zoom44
08-10-2006, 04:53 PM
http://www.freep.com/apps/pbcs.dll/article?AID=/20060810/BUSINESS01/608100352/1014/BUSINESS
the twist on/off kind in favor of the metal flap type they used on the GT. this is to eliminate the problem o f not screwing the filler cap on at all or correctly after fueling so it should eliminate false evap CELs
Here's how it works: When the nozzle of a conventional gas pump is put into the fuel filler point, it pushes on two tabs that open a spring-loaded metal flap. That allows the pump to sit in the tube that delivers gas to the tank, just as a pump does after the cap is unscrewed. After the nozzle is removed, the spring-loaded door seals the pathway shut.
The innovation addresses issues for at least two key target groups. It could be a boon for aging drivers with arthritis and women who don't want to muck up their nails by unscrewing caps.
Ford research, though, found that the capless system was universally liked by drivers -- young and old, men and women, said Mike Cowley, Ford's manager of North America fuel systems.
Aside from the MKS in 2008, Ford would not say when the capless system would be available in other vehicles, but it will be installed across the entire lineup.
Ford spokesman Nick Twork said it's a "go-fast" project.
"As fast as we can get it out there," he said.
