Help! Quick response appreciated!
Old Aug 11, 2006 | 01:05 PM
GeorgeH's Avatar
I'm getting a flashing check engine light that activates only when I rev the engine very high. It comes on, flashing, but then goes away if I drive normally. Doesn't come on if I shift below 6,000 rpm.
Car is an '04 with no mods other than a K&N drop-in. I also run a little Yamalube semi-synthetic pre-mix (4 oz per tank). I'm hoping to compete in the Packwood NT tomorrow, and am pulling my hair out as this just started happening today. Called a dealer and they can't see the car this afternoon.
Has anybody had this happen?
George
Old Aug 11, 2006 | 01:13 PM
zoom44's Avatar
its misfire- check your plugs and coils
Old Aug 11, 2006 | 01:33 PM
GeorgeH's Avatar
Plugs are fairly new, but they still could be problematic, I suppose. I'll check them.
Another symptom - I could swear the car is running just a little rough.
As for the coils, they are original (16,000 miles). Can you provide a link that describes how to check them?
Thanks for the help.
Old Aug 11, 2006 | 01:42 PM
Might be a plug wire as well?
Bad gas?
And 101 other assorted problems
Do you have a code reader to pull the code??
Old Aug 11, 2006 | 01:43 PM
zoom44's Avatar
pull them off and look at the underside for signs of burning/ arcing. also look for any bubble like deformation in the casing of the coil
Old Aug 11, 2006 | 01:51 PM
GeorgeH's Avatar
Zoom44, you are the man!
Pulled out the top plug on the left, and it looked fine. As I was re-installing it, I noticed that the top plug on the right wasn't connected to it's lead. "That sure is odd," I thought to myself.
Note to self: Electrons have to reach the plug...
Old Aug 11, 2006 | 02:01 PM
GeorgeH's Avatar
Thanks for the help guys. Now, on to the Tour! Storm the castle gates! And all that good stuff.
Old Aug 11, 2006 | 02:05 PM
You probably want to pull the rear trailing plug and see if it is fouled if it was disconnected for very long. It is amazing how little difference it makes if the trailing plugs are disconnected.
Old Aug 11, 2006 | 02:21 PM
zoom44's Avatar
george hows the kendo going?
Old Aug 11, 2006 | 02:25 PM
zoom44's Avatar
oops wrong portland george- the kendo one was at my house for a bbq 2 years ago. got the two of you confused for a moment
RevMeHarder
Jun 1, 2026 02:30 PM
Brokegang
Jan 3, 2016 12:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
RXBae
Sep 14, 2015 03:54 AM
