People with Toyo T1-Rs...
Old May 5, 2006 | 06:52 PM
RL8's Avatar
RL8
How many miles did it take to fully break-in these tires? I've had them for 600miles and they've improved handling from new, but still not as grippy as I expected.
Thanks.
Old May 6, 2006 | 04:07 PM
zaglo6204's Avatar
mine's better
I think mine took 250-300... hard to tell. I've been very happy with mine (I've written praise for them all over this forum), but I don't drive hard enough on a regular basis to really test their limits. The few times I have, though, they've stepped out very progressively; it didnt come as a surprise, & I still felt completely in control.
Old May 7, 2006 | 03:09 AM
im only on 200 miles...if we're comparing stock tires vs. these, HUGE DIFFERENCE!
Old May 11, 2006 | 06:36 PM
NC RX8's Avatar
300 miles ... Still Not very grippy .... maybe not fully break-in !?
Old May 12, 2006 | 05:04 PM
GeorgeH's Avatar
What pressure are you running?
Old May 12, 2006 | 05:48 PM
RL8's Avatar
RL8
I'm running 36psi all around.
Old May 12, 2006 | 07:24 PM
GeorgeH's Avatar
Try dropping it to 32. I haven't tried mine at 36 yet, but if you go too high they start to loose grip.
Also, make sure you have lots of negative camber (say, -1 at the front, and at least as much at the rear). The Toyos like negative camber.
Old May 12, 2006 | 07:25 PM
GeorgeH's Avatar
In fact, if you want to determine if 36 is too high, drop the fronts only. If the car oversteers drop the rears to. If it understeers, bring the fronts back up.
Old May 15, 2006 | 11:53 AM
iridearocket's Avatar
Track Tires need 1 warm up lap to break in. I would be very surprised if street tires get any better after a short drive.
Old May 15, 2006 | 12:15 PM
i need an alignment, and also need to get my camber adjusted, it looks tight but i wouldn't want too much uneven tire ware.
Old May 15, 2006 | 12:46 PM
crossbow's Avatar
At 10,000 miles I sold them. I found overall, regardless of Toyo's marketing, they were inferior tires to the T1-S in both dry and wet handling.
The T1-R seems to have softer sidewalls, which is why its rated higher in regards to "ride quality and noise level".
I have since replaced my T1-R's with hankook Ventus R212's, which made the T1-R's feel like all seasons by comparison (in the dry).
Here's my little graph I made to counter toyo's.
I really loved the T1-S's, and wanted to love the T1-R's, but they just aren't the same tire...compromises suck. If you are waiting for the T1-R's to breakin and suddenly provide magical handling and grip...you'll be waiting until the tread hits cord.
Old May 15, 2006 | 01:20 PM
GeorgeH's Avatar
This certainly doesn't match my experience. I find the T1-Rs to have better turn-in comapred to the T1-Ss, with grip at least as good. My 245s grip better than the 225 OEM Potenzas did, and I replaced the Potenzas well before they were worn out.
Of course, they don't grip as well as your Hankooks. Those are one of the top choices for street tire autocross competitors. But the Toyos should last longer and provide better comfort, as you indicate.
As you say, compromises suck, unless it's the compromise YOU want. Everything is a compromise.
Old May 15, 2006 | 06:25 PM
crossbow's Avatar
I will agree with your comment on the turn in, but I still got less overall grip with the T1-R's. Everything just felt...I dunno, softer. I loved the T1-S's so much I ran them down till the tread was nearly gone, exciitedly bought the T1-R's as a replacement, and waited for them to break in for 10,000 miles.
The track and autox performance was noticably degraded. They always seemed to be squeeling with the tinest of efforts. I tried nearly a 10 psi differential trying to dial them in...no matter what I did they never gripped as well as my T1-S's.
Who knows, maybe I got a magical set of T1-S's, and a 5:00pm friday set of T1-R's. I just know I was all smiles with the T1-S's, and couldn't wait to get rid of the T1-R's.
I really miss the T1-S's rain performance though...those things were rediculous. It was like it wasn't even raining. The hankooks have no where near the same level of rain performance .
Old May 15, 2006 | 06:35 PM
BlueEyes's Avatar
haha, I had a car aligned last weekend, and I said the same thing, except with 5 degrees instead of 1
Old May 15, 2006 | 06:47 PM
GeorgeH's Avatar
That is odd. I've heard one other person say the T1-Rs weren't as good as the 'Ss for track use (in a 195/50-15 size). But I've had both on my Miata and I would never say the R's had a lot less grip than the S's. In fact, I was just thinking the other day that my current setup on my Miata (JICs set super low, with 195/50-15 T1-Rs) have about as much grip as my old setup (Tokico Illuminas w/GC sleeves, with about 1 inch higher ride height) did with 205/50-15 Falken Azenis 215s, at least on the street. Which is to say, the lower ride height & better camber control of the stiffer JICs more or less offset the grip differential in the tires. I won't say that with 100% certainty, since I never got to test these two setups back to back, but I was getting pretty good grip out of my Rs with the JICs.
On the RX-8 I really like the T1-Rs for street use. Again, though, it's because of the overall combination of attributes, rather than all-out performance. Sorry they didn't work out for you (and perhaps the original poster). I can understand how they would be lower grip than the 'kooks but it's odd that they struck you as lower performance than the Ss.
Old May 15, 2006 | 09:56 PM
lure3o1's Avatar
I had T1-S's and now I have T1-R's on and to me I never noticed that big of a difference in handeling from the T1-S's to the T1-R's. I do think it the T1-S's is alittle more sticky then the T1-R's. I run the psi at 32 about on both sets.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Tsurugi
Sep 7, 2015 08:27 PM
wayloco
Sep 1, 2015 09:03 PM
