Problem with my emergency brake indicator
Old May 22, 2006 | 12:44 PM
oryas's Avatar
My emergency brake indicator light on my dash panel is now constantly on. It's a minor annoyance which I would like to fix. I don't want to take my car back to the dealership if this is an easy problem to fix myself. Does anyone know how to fix this? Is this a Fuse issue?
Old May 22, 2006 | 12:47 PM
Check the switch...it's under the shifter cover right in front of the E-brake handle. The connector may have fallen off...or the switch may be broken.
If you look at an Axial Flow SS install you can see a DIY to access that area
Old May 22, 2006 | 12:50 PM
dupa12345's Avatar
not sure about the 8 but ive seen other mazdas indicate low break fluid or worn out breaks by the emergency break light .. dont ask me why .. i would never connect the two but thats what they do
so if the 8 does the same .. maybe your breaks are due for service
Old May 22, 2006 | 04:30 PM
dillsrotary's Avatar
jersey fresh
check your brake fluid, my old mazda protege lit up when the brake fluid ran slightly low
Old Jun 14, 2006 | 02:26 PM
oryas's Avatar
I was due to make a brake pad change but I didn't think there was a connection between the emergency brake light and my brake pads. I just got make brakes changed last week, and my emergency brake light is back to nomal. So either it's a coincidence or Dupa12345 was correct.
Old Jun 14, 2006 | 02:53 PM
puch96's Avatar
take it to service! My mom's mazda protege brake light lights up when the brake fluid is low, or in her case, she needed new brake pads.
Old Jun 14, 2006 | 04:51 PM
zoom44's Avatar
check the manual?
Old Jun 14, 2006 | 08:15 PM
Fluid Level Worn out pads causes fluid level to go down because of the pad wear...the pistons have to stick out more to push the pads against the rotors. It seems that when the light comes on that the pads are about gone.....that's nice. My BMW had a much smaller reserve capacity and it would set off the light much sooner.
xAgyex
Jun 3, 2026 03:47 PM
ktec
Jun 26, 2021 10:18 AM
drebbrnator
Dec 27, 2018 07:02 PM
thewatcher101
Jul 27, 2015 09:44 PM
