Eibach Pro Kit Problem
Old Aug 4, 2006 | 09:35 AM
Evil 8's Avatar
TwIsTeD KrE8iOnS
I installed lowering springs about 6 months ago with no problem. Just recently theres been a knocking noise from the front Left Wheel. Whenever Im going really slow or step on the brake. Anyone out there have the same problem. I did do a search on this problem but only found results on the rear doing a noise. Any suggestions. I brought the car to mazda and they told me its not the strut.
Old Aug 4, 2006 | 10:06 AM
dsmdriver's Avatar
Check your sway bar link nuts. I had one coming loose and it sounded almost exactly like what you describe. It would pop whenever the sway bar got loaded up. You have to take these bolts out to put in springs or struts, so maybe it didn't get tight enough.
Old Aug 4, 2006 | 06:12 PM
Evil 8's Avatar
TwIsTeD KrE8iOnS
Thanks dude... i'll try that and i'll let you know.
Old Aug 4, 2006 | 07:08 PM
PoLaK's Avatar
Son what is your Alibi?
I had a similar problem, mine turned out to be loose lugs on the rear left wheel.
Old Aug 4, 2006 | 09:40 PM
Silver_Surfer's Avatar
I4NI
I had this same problem with my 04 Maxima. This time I purchased Tein springs and am glade I did!
Old Aug 5, 2006 | 01:13 PM
Evil 8's Avatar
TwIsTeD KrE8iOnS
See i would say that its my springs that i put in but its only doing it on the one side. Haven't had time to check it yet.
Old Aug 5, 2006 | 08:37 PM
RX8Maine's Avatar
Hasn't there been an issue with lower control arm bushings on our front suspension? Might be another thing to check.
Old Aug 5, 2006 | 10:34 PM
Evil 8's Avatar
TwIsTeD KrE8iOnS
i pretty much took it to mazda just to look at it and i really dont think they even put it on the lift. Cause when they got the car the front tires had brake dust all over it and it didn't even look like they took the wheels off. and plus they didn't even have the key but there could be a master one.
Old Aug 6, 2006 | 03:45 PM
kw1k's Avatar
i've been havin the same problem..
Old Aug 24, 2006 | 09:15 AM
Evil 8's Avatar
TwIsTeD KrE8iOnS
Well if you figure out whats wrong let me know...or if anyone out there knows what it could be.
Old Aug 25, 2006 | 06:22 PM
OnRails's Avatar
Uh.....I don't think they even looked at it dude.
Old Aug 26, 2006 | 05:43 PM
h-khunterkiller's Avatar
for hire
well i don't think is a problem with the spring itself, i have had mine for 2 years and no problems here (i have eibach also) so like the other guys have told you check and re-tight everything again something has to be loss
Old Aug 26, 2006 | 06:24 PM
mmats69's Avatar
93.5 octane
i tend to agree here. i've had mine a year with no problems at all. there was a recall in the front lower arm ball joint. you can look at that and other TSB's on the 8 here:
http://www.finishlineperformance.com...ins_index.html
xAgyex
Jun 3, 2026 03:47 PM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
Billy Marcial
Mar 1, 2018 06:50 AM
RicerX1
Jan 11, 2016 05:59 PM
RoddyMac
Aug 5, 2015 04:21 PM
