where can i get the cz2 mapping
Old Jun 24, 2006 | 02:01 AM
rx8macau's Avatar
I have messed up with the mapping anyone have information on how to program my unit to stage 2 mapping again thank you
Old Jun 24, 2006 | 04:29 AM
rx8macau's Avatar
anyone can help me
Old Jun 24, 2006 | 04:44 AM
MegaLoL's Avatar
http://tyrannical.org/page-15
Old Jun 24, 2006 | 04:57 AM
rx8macau's Avatar
I need to have the cz 2 AFR map to upload to the main unit
Old Jun 24, 2006 | 11:22 AM
Here's the original stage2 map in full RPM
Old Jun 25, 2006 | 12:07 AM
rx8macau's Avatar
thank you dannobre
Old Jun 25, 2006 | 01:15 AM
rx8macau's Avatar
when I upload the file it saids some kind of verion error and ask me to contact the dealer what version are you using dannobre
Old Jun 25, 2006 | 12:15 PM
Is it a winzip error......or a CZ error??
I opened it from the link and it worked for me ??
Old Jun 25, 2006 | 10:42 PM
rx8macau's Avatar
I can connect to the cz unit and can import map from the unit but cannot make any modification and export map to the unit it says some kind of verion not support by the emanage something like that
Old Jun 26, 2006 | 07:06 AM
rx8macau's Avatar
is a cz error, cannot export your map to the unit
Old Jun 26, 2006 | 09:01 PM
What version is the unit and the software you are using?? I would expect that you have different firmware version installed than the map was made in...
Is the software communicating with the Unit...ie does the maptrace and Throttle setting work?
Old Jun 26, 2006 | 09:02 PM
That map is the original map from Canzoomer by the way....
Old Jun 27, 2006 | 01:37 AM
rx8macau's Avatar
I'm using software version 1.24 anf firmware version 1.42
Old Jun 27, 2006 | 09:39 AM
That's the "gold" version software...you can't use it to open a "blue" map....you will have to make yourself a map manually.
or install a " blue" software version
Brettus
46
Apr 19, 2024 06:28 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
