help broken stud from replacing flat tire -what is the part called that I need ?
Old Jul 10, 2006 | 06:35 PM
yellowrx888's Avatar
I got a flat tire not so long ago and decided to put on my spare tire on. I took off the lug nut and one lug cracked the screwy peice and took it with it ... so now I have what looks like 4X114.3 bolting on the rear left rim .....
Anyone know what the part is called that I broke off ? I'm guessing its called a hub or wheel adapter?. Circled is the part I broke off. ...
Attached Thumbnails help broken stud from replacing flat tire -what is the part called that I need ?-gn132.jpg
Old Jul 10, 2006 | 06:58 PM
Alright nevermind about that .. found out its called a wheel stud...
Old Jul 10, 2006 | 07:34 PM
RedSheDevil's Avatar
.:. causing mischief
LOL, i was just going to post .... um, the wheel stud? good thing is they're cheap!!!
Old Jul 10, 2006 | 07:41 PM
yep they are cheap .. just found the DIY thread for replacing the front ones. .... heard the rear ones are hard ...
damn out of all the ones I break , I broke the rear one...
Anyone know how to install/remove a stud from the rear ?
Old Jul 11, 2006 | 10:55 AM
Red Devil's Avatar
Don't listen to her. She gives bad advice and then tries to charge you for it.
Old Jul 11, 2006 | 11:02 AM
LOL!!
do I really give bad advice? You know I'm dying to know how the advice I gave you worked out .... but I'm just sitting here patiently
/hijack
Old Jul 11, 2006 | 11:10 AM
Red Devil's Avatar
At the moment...I have nothing to speak of regarding that advice because there is no new information to report.
Old Jul 11, 2006 | 11:47 AM
Aseras's Avatar
pound it out and cut it off. to put a new one back in you need to pull the axle and replace the bearing/seal there.
or... cut a tab out of the new stud so it can clear the axle and put it back in.
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
M RX 8
Aug 5, 2015 06:45 PM
Jazzmeson
Jul 31, 2015 01:47 AM
