Rotary Performance HF Cat Popping Sound
Old Jul 24, 2006 | 09:54 PM
brillo's Avatar
Go Texas Longhorns!
When cruising down the highway at 70ish mph and occationally while cruising down the road, I hear a popping sound coming from below the car in the area where the cat and mid pipe would be.
I know that some folks were having an issue with the cat since it didn't have a hanger like the stock piece, but I can't tell if what I am hearing is the cat hitting something (likely the underbraces) or possibly mini backfiring due to the engine running lean at cruising speeds. From the passenger seat, it sounds like its coming from up near the engine, even though the stock cat hanger was in the rear.
just wondered what other folks with the cat hear or feel. I have the stock exhaust.
Old Jul 24, 2006 | 09:56 PM
mysql101's Avatar
does it happen when you're letting off the gas?
how about if you rev it really hard?
Old Jul 24, 2006 | 10:03 PM
Moostafa29's Avatar
Storm Trooper
Hey Brillo, they are two very different sounds. The cat hitting against something, you'd definitely know. Just in case, have someone rev the car up, and lay down next to the side and listen to it. I'd suspect that what you are hearing is just the cat backfiring.
Old Jul 24, 2006 | 10:40 PM
brillo's Avatar
Go Texas Longhorns!
i heard it most clearly when we were cruising at a steady speed on the highway going up and down hills, not when i let off the gas
Old Jul 24, 2006 | 10:47 PM
back out.
that popcorn popping sound is detonation.. the location you give is exact... back of the cruise afr..
Old Jul 24, 2006 | 10:50 PM
pm or call me this is serious!!!!!!
Old Jul 25, 2006 | 12:12 AM
brillo's Avatar
Go Texas Longhorns!
I pulled the interceptor to be safe and switched back to stock. No issues or noise. I still think I here the cat hitting something on bumps.
Its weird, we tested the lean afrs for cruising on a dyno, and we had worked the car over pretty good by that point, i wouldn't think 15.2-15.5ish would be that bad. Well, I'm going to re evaluate my strategy as far as cruising maps go.
Old Jul 25, 2006 | 12:36 AM
Brettus's Avatar
Boosted Kiwi
Brillo - have you read what RB has to say about tuning for fuel consumption ? Its in the Tech info for the flash tune.
Worth a read
Old Jul 25, 2006 | 12:57 AM
brillo's Avatar
Go Texas Longhorns!
Worth a read
I did, but I figured were working mostly inside the cat temp/emissions box, therefore I thought I'd see what else i could eak out emissions be damned.
it turning out to be harder than I thought, but i'm not totally out of ideas yet.
Old Jul 26, 2006 | 02:19 PM
Moostafa29's Avatar
Storm Trooper
Did you solve this problem yet?
Old Jul 26, 2006 | 03:48 PM
brillo's Avatar
Go Texas Longhorns!
Well, I had thought it might be knocking, but since I didn't experience any loss of power and i still hear the noises with the stock ECU and premix, it has to be the cat rattling or hitting something. It takes a while for the sound to develope, but what I think is happening is that the rubber hangers eventually heat soak and the fact that I'm one hanger short causes them to flex mroe than they should.
I was worried I was hearing the same thing as Swoope, but we discussed the issue and I'm pretty sure that it is the cat, as the sounds I hear were only after the cat was installed.
I'm going to get a hanger installed this week to help hold it in place.
Old Jul 26, 2006 | 03:50 PM
brillo's Avatar
Go Texas Longhorns!
Old Jul 26, 2006 | 08:08 PM
Moostafa29's Avatar
Storm Trooper
Maybe it depends on the exhaust its matched up with, or the version of the RP cat, because I had an earlier version matched with the RB exhaust for about 8 months, and never heard any rattling. But when I was helping IzoomzoomI put a Supercat on his Helix, it made a horrible rattling sound, even at idle.
Kanthinar
Dec 21, 2015 01:24 PM
dbarber
Jul 25, 2015 01:34 PM
Jvswan
28
Jul 23, 2015 09:02 AM
AussieGray
Jul 16, 2015 03:58 AM
