245/30/18's
Old Apr 28, 2006 | 08:39 AM
momo's Avatar
Registered Laker's Fan
245/30/18's
Anyone running this size? I'm sticking with 18's with the same offset and some Tein S-tech springs. I'm wondering if I will run into any clerance problems? I'm just looking for a little improvement without degrading the overall ride. I don't track, but I do go on spirited runs. If anyone has pics, with this set up, can you please post them?
I will also be upgrading the sway bars, in the near future. Thanks for the help guys.
Old Apr 28, 2006 | 11:55 AM
connor@tirerack's Avatar
Forum Vendor
You won't have any clearance issues at all. In fact in my opinion the tire is to small for a RX8. The correct size would be a 245/40/18 which has an overall diameter of 25.7". The 245/30/18 has an overall diameter of 23.8". You would be loosing 2" of side wall height and most likely would not meet Mazda's minimum load capacity.
Old Apr 28, 2006 | 12:26 PM
The 245/40/18 is the most common upsized tire on here.......It fits on the stock rims, and gives a bit extra meat to the tires. There should be no rubbibg problems at all.
245/30/18's are too low profile....and too short.....your speedo would be way out to lunch...plus the ride would be very stiff......Hope it was a typo
Raz0rama
Jun 8, 2005 02:47 PM
