Wierd - rx-9 rpm only goes between 2 and 3 thousand rpm
Old May 29, 2006 | 08:10 PM
darren90909's Avatar
Its memorial day evening -- went out to start the 8 and it engine only runs between 2 and 3 thousand rpm -- I push the gas pedal and it runs at a slightly higher rpm but thats it -- check engine light came on and the anti-slip light came on ------ I suppose 2morrow I could drive to dealer that way ---- any ideas from anyone is appreciated ----- only 8 thousand miles on my 05 six speed
Old May 29, 2006 | 08:23 PM
skhmund's Avatar
THE BITCH IS DEAD
i dont thnk it safe to rev it wen its cold, should be easy wit her, let her warm up n then have yor way
Old May 29, 2006 | 08:24 PM
rx-8 I mean ----- no abuse went out to run an errand and started the car and from what I have gathered the 8 is in limp mode --- how do I cure limp mode??
Old May 29, 2006 | 08:29 PM
tiggerlee's Avatar
May Cause Anal Leakage
Viagra
Old May 29, 2006 | 08:31 PM
do I add viagra to the oil or the gas tank
Old May 29, 2006 | 08:49 PM
StealthTL's Avatar
Metatron
Nein....
I just wanna know where ya got the RX-9 ????
S
Old May 29, 2006 | 08:53 PM
typo combined with stress of a car that is in limp mode that I need to get to work in the morning (now do u understand) ------- went out to start is again and it runs fine now -- the check engine light is still on and the anti-slip light went off ------ very wierd
Old May 29, 2006 | 08:59 PM
FASTNMEAN8's Avatar
WHO's WANKEL?
Originally Posted by tiggerlee
Viagra
not to laugh at your problem darren, but this comment is just funny
Hope everything works out for you buddy, just take it to the dealer and let them have a look, if their good they'll fix it with no problem....
Old May 29, 2006 | 09:00 PM
puch96's Avatar
I would take it to the dealer anyways.... Also, call the dealer and explain your situation before driving there with her. Just to be sure that nothing will happen if you drive it tomorrow based on what you stated that happened before.
Old May 29, 2006 | 09:02 PM
MTLbroker's Avatar
You have a faulty abs brake sensor. An intermittent problem. Car thinks you are losing traction and engages dsc. I suggest you take it to the dealer and have the sensors and connections checked. Last thing you want is for the antislip to kick in while on the highway travelling at high speed.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
