Faulty Fuel Gauge?
Old Jul 27, 2006 | 08:39 PM
Tirminyl's Avatar
Listen to Zoom44
Faulty Fuel Gauge?
I've notice recently that my fuel gauge behaves funny when I am at 3/4 of a tank. Two days ago before leaving for work, I was at 2 tics above the 3/4 mark. When I arrived I was at 1 tic under 3/4 of a tank. When leaving work, I put the key to the "on" position and my fuel light comes one and the mark is on E. It then moves a tic up after 30secs. After 5 minutes of driving, the gauge goes back to 3/4 of a tank and and only moves 1 tic by the time I reached home.
I've filled up since then, and it is behaving normally when comparing it to my mileage. Any idea before I take it to a dealer to get the normal "we can't replicate the issue" response. I've tried searching but maybe im not using the correct terms.
Old Jul 27, 2006 | 08:43 PM
One of the fuel tank sensors isn't working properly.........I'd guess it's the sensor in the passenger side of the tank. There are two sensors that determine the fuel leveL.
Old Jul 28, 2006 | 02:23 PM
JonsToy's Avatar
Registered Rep
Are you parked on a level surface at home and at work?
I've noticed my readings can be off when I'm parked either uphill or downhill. These readings tend to even out, though, once the car gets back to flat terrain.
Old Jul 28, 2006 | 05:47 PM
Tirminyl's Avatar
Listen to Zoom44
Yes, I am parked on a level surface. Still doesn't explain how I can drive a couple of miles with it on E then it shoots back up to 3/4 of a tank.
Old Jul 28, 2006 | 05:59 PM
zoom44's Avatar
dan did a good job of that
Old Jul 29, 2006 | 07:48 AM
Tirminyl's Avatar
Listen to Zoom44
Well, I know Dan did a good job answering that. That statement was more towards Jonstoy in a sarcastic tone.
Old Jul 29, 2006 | 11:26 AM
zoom44's Avatar
mine was laced with sarcasm
Old Jul 31, 2006 | 01:23 PM
JonsToy's Avatar
Registered Rep
Hey. I was just trying to help.
Old Jul 31, 2006 | 01:46 PM
Tirminyl's Avatar
Listen to Zoom44
Nothing bad against you, thanks for the help
cliffkemp
Dec 24, 2024 10:48 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
XianUnix
Sep 29, 2015 03:48 PM
DeltaJ802
Sep 29, 2015 01:20 PM
Jb4ker96
Sep 27, 2015 10:06 PM
