Agency Pulley HELP!
Old Jun 19, 2006 | 02:16 PM
Rootski's Avatar
DGAF
Agency Pulley HELP!
I installed my Agency crank pulley today (with no small difficulty I might add), and when it was all said and done I fired the car up and the DSC/TCS lights were blinking! My whole stability control system is disabled. I tried disconnecting and reconnecting the battery. My best guess is that I disconnected some cable that I forgot to re-attach. Does anyone know what cable this might be? Or is this a side-effect of underdriving the alternator?
Old Jun 19, 2006 | 02:22 PM
pbuck1's Avatar
pbuck1
It's nothing that you did you need to reset the system . Start the car and turn the steering wheel all the way to the left and back to the right you need to due this I think 3 or 4 times both ways that will reset the DSC and the trac light will go out in time .
Old Jun 19, 2006 | 02:24 PM
supergoat's Avatar
I don't "smell good".
On my '05 I just need to turn the wheel all the way to the left and right once to get the DSC OFF light off and the little skidding car light does not come on the next time I crank the car.
Old Jun 19, 2006 | 02:35 PM
Rootski's Avatar
DGAF
Just got back from a drive, and I have a CEL now too. I'll go try a PCM reset.
Old Jun 19, 2006 | 02:42 PM
Rootski's Avatar
DGAF
There, that fixed it. Thanks.
Old Jun 19, 2006 | 02:46 PM
pbuck1's Avatar
pbuck1
your welcome .
Old Jun 19, 2006 | 03:39 PM
flyboi1121's Avatar
werD?
hey rootski, did you need a tq wrench? i just got my pulley today and any advice would be helpful
Old Jun 19, 2006 | 03:41 PM
Moostafa29's Avatar
Storm Trooper
I think there is a full DIY in the pulley thread.
Old Apr 24, 2007 | 12:56 PM
305WANKEL's Avatar
I Installed My Pulley Today And My Cel Blinks - Blinks And When I Stop The Car It Turns Off . Its Weird , But I Can Notice The Gains
Old Apr 24, 2007 | 02:17 PM
Skiptomylue's Avatar
im not sure if i ever had those problems.. after i installed my Pully my car didnt turn back on.. that was the first.. and only time i have flooded my car..
Old Apr 24, 2007 | 02:30 PM
Moostafa29's Avatar
Storm Trooper
What???
Old Apr 24, 2007 | 02:36 PM
chickenwafer's Avatar
Nope
Do the 21 brake tap reset to reset your CEL.
If that doesn't work, pull the room fuse. The brake tap didn't work for me, so I pulled the room fuse and now no CEL for over 1,000 miles.
Old Apr 25, 2007 | 10:05 AM
WreakLoosE's Avatar
Yep that is how you fix it. I just did the same thing did the 21 brake taps and pladow!! working no CELs or nuthing.
Old May 7, 2007 | 02:06 PM
SE3PSynergy's Avatar
Has a headache.
21 tap didn't work for me either... where is the room fuse?
BTW I am pleased with this pulley too, the car feels a lot smoother now. Definitely not a huge power gain if any, just feels really smooth revving.
*edit I located the room fuse... pulled it and I STILL have a CEL. Any advice?
Old May 7, 2007 | 08:03 PM
Maraku's Avatar
Just installed mine last week. Turn the ignition on and tap the brakes 21 times. Then turn the steering wheel all the way left, then all the way right. Should fix the CEL and the DSC light.
Old May 7, 2007 | 08:42 PM
Has a headache.
That killed the cel, thanks a lot!
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RXFEVER
Sep 11, 2016 02:51 PM
UHATEIT
Dec 10, 2015 02:57 PM
