hobby
05-14-2006, 05:17 PM
How do you get those little plastic screws to come out without damaging them? Mine won't budge.
View Full Version : clear side markers hobby 05-14-2006, 05:17 PM How do you get those little plastic screws to come out without damaging them? Mine won't budge. dannobre 05-14-2006, 05:20 PM In the fender wells?? They turn about 1/2 turn and then pull out the center section. If they are full of dirt they are difficult to get out. WD-40 or even water may help. If you break them they are about a buck each to buy new ones poorman 05-15-2006, 10:12 PM The screw is in two parts, a center and an outer. If it gets dirty like the above has stated, you can use wd-40 or do what i did. Hold the outer side of the screw and turn the inside with the screwdriver. Usually this would cause the center to twist and pop out a little like it should. Make sure your only holding the outer side of the screw. If this does not work used the wd-40 :) NgoRX8 05-15-2006, 10:47 PM get a philips screw driver and turn slightly to the left. you will see it come out. if it's stuck for some reason you'll have to loosen it by popping it out a lil while you turn. |
