any burning smell after stopping engine?
Old Jul 11, 2006 | 12:05 PM
lawreo's Avatar
*** Lover
Hi
i just got my new AT 8. Sometimes when i stopped my engine after reaching my destination and getting out of the car, i can smell some burning smell coming from the car. is this normal ?? anyone experienced it? i am still monitoring the situation. i am only driving it for the 3 third day.
thanks !
Old Jul 11, 2006 | 12:15 PM
INXS's Avatar
INXS
smell of petrol ?
Old Jul 11, 2006 | 02:35 PM
Genesis's Avatar
Driving Me Crazy
Originally Posted by lawreo
Hi
thanks !
It's a rotary engine....that's called the New Smell Period (NSP)...also known as the Never Stop for Police period....
Old Jul 11, 2006 | 06:58 PM
rav969's Avatar
it is probably new car smell as most parts underneath the bonnet are still new and got heated up for the very first time. try smelling the tires and brake ... u may find somethng too heeheehee ... Monitor it for a while longer ! anywat, no worries la, let the problem surface now rather then later and get the PI to fix it FREE !
Old Jul 11, 2006 | 10:50 PM
Emperor's Avatar
aka Spectre
It happens with all new cars for at least the first month.
Also happens when you change bodykit or spill liquids on the engine.
Old Jul 12, 2006 | 04:48 AM
lawreo's Avatar
*** Lover
Originally Posted by INXS
smell of petrol ?
no not the smell of petrol but really some heated smell never smelled before from my previous corolla.....maybe i will meet up some time to show u guys
then again , maybe our 8s all smell the same
hehe
Old Jul 12, 2006 | 05:34 AM
mkl22's Avatar
double check to see if you have not caught a plastic bag under the car and is being heated up by the exhaust.
Old Jul 12, 2006 | 07:28 AM
Emperor's Avatar
aka Spectre
I am having this smell now. The silly mechanic spilled my precious oil on the engine. Always happens; its quite difficult to fill oil with the filler in the middle of the car. And its even more difficult with my bodykit.
Anyway don't worry. 99% no problem. Your old corolla may not smell the same maybe because it heats up less than the 8 or it smell lesser.
I understand that feeling. I know all new car smells in the first month and yet whenever i buy a new car and i smell it, i will call the saleman only to have him reassure me this is normal. Its just new car anxiety.
Old Jul 12, 2006 | 07:51 AM
madmax_rx8's Avatar
i think most of them are right might be new stuff so need to take awhile
i changed my fujisubo exhuast when i first got my car... when i 1st got it fix, its worst cause after my 1st spin with it, it got smoke coming out for i think about 2min and the burning smell is strong...
i thought what happen then i call the st power then they say cause new exhuast is like that then true enough after about 2 days or so it's all gone
Old Jul 12, 2006 | 08:42 AM
lawreo's Avatar
*** Lover
oic
thanks alot guys/gals !!!
really appreciate all the replies here.......btw hoping to change mineral oil at Monster G. when i reached 500 km soon (advice from one bro here). Do i need to book an appointment for that?
Old Jul 12, 2006 | 08:57 AM
Jasontan_sg's Avatar
If rubber smell, then you have to be careful, because the engine mounting rubber might be melting due to you left your car ideling for hours with engine on and the engine compartment getting very hot.
I have got my engine mounting changed already, and understand this is comment for RX8. Same thing it got rubber buring smell and the a few week later the engine started to vibrate, it get worst until you replace the engine mounting which cost arond S$380 for parts and laboure.
Never left your car engine on for hours, when you stop switch off the engine. Otherwise the engine will get very hot. Rotary Engine is alway very hot.
Would suggest you go to kinokuniya to buy the RX8 Magazine: Hyper Rev Vol.110, it will tell you what are the very important thing to do with your new 8.
1) Fix two defi meter: 1 Oil temperture and 1 Water temperture.
Oil temp will give you warning indication not to overaft you engine, when it hit 120 degree stop pushing your car anymore, as it will hurt the engine.
Water temp is very important for RX8, as if over 105 degree, you better stop the car and look at the temp before switching off the engine, if the temp continue go up then no choice switch off the engine, too hot will hurt the engine seal, that will cause oil leak.
2) Fix an additional oil cooler on the front right, as the original one on the left is still not enought, because it need two to bring down the engine heat.
3) If you are auto, please fix a Auto Transmission Cooler, so the the transmisson are less stress with heat.
Once all the above is done, then you consider doing other MOD on electric, 18' rim, shock and etc..............
Upgrade should come slowly maybe every few month then you will enjoy your RX8.
Jason
Old Jul 12, 2006 | 05:57 PM
lawreo's Avatar
*** Lover
Jason
thanks bro for the info . i dun think it is the burning rubber smell although i do experience vibration when idling at the traffic light...dun know whether is that normal......will ask the garage to check my engine mounting when i am changing my mineral oil. any good place to recommend ?? i also plan to install an AT cooler ....any good brand and place to install to intro?
cheers!
Old Jul 12, 2006 | 06:10 PM
theboy's Avatar
RX8 newbie!
i had this problem before,
1. plastic stick on your exaust
2. new or burnt out engine oil
3. must be your new car smell. the thing they used for anti corrusion. when ur car put out the heat, it make the protection layer smells.
Old Jul 12, 2006 | 08:09 PM
Roulette's Avatar
DOes anyone have a burning smell thru the A/C when u rev it hard? i tend to get mine after even a little bit of hard revving, esp when the engine is still warming up. (rev up to 5k rpm onli somemore)
Old Jul 13, 2006 | 11:02 AM
Genesis's Avatar
Driving Me Crazy
A few have reported this, though I've been lucky and never had it. I still can't figure how the burning smell travels with the A/C line....anyone?
Old Jul 13, 2006 | 11:15 AM
lawreo's Avatar
*** Lover
maybe if you off the air recirculation, you may get the smell from outside?
if you use the recirculation for the air-con, i think should be fine.
Old Jul 13, 2006 | 11:58 AM
Genesis's Avatar
Driving Me Crazy
No mate, that's the obvious solution....the A/C problem cited is more involved than that, but thanks for posting your view.
Old Jul 14, 2006 | 10:56 AM
Freestyle's Avatar
Renesis Perfection
My RX-8 has that burning smell after a hard rev... my G9 Corolla had that too. And so does my friend's Integra R... dunno whether that's normal... but it happens...
Old Jul 14, 2006 | 01:36 PM
CoupeM's Avatar
Night Rider
My 8 got a burning smell when a plastic bag got caught on the exhaust and melted.
Old Jul 14, 2006 | 03:30 PM
INXS's Avatar
INXS
Thats awful, mine too.. on my camry.. the stench was unbearable.. didnt know what to do at first..
Then finally jacked it up.. took of the plastic shreds one by one by one.. had to drive with the window down for 2 weeks..
Old Jul 15, 2006 | 01:00 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
Burning smell might be clutch smell :P
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Quato_jr
Aug 4, 2015 09:22 AM
marc2820
Jul 26, 2015 10:47 PM
