if you unplug your battery do you have to get the ecu re-flashed??
Old Jun 9, 2006 | 03:16 AM
p-trix's Avatar
I just upgraded my battery do I have to get my ecu re-flashed.
Old Jun 9, 2006 | 03:28 AM
The Ace's Avatar
Greek Power
Νο
Old Jun 9, 2006 | 03:32 AM
Mazdaspeed RX8 ver2's Avatar
Originally Posted by The Ace
Νο
i love that one word answer.. very nicely put.
Old Jun 9, 2006 | 03:37 AM
p-trix's Avatar
thanks
Old Jun 9, 2006 | 01:19 PM
puch96's Avatar
but you do have to re-activate your stability control/traction control... explained in the owner's manual
Old Jun 9, 2006 | 01:22 PM
Nemesis8's Avatar
Bigus Rotus
Yes
Old Jun 9, 2006 | 01:40 PM
RoyalPain's Avatar
It really depends on how long your car is disconnected from the battery. My car was in the body shop after it was hit and they had the battery disconnected for a whole day and when they connected the battery nothing happened when they tried to start the car. They had to send it to the dealer to get the ECU reflashed
Old Jun 9, 2006 | 01:54 PM
The Ace's Avatar
Greek Power
Τhe settings and maps are stored in EEPROMS. These do NOT lose their charge so easily, if at all. Something else happened with your car....
Unhooking the battery, changing the battery or anything similar will only result in your radio losing the stored stations, and maybe asking you for the PIN, if you have activated the anti-theft system Even the DSC activation is something that will never be necessary (at least this stands for the EUDM RX8s). Is this even a valid procedure ?
Old Jun 9, 2006 | 02:18 PM
puch96's Avatar
for DSC activation is almost always needed... But very easy to re-activate... Turn the vehicle ignition on, turn the steering fully clockwise, then fully counterclockwise, then the DSCOFF light will come off. Then turn the ignition off, then back on... and everything should be fully operational then.
Old Jun 9, 2006 | 02:34 PM
zoom44's Avatar
hahha no. for instance i had my PCM out of the car for 4 days. something else happened to your pcm.
Old Jun 9, 2006 | 03:13 PM
RoyalPain's Avatar
I am just relaying what I was told by the body shop.
Old Jun 9, 2006 | 03:28 PM
zoom44's Avatar
i know its just a silly thing for them to say. reason- if your car was part of the thermal damage recall and had the work done or it was not involved then there is no flash for you to get. also no "flash" would get your car started if it refused to start.
could be there was something wrong with the PATS and they needed to program the system to know the key again but that isnt effected by a dead or disconnected battery either. other than that it would have to be mechanical/electrical in nature.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Evan Gray
Sep 26, 2015 12:30 PM
