Installing strakes AFTER front splash guards?
Old May 25, 2006 | 05:53 AM
New Yorker's Avatar
I'd like to install strakes, but unfortunately I already have the front splash guards. Anyone know how to do this? I'm asking because, while I'm good at following instructions, I'm not very handy—so I'm NOT the type who could "figure it out" just by looking. (In an older thread, someone mentioned it might be possible if you had small hands, which I do.) Also, would I need to replace the double-sided tape? If so, exactly what tape—brand & size—should I get?
Old May 25, 2006 | 08:05 AM
BoosTED's Avatar
You should be able to get around the splash guards without taking them off.
Just take the entire wheel well cover out.
Or attempt to move it around the mud flap by pulling the screw and clip from the flap and working the well cover out so you can access the side vent from inside.
Old May 27, 2006 | 06:43 PM
New Yorker's Avatar
Worked just as you said - no problem at all. Thanks for the tip.
Old May 28, 2006 | 05:42 AM
BoosTED's Avatar
Good to know as I now have the flaps on
I had installed them before I had the mud flaps installed.
In case I need to adjust them later.
Mr. Pockets
RX-8 Racing
19
Oct 17, 2019 08:03 AM
RXeckless
Aug 16, 2015 12:51 PM
ColeParkerrr
Jul 23, 2015 10:50 AM
