do to squeeze money from MA. Haven't you know why they like us asking the right question so much? Oh my car does not sound well when it starts - yes you can have a start motor upgrade. Oh my car is vibrating on idle - yes you can have a new engine mount.
Old Aug 14, 2006 | 10:46 PM
kunz's Avatar
i c
gotta be careful then hey
Old Aug 14, 2006 | 11:04 PM
pp going bad or pp bolts / screws backing out... clutch is not releasing all the way..
beer
Old Aug 15, 2006 | 08:25 AM
aa@uow's Avatar
YES, my 8 is still under factory warranty but Mazda Sutherland told me that I would be charged for labor if it is not the gearbox causing the problem... they doubted that I did'nt release clutch properly which lead to the problem..... (bull ****!!!!) I do sometime drive the car hard but isn't it what it meant to be? I drive easily most of the time.....
any idea for man??????
Old Aug 15, 2006 | 06:36 PM
Revolver's Avatar
Have you considered getting another RX8 owner to give it a short thrashing to see if they can detect a problem?
Old Aug 15, 2006 | 09:19 PM
auzoom's Avatar
Hmmmmmm.........
I owuld skip mazda for the moment and get a reputable mechanic to have a look/listen and see what they think. Once you/they are sure its the gearbox make mazda look at it.
Cheers
Andrew
Old Aug 15, 2006 | 10:30 PM
Revolver's Avatar
An even better idea. Find a transmission specialist if you can.
Old Aug 15, 2006 | 10:45 PM
aa@uow's Avatar
thx alot guys!!
will try Rockdale Mazda since a number of U guys recommanded it... will keep U guys updated!
Old Sep 3, 2006 | 03:31 AM
auzoom's Avatar
Hmmmmmm.........
how did you go with this? ANy updates yet?
Old Sep 3, 2006 | 06:53 AM
aa@uow's Avatar
I went test drive a 2nd RX8 this afternoon which has been driven for about 23000km.. i could easily tell that my gearbox needs to be repaired.. will ring up other Mazda dealer tomorrow to book a time for an inspection..
I sometime cant even shift up at high rev.. (usually beyond 8000...)
Old Sep 3, 2006 | 07:33 AM
auzoom's Avatar
Hmmmmmm.........
Have you ever changed gearbox oil?
Old Sep 3, 2006 | 06:29 PM
Gibbo's Avatar
In between cars, RX8-less
OK, I would not put up with this from the dealer. I had a similar problem with a clutch failure from Holden a couple of years back. They claimed driver abuse, I challenged them on it and asked them to prove their claim. They said it was common knowledge that this sort of failure was vehicle abuse, once again I asked them to prove it or I would be contacting the Department of Fair Trading.
They have a standard policy of denying fault in issues like this, inform them that you will not be paying anything, and they need to rectify the problem. If this fails then contact Mazda Australia and complain to them.
Old Sep 4, 2006 | 10:16 AM
aa@uow's Avatar
no, never changed gearbox oil since I bought the car.. I have done 33000kms..
will let another dealer to look at the car first.. hope they will take care of me this time..
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Mane
Nov 20, 2015 12:16 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
