Couple of offset questions...
Old May 6, 2006 | 04:25 PM
phxtravis's Avatar
I guess RX-8's are fast?!
FYI, these are for a stock ride height MT RX8.
Would these offsets work "as is"?
1)18x7.5 +40mm
2)18x7.5 +42mm
thanks
Old May 6, 2006 | 05:12 PM
RPIRX-8's Avatar
Apexing at Oak Tree
yes they would, but why would you want to go with a thinner wheel then reduce the offset by 10mm? Going with a lower offset number is going to push the wheel farther out to the corners. I would at least stick with the stock wheel size (18x8) or go with a wider wheel (18x8.5 or 18x9) if you are going to reduce the offset. I run 18x8 +35mm offset on my summer rims.
Old May 6, 2006 | 05:21 PM
phxtravis's Avatar
i just found these wheels on the web and was interested...also I dont know the specs on the factory wheels so i had no clue.
Old May 6, 2006 | 05:36 PM
RPIRX-8's Avatar
Apexing at Oak Tree
The stock wheels are 18x8 +50mm offset weighing in around 22.5 lbs.
Do you have any idea what the stock ride height is?
Old May 6, 2006 | 06:11 PM
phxtravis's Avatar
no, i dont
Shankapotamus3
Mar 14, 2021 03:53 PM
hufflepuff
May 30, 2016 10:45 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
