Brake Calipers
Old Aug 5, 2006 | 03:01 PM
HKS17's Avatar
Brake Calipers
Bros/Sis out there,
I'm thinking of changing my 4 brake calipers to after market like Brembo or Endless, any good recommendation and what is the cost likely to be? Mine is a MM spec.
Old Aug 5, 2006 | 04:17 PM
HKS17's Avatar
Location
Possible to list few cheap locations for after market brake calipers installations? Exclude Garage R (well known for EXP)
Old Aug 6, 2006 | 12:40 AM
sqflyer's Avatar
Heavy Machinery Operator
Take note that if you're on stock rims, you're gonna have to change them to aftermarket rims that can accommodate the bigger brakes. BTW, our stock brake calipers are excellent and can even handle light track use.
Old Aug 6, 2006 | 06:04 AM
lennon's Avatar
It's true..... You have to change your rim before you upgrade the brakes
Front brake calipers with rotors can simply cost SGD5k...... So far haven't found brake calipers for rear.....
Old Aug 6, 2006 | 08:55 AM
KJ238's Avatar
Air + Fuel + Spark = Boom
Dont think you would need to change the calipers unless you have a major power increase in your engine or regularly are on the track...
Change of pads should be sufficient
I'm using a pair of endless Vito Nuovas in front... Cost is around SG$200 here in brunei... so shud be cheaper there
Slightly better braking, slightly better feel, slightly louder noise.... Nothing major... Oh and it got rid of the squeal..
Old Aug 6, 2006 | 12:30 PM
Rei's Avatar
Rei
White Rotary
Maybe can consider the rx7 fd3s brake caliper...much cheaper than those
branded stuff in the market...plus its a 4 pot...
Old Aug 6, 2006 | 03:23 PM
coupe07's Avatar
SC 300HP!!
this one huh....
Old Aug 7, 2006 | 04:48 AM
Rei's Avatar
Rei
White Rotary
Yup...this is the one I was talking abt...sweet...
Old Aug 7, 2006 | 06:20 AM
simply8's Avatar
white renesis*
show that u have not visit the garage for sometimes hor?
please update hor! it's on ivan's rides for sometime already.
not forgetting to mention our master zavhan for spraypainting!!
Old Aug 7, 2006 | 10:09 AM
Rei's Avatar
Rei
White Rotary
Hahaha...got go lah, bro...juz usually stay there for less than 1 hrs to eat snake
during work, thats y never call u? heehee... saw it on Ivan's ride a
few time...including the grand opening of monster garage...
Old Aug 8, 2006 | 11:21 AM
4-TOOTH's Avatar
Just changed my brake pads to the Endless C-CA and also the Endless braided steel line with the brake fluid in the package..... surprisingly it is as quiet as stock pads and the bite is at least 40% firmer..... will let it run in the pad a little longer to find out the exact quality of the pad......
initial feeling ....... very happy with the product....
Old Aug 8, 2006 | 11:30 AM
CoupeM's Avatar
Night Rider
How much you paid for it?
Old Aug 8, 2006 | 02:06 PM
4-TOOTH's Avatar
the Pad itself is in the range of 300 and the brake line kit plus the brake fluid in the around 500
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
TheRedRotor
Sep 22, 2015 05:30 AM
