Help! Settle this debate....
Old Jun 19, 2006 | 05:14 PM
OnRails's Avatar
Question Help! Settle this debate....UPDATE
Could someone help clear up a debate I'm having with my brother-in-law? He had a problem this weekend where his 94 Corvette was overheating at an autocross event. (I was running my 8 and he was running his Corvette.) He was able to drive the car home however. He claims that the car is overheating because the thermostat is stuck open. I say that if the thermostat was stuck open then the car would run too cool and not too hot. I say that it may be stuck closed but it is not stuck open. He says that because the thermostat is stuck open, the coolant is not staying in the radiator long enough to cool off and therefore the engine is overheating. Who is right?
Old Jun 19, 2006 | 05:23 PM
midlife crisis's Avatar
You are.
Old Jun 19, 2006 | 05:51 PM
OnRails's Avatar
I did find this to support his argument...
http://www.dansmc.com/watercooling.htm
It says: "You can run without a thermostat but it's not a good idea because the thermostat controls the flow of water from the radiator to the engine. If the flow is too fast, the water doesn't stay in the radiator long enough to cool off so your engine could end up running too hot."
But its about motorcycle engines...Not sure how that's different.
Also found this:
http://forums.corvetteforum.com/show....php?t=1402508
This guy has this to say:
"You must realize that a stat is NOT an open/ closed valve....As cooler water returns from the rad it causes the stat to partially or even totally close over and over again.....continual coolant flow is usually bad...(as are systems with no stats...) the coolant in the engine needs time to collect the heat from the engine....and at the same time the coolant in the rad needs to slow down or stop for a short time for the heat to be exchanged with the atmosphere....as simple as it looks, it is a complicated system (especially with ECM controlled fans...) Making it work right is easy if you KNOW how it works and why....."
Also this:
http://www.ehow.com/tips_7683.html
It says:
"You will get almost identical symptoms to a sticking thermostat if you fit a normal thermostat to a car that requires a dual-acting thermostat (eg., some Corvettes). A dual-acting thermostat has a spring-loaded valve that closes the bypass circuit. "
Further searching lead me to this:
http://www.theherd.com/articles/lt1_cool.html
I didn't understand some of it but it says:
"Dual-acting means that the thermostat regulates coolant flow both in to as well as out of the engine, while the bypass portion of the thermostat circuit supplies the water pump with a full flow of liquid coolant at all times. This is unlike a conventional engine thermostat, which only regulates coolant flow at the engine outlet, and which does not allow full flow through the water pump when the engine is cold and the thermostat is in bypass mode."
Comments?
Old Jun 19, 2006 | 06:30 PM
zoom44's Avatar
either would be bad in th elong run. stuck closed bad sooner. depends on the stat but most are designed to fail closed with a few now designed to fail open.
Old Jun 20, 2006 | 09:00 AM
OnRails's Avatar
OK, for anyone that cares I wrote to a corvette cooling expert and this is his reply. He seems to suggest that we may both be wrong.
Your brother is talking about an old wive's tale (read: myth) which has no basis in fact. On that, clearly he is wrong, and you are correct. I've run vehicles without a thermostat at all (equal to stuck "WFO" <g> in most vehicles), and found them extremely difficult to get up to proper operating temperatures.
HOWEVER, it is also true that the overheating problem he is having with his
LT1 may not be caused by the thermostat at all. The LT1 reverse flow cooling system is quite trouble prone, for example there can be problems with clogging, trapped air, and the water pump has proven to be unreliable.
I've had so many questions and complaints from people about LT1 cooling problems that I've written an article on the subject, which I will send in a following message. The article details the sources of cooling problem (and solutions) that I've found with the LT1. Let me know what the source of his cooling problem turns out to be in the end. Scott.
Old Jun 20, 2006 | 10:49 AM
OnRails's Avatar
Debate UPDATE
The debate continues....
He says:
for his vehicle, at normal driving conditions if he took his car to the desert and ran without the thermo at 100 mph, it would overheat just take your thermo out, ran at 130mph on a hot day see if it still runs cool
I Say:
"no basis in fact"...seems pretty clear to me?
He Says:
that's complete bullshit to think that every car is same. take an iron block, smaller engine....yes, you could probably take the thermo out and it not overheat. take a big block, high output engine...it will overheat. it's ignorant to say that it would be the same for every vehicle
Comments?
Old Jun 20, 2006 | 02:15 PM
OnRails's Avatar
OK, I'm almost positive nobody cares, but for posterity here is the end of the debate....
I sent the above to the "Corvette cooling guru" and here is his reply that finally convinced my brother-in-law:
My main comment is that it is obvious he has never studied physics or engineering, and from the impression you are giving me, at this late stage he may be untrainable. <g>
But I like a challenge, so I'll give it one LAST try:
Cooling really is a fairly simple principle, it involves the transfer of heat from one material to another. The more of each material you can get into contact with the other, the more heat will be transferred. This means that if you move MORE air through the radiator in a given amount of time, more heat will be transferred from the coolant to the air. It also means that if you move MORE coolant through the engine in a given amount of time, more heat will be transferred from the engine to the coolant as well.
The one thing I've found that most people *don't* understand about engine cooling systems is that the thermostat only controls the MINIMUM temperature an engine will run. Once the T-stat is WFO, the actual engine temperature depends on the capacity of the cooling system to transfer and remove heat balanced against the thermal output of the engine.
Real world example: I had a '78 Riv (2-door B-car) with an Olds 403 (6.6L) in which I had installed a 180 degree thermostat along with an accurate VDO temperature gauge. With the gauge, I could accurately track the engine temp and even see exactly when the T-stat opened. After starting the car, the engine temp would rapidly rise to 180-185, whereupon the needle would visibly stall, maybe even drop 5 to 10 degrees, then slowly rise to between 190 and 200, where it would generally stay under MOST conditions. However, in 90+ degree ambient temperatures, with the AC on and running at highway speeds, the temperatures would begin to creep upwards to as high as 225. That is still an acceptable temperature (most factory stock engines are designed to run that hot before the fans kick on in fact), but I wanted to see if I could get it to come down.
So I installed a 160 degree T-stat in place of the 180. The only difference I noted was in the initial warm-up. The engine would rapidly rise to 160-165, I could see the gauge needle stall as the T-stat opened, then it would slowly rise and stabilize at between 170-180 under most normal conditions. However, just like before, in 90+ degree ambient temps, with the AC on and running highway speed, the temperature would again creep up to 225.
Finally I decided to remove the thermostat altogether. What this did was make the engine incredibly slow to warm up, and the temperature it would run at was largely influenced by the ambient temps. In the morning for example, I could barely get the engine to rise over 130 to 140. On a normal 70 degree day with the AC off, it would rise to 170-180. But just as before, with 90+ degree ambient temps, the AC on and cruising at highway speeds, the temperature STILL rose significantly higher, but I did note that it would generally max out at 220 instead of 225.
I attributed that minor 5 degree reduction at the top end to be the elimination of any coolant flow resistance by the thermostat, since even when a T-stat is wide open it does provide some resistance to flow.
BTW, I later *repeated* this experiment almost exactly with an '88 Caprice
9C1 with an LM1 350, noting all of the temps I experienced were virtually identical. In fact my friend still drives this car TODAY (250K miles) and has been *removing* the T-stat EVERY SUMMER since he bought it from me many years ago. He also completely ripped out the AC and installed a larger Modine aluminum radiator. Once the AC was ripped out (esp. the condenser in front of the radiator) the max. temps immediately dropped 10 to 20 degrees (increased airflow through the radiator), and subsequently adding the larger aluminum radiator dropped the max. temps another 5 to 10 degrees. Now even under the worst ambient conditions, he barely hits 195 on the gauge.
What all this should tell you is what I have KNOWN all along, which is that the thermostat only controls the MINIMUM temperature that the engine will run. Once the T-stat is open, the capacity and performance of the cooling system balanced against the thermal output of the engine is what decides what the coolant temperature will be. Meaning that even though the T-stat is fully open (or even removed entirely) the temperatures will equalize at whatever point where the engine thermal output balances against the capability of the cooling system to remove that heat. As the engine warms up or the load changes, the system will reach a stable temperature (depending mainly on ambient temperatures and engine load), which if the system is designed properly, will always be below the point where any damage can occur.
If one wanted to improve the performance of a liquid cooling system in order to reduce any rise in temperature that would occur AFTER the thermostat was open (or removed), then there are two main things that cold be done: transfer MORE heat from the engine to the coolant, and/or MORE heat from the coolant to the air.
To transfer more heat from the engine to the coolant, you would increase the flow speed and therefore volume over time of coolant circulating through the engine. This could be accomplished by changing pulley diameters to spin the water pump faster (of course also keeping it below the point where cavitation would occur), or by designing a pump that used larger impellers to flow more coolant at a given speed, or a combination of both. As any cooling system engineer could tell you: if you flow MORE coolant through the engine in a given amount of time, you will absorb and therefore remove more heat as well.
Of course the performance of the entire system depends not only on transferring heat from the engine to the coolant, but then also transferring that same heat from the coolant to the air. Improving one side of the system won't have any benefit unless the other side is up to the same or higher capacity as well.
Increasing the size, capacity, and surface area of the radiator will allow more of the heat to be moved from the coolant to the air. Likewise, increasing the speed of the airflow over the radiator (or removing restrictions like the AC condenser) will also enable the transfer of more heat, which is why at lower speeds a larger or higher CFM fan could be used.
If your B-I-L were correct (I'm imagining some sort of alternate universe where the laws of physics are upside down <g>), then flowing MORE coolant through the engine would somehow transfer *less* heat, and I guess by corollary he would say that flowing MORE air over the radiator would transfer
*less* heat as well. Yeah right. <g>
All I can say about *that* is this is obviously *not* the way it works in the *reality based* universe you and I live in. <g>
OK, time to end this. At this point all I can say is that if he recognizes the truth, then my mission was a success! (yay!) If however he remains unconvinced, then I have failed (boo!), and unfortunately would have to believe that any further attempts at education in this matter would also be in vain. Let me know how it turns out, but in either case I consider the subject officially "closed." (yay!) Scott. <g>
PS: Tell your B-I-L not to take any of this personal, I tend to be a bit of a smart-*** in messages like this, all in fun of course. <g>
I thought it was pretty informative and applies to all liquid cooled engines...including our wonderful RX-8!
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
titaneum_grey
Sep 6, 2015 10:21 PM
iwannarun
Sep 6, 2015 01:37 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
