Calling All Turbos!!! Need Help!!!!
Old Aug 12, 2006 | 07:22 PM
diggs's Avatar
Eliza Dushku's Stalker
I have a greddy kit and since this morning, the turbo has been sounding like a supercharger, it has that whine to it.
I had a buddy of mine take a look at it and we both came to the conclusion that the turbo isn't getting enough oil and the sound is the bearings complaining about it.
All of the lines look intact, im not losing boost and there are no other problems, but my buddy made the observation that the oil return line may not be draining the oil properly back into the oil pan, as it sits pretty much horizontally.
Is there any info you guys would have for me at all before i start tearing my car apart?
Thanks everyone.
Old Aug 12, 2006 | 07:53 PM
mysql101's Avatar
can you make an audio clip of it?
the greddy upgraded oil pan is a really good buy - something like $280, and the oil drains much better with it.
Old Aug 12, 2006 | 08:05 PM
shawn81's Avatar
how long have you had your turbo and what is youe AFR do you have a WBO2.. check your oil level. i wish you had a oil pressure gauge.
Old Aug 13, 2006 | 04:47 AM
mikeschaefer's Avatar
I wanna rock! Rock!
are you using an oil supply line restrictor?
any smoking?
try taking a look at the thread about the oil line restrictor if you haven't already
Old Aug 13, 2006 | 09:00 AM
MadDog's Avatar
Consiglieri
Your two theories are inconsistent. If the oil isn't draining properly, then there would be an over-abundance of oil in the turbo, not too little. But, for the record, it drains just fine if you have it setup like every other GReddy turbo does. Also for the record, there are two advantages of the GReddy oil pan - but better drainage isn't one of them. It has more capacity and oil changes are a little cleaner since you retain the plug.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Patricia Odell
SE RX-8 Forum
12
Nov 14, 2016 02:40 AM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
DeltaJ802
Sep 29, 2015 01:20 PM
