k&n air filter - petrol consumption
Old Jun 8, 2006 | 06:25 AM
zarekr's Avatar
i just dropped in a k&n air filter into the stock airbox yseterday and took the car for a spin and it seemed like the fuel consumption took a heavy hit. i only did about 15 miles and the guage dropped 2 notches (i know this is not an accurate measure of the petrol but its also not normal compared to how it drops usually).
what is the likelihood that the air filter is causing this? is it possible im just imagining it because im already disenchanted with the car's crappy mpg? could it have been installed wrong? when i put it in a pressed the sides down quite firmly but i dont know if it could be the wrong way or something like that? it looked fine and fit perfectly so i dont know..
Old Jun 8, 2006 | 09:15 AM
zenmoused's Avatar
the stig is my hero
That's a terrible way to gauge milage. Record your miles for a tank using the trip odometer, and divide that number by how many gallons it takes to fill it back up. That will give you milage. You can do a before and after if you're concerned, but no the K&N (unless you really botched installation somehow) will not give you worse mpg. If anything you should get a slight boost since it gives you less resistance through the airbox. Oh... and if you search you can find all the info you need. This topic has been posted to death several times over.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Danield97
Sep 30, 2015 05:59 PM
drlubell
Sep 26, 2015 11:58 PM
