Interceptor And E-01
I know you cannot use the E-01 to tune the interceptor, but after spending almost 500 dollars i hate to junk the E-01 Completely. Now my question is can i still use my greddy warning gauge's that i have and the E-01 (just to control boost and see boost pressure, using the warning gauges to let me know when egt and A/F's are not right)
Im having massive problems tuning the Junk emanage we have been given and after 3 weeks of pain and b.s. im finally going to give up and spend 1500 and get the interceptor
I use my E-01 with my InterceptorX.
BTW -- if you get the InterceptorX get the optional O2 Sensor plug-in -- it makes a world of difference
and allows for optimal fine tuning without going to the dyno -- well worth the $$$$
The E0-1 will not loose any functions except the ability to access the Emanage. So all of the display,warning, graphing functions will remain unaffected.
The plug-in WB02 is a add-on feature that will enable you to use the built in data logger and real time display to monitor,record and use this data to tune your Interceptor-X unit. This will allow most of the tuning to be done before you ever get to the dyno!
You want to buy mine??
v300
21
Apr 28, 2008 10:22 PM
adrian-1
RX-8 Multimedia/Photo Gallery
18
Aug 22, 2005 11:22 PM
