Taking off rear aero flares?
Old Aug 8, 2006 | 02:17 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
I am possibly going to install a traded stock rear black bumper on my car. It has the rear aero flares installed from the factory/dealer.
Are they hard to take off? Do they leave any noticeable holes/marks/cutouts after I take them off?
Old Aug 9, 2006 | 04:31 PM
Anyone?
Old Aug 9, 2006 | 05:24 PM
Mugatu's Avatar
Even My Dog Searches
if they were put on exactly the way Mazda says to, there will be 2 slits in the bumper - one from each flare. however, some (like me) cheated and cut those tabs off so as to not have to cut into the bumper. if you bought it that way from Mazda, then odds are you got them. they will be about 3/4" wide.
Old Aug 9, 2006 | 05:25 PM
kwescott's Avatar
One ball, corner pocket
They are easy to take off. There is one nut, and one square fastener on the inside of the bumper....but both of these will leave holes exposed, as well as 3m tape along the front edge of the bumper. I have pics somewhere as I just removed mine.
But quick answers, yes, easy to remove, and yes, it will leave two holes exposed in your bumper.
Old Aug 9, 2006 | 05:32 PM
arr ex eight's Avatar
not any holes that an aftermarket side skirt wont cover right kwescott?
Old Aug 9, 2006 | 05:43 PM
StealthTL's Avatar
Metatron
Arrow Traded...
If you have access to the "new" part, look up inside the bumper, you can see the hole from the inside, then YOU can be the judge as to whether they are tolerable. (They are huge.)
If the tabs were cut off by the installer, you can also see that, there is a little outline up inside the bumper, of where the holes would/should be.
S
Old Aug 9, 2006 | 06:08 PM
kwescott's Avatar
My MS rear covered the holes, and lined up in the same spot as the flares. So, no problems for me.
and the dealer that installed mine, actually drilled two holes for the bolt, given that their first attempt didn't line up.
Old Aug 9, 2006 | 07:25 PM
Thanks for the help. I knew that owners doing it themselves usually skipped the bumper holes and only did the one in the wheel well. I just wasn't sure what the dealers did if they did it properly.
RX8inSTL
Oct 20, 2015 05:17 PM
DVerdeyen
Aug 31, 2015 10:41 PM
Kahl
Aug 20, 2015 11:49 PM
Jazzmeson
Jul 21, 2015 02:54 PM
