MIX MATCH eMANAGE
Old Jun 12, 2006 | 09:15 AM
Six Shooter's Avatar
MIX MATCH eMANAGE
Do you guys know if I can switch the GREDDY eManage, to the CZ before I install the GREDDY kit? Or has anyone tried? Will it work???????????
-6.
Old Jun 12, 2006 | 09:23 AM
rkostolni's Avatar
Why would you want to do that? No, it won't work. The CZ is not setup correctly. Without investing too much time thinking about this, a couple differences are: 1. The CZ alters the MAF signal, the emanage setup directly alters the injector signals. 2. The CZ doesn't include a Map sensor. There are other differences as well
Old Jun 12, 2006 | 09:25 AM
Since the CZ is an E-manage.....you could re-wire the whole thing and it would work. But it would be a lot of work.......as rkostolni said...why bother
Old Jun 13, 2006 | 01:45 AM
seikx8's Avatar
Is this title ok?
I could passed this up,
Now, why would you want to switch to CZ as its intended for N/A and you are installing a turbo. Are you trying to work backward and create yourselves more headache? that doesn't make any sense.
Unless you have the CZ unit already and want to convert it to use with the kit minus the emanage, that would be more reasonable.
Old Jun 13, 2006 | 01:46 AM
NgoRX8's Avatar
go get the interceptor-x
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
Jazzmeson
Aug 30, 2015 02:42 AM
