MS style CF wing install???
Old May 2, 2006 | 10:19 PM
shinka213's Avatar
Pettit fangurl <3
Question MS style CF wing install???
I just received an MS style CF wing from rotary extreme....no directions in the box..dayum....Ive found some threads that talk about the install but no specific instructions...if someone out there has them can you put up a link or PM me..
thanks
Old May 4, 2006 | 02:20 AM
FABRO's Avatar
Registered Ricer
did you try calling them, I don't see any problems with them faxing it over or sending you directions over the net. Are their holes in your trunk already from the previous wing? If there is, it should be an easy install. Took me about 3 hours to do it w/out directions.
Old May 4, 2006 | 02:48 AM
Winning 8's Avatar
Hot Pit
make sure the lower piece fit your trunk, I got one from somewhere else and the fitment is so bad, I could put a finger in it.
Old May 4, 2006 | 06:03 AM
rob.rotor's Avatar
Here is a site with some instructions and a template
http://www.hi-impact.org/ryang/modif...8_bodykit.html
Old May 4, 2006 | 03:57 PM
shinka213's Avatar
Pettit fangurl <3
thanks Rob
your the man!!!
I did call rotary extreme....unfortunately directions dont come with them....
but the directions on that link are great!!!
now I got something to do this weekend
Old May 5, 2006 | 12:03 AM
Winning 8's Avatar
Hot Pit
when you drill the trunk, put a sheet cover the opening then place a block of wood under the area you want to drill the holes, so when you go over it will not damage your trunk. and easy cleaning with the sheet.
Old May 5, 2006 | 12:17 AM
Winning 8's Avatar
Hot Pit
0 degree for factory bumper
5 degree for bumper with front lip
15 degree for mazdaspeed bumper
30 degree for track use.
Old May 5, 2006 | 06:54 AM
shinka213's Avatar
Pettit fangurl <3
BIG QUESTION!!!
should every screw/bolt have a regular washer and lock washer....IMO it would make sense but if thats the case, I am missing a couple....
can anyone advise me of their install??
thanks
Old May 5, 2006 | 07:01 AM
FABRO's Avatar
Registered Ricer
I lost 2 or 3 of the washers when I was installing my wing and it turned out to be fine. I just check the screws every so often to make sure and nothing bad so far.
Old May 5, 2006 | 09:52 AM
Winning 8's Avatar
Hot Pit
go buy some
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
mitchrx8
Sep 13, 2015 08:05 AM
